Use this section to validate your MongoDB setup on an Azure Cobalt 100 (Arm64) VM running Ubuntu 24.04 LTS. You will check service health, run a quick storage baseline with fio, validate CRUD operations with mongosh, and do light query, index, and concurrency checks before larger benchmarks.
For this exercise, mongod runs locally and access control is disabled by default. Keep the server bound to 127.0.0.1 until you configure users and authentication.
ps -ef | grep mongod
mongod --version
netstat -tulnp | grep 27017
What each command does:
You should see output similar to:
mongod --version
ubuntu 4288 1 0 10:40 ? 00:00:01 mongod --dbpath /var/lib/mongo --logpath /var/log/mongodb/mongod.log --fork
ubuntu 4545 1764 0 10:43 pts/0 00:00:00 grep --color=auto mongod
db version v8.0.12
Build Info: {
"version": "8.0.12",
"gitVersion": "b60fc6875b5fb4b63cc0dbbd8dda0d6d6277921a",
"openSSLVersion": "OpenSSL 3.0.13 30 Jan 2024",
"modules": [],
"allocator": "tcmalloc-google",
"environment": {
"distmod": "ubuntu2404",
"distarch": "aarch64",
"target_arch": "aarch64"
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
tcp 0 0 127.0.0.1:27017 0.0.0.0:* LISTEN 4288/mongod
This reads random 4 KB blocks from a 100 MB file for 30 seconds with one job and prints a summary.
fio --name=baseline --rw=randread --bs=4k --size=100M --numjobs=1 --time_based --runtime=30 --group_reporting
baseline: (g=0): rw=randread, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=psync, iodepth=1
fio-3.36
Starting 1 process
Jobs: 1 (f=1): [r(1)][100.0%][r=14.8MiB/s][r=3799 IOPS][eta 00m:00s]
baseline: (groupid=0, jobs=1): err= 0: pid=3753: Mon Sep 1 10:25:07 2025
read: IOPS=4255, BW=16.6MiB/s (17.4MB/s)(499MiB/30001msec)
clat (usec): min=88, max=46246, avg=234.23, stdev=209.81
lat (usec): min=88, max=46246, avg=234.28, stdev=209.81
clat percentiles (usec):
| 1.00th=[ 99], 5.00th=[ 111], 10.00th=[ 126], 20.00th=[ 167],
| 30.00th=[ 190], 40.00th=[ 229], 50.00th=[ 243], 60.00th=[ 253],
| 70.00th=[ 269], 80.00th=[ 289], 90.00th=[ 318], 95.00th=[ 330],
| 99.00th=[ 416], 99.50th=[ 490], 99.90th=[ 799], 99.95th=[ 1106],
| 99.99th=[ 3884]
bw ( KiB/s): min=14536, max=19512, per=100.00%, avg=17046.10, stdev=1359.69, samples=59
iops : min= 3634, max= 4878, avg=4261.53, stdev=339.92, samples=59
lat (usec) : 100=1.27%, 250=56.61%, 500=41.65%, 750=0.34%, 1000=0.06%
lat (msec) : 2=0.04%, 4=0.01%, 10=0.01%, 20=0.01%, 50=0.01%
cpu : usr=0.33%, sys=2.93%, ctx=127668, majf=0, minf=8
IO depths : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
issued rwts: total=127661,0,0,0 short=0,0,0,0 dropped=0,0,0,0
latency : target=0, window=0, percentile=100.00%, depth=1
Run status group 0 (all jobs):
READ: bw=16.6MiB/s (17.4MB/s), 16.6MiB/s-16.6MiB/s (17.4MB/s-17.4MB/s), io=499MiB (523MB), run=30001-30001msec
Disk stats (read/write):
sda: ios=127195/29, sectors=1017560/552, merge=0/15, ticks=29133/8, in_queue=29151, util=96.37%
Interpretation:
To verify that the MongoDB server is reachable you will perform a connectivity check. You will run a sanity test of core database functionality and permissions, refered to as CRUD:
mongosh --host localhost --port 27017
Inside the shell:
use baselineDB
db.testCollection.insertOne({ name: "baseline-check", value: 1 })
db.testCollection.find()
db.testCollection.updateOne({ name: "baseline-check" }, { $set: { value: 2 } })
db.testCollection.deleteOne({ name: "baseline-check" })
exit
What these commands do:
test> use baselineDB
switched to db baselineDB
baselineDB> db.testCollection.insertOne({ name: "baseline-check", value: 1 })
acknowledged: true,
insertedId: ObjectId('689acdae6a86b49bca74e39a')
baselineDB> db.testCollection.find()
_id: ObjectId('689acdae6a86b49bca74e39a'),
value: 1
baselineDB> db.testCollection.updateOne({ name: "baseline-check" }, { $set: { value: 2 } })
acknowledged: true,
insertedId: null,
matchedCount: 1,
modifiedCount: 1,
upsertedCount: 0
baselineDB> db.testCollection.deleteOne({ name: "baseline-check" })
{ acknowledged: true, deletedCount: 1 }
Run a lightweight query performance check.
mongosh --eval '
db = db.getSiblingDB("baselineDB");
for (let i=0; i<1000; i++) { db.perf.insertOne({index:i, value:Math.random()}) };
var start = new Date();
db.perf.countDocuments({ value: { $gt: 0.5 } });
print("Query Time (ms):", new Date() - start);
This connects to MongoDB, selects the baselineDB database, inserts 1,000 documents into the perf collection, and measures the time to count documents where value > 0.5.
Query Time (ms): 2
Measure how long MongoDB takes to create an index on a collection.
mongosh --eval '
db.perf.createIndex({ value: 1 });
print("Index Creation Time (ms):", new Date() - start);
This creates an index on the value field in the perf collection and prints the time taken.
Index Creation Time (ms): 22
Verify that MongoDB can handle concurrent client connections and inserts.
for i in {1..5}; do
mongosh --eval 'use baselineDB; db.concurrent.insertMany([...Array(1000).keys()].map(k => ({ test: k, ts: new Date() })))' &
done
wait
This runs five parallel MongoDB shell sessions, each inserting 1,000 documents into the baselineDB.concurrent collection.
[1] 3818
[2] 3819
[3] 3820
[4] 3821
[5] 3822
switched to db baselineDB;
[1] Done mongosh --eval 'use baselineDB; db.concurrent.insertMany([...Array(1000).keys()].map(k => ({ test: k, ts: new Date() })))'
[2] Done mongosh --eval 'use baselineDB; db.concurrent.insertMany([...Array(1000).keys()].map(k => ({ test: k, ts: new Date() })))'
[4]- Done mongosh --eval 'use baselineDB; db.concurrent.insertMany([...Array(1000).keys()].map(k => ({ test: k, ts: new Date() })))'
[3]- Done mongosh --eval 'use baselineDB; db.concurrent.insertMany([...Array(1000).keys()].map(k => ({ test: k, ts: new Date() })))'
[5]+ Done mongosh --eval 'use baselineDB; db.concurrent.insertMany([...Array(1000).keys()].map(k => ({ test: k, ts: new Date() })))'
All sessions completed successfully, confirming that concurrent inserts work as expected.
With these checks complete, proceed to the MongoDB benchmarking section to run workload‑focused tests on the Azure Cobalt 100 Arm64 instance.
