Run MongoDB on Arm-based Azure Cobalt 200 instances
What are Cobalt 200 and MongoDB?
Create an Arm-based cloud virtual machine using Cobalt 200
Install MongoDB and Mongosh
MongoDB baseline testing
Generate a MongoDB workload
Monitor MongoDB with mongotop
Monitor MongoDB with mongostat
Select an Azure Cobalt 200-based VM from the Dpsv7 general-purpose series. In the Azure portal, choose Ubuntu 24.04 LTS and set VM architecture to Arm64.
Start
mongod locally and confirm that it binds to 127.0.0.1. Connect with mongosh, run the service health checks, and review the MongoDB log for errors.You use a local test deployment with authorization disabled and
mongod explicitly bound to 127.0.0.1. Before you accept remote connections, set --bind_ip or bindIp, create users, and enable authorization.Ensure that
mongod is bound to 127.0.0.1, long_system_load.js is generating traffic in another terminal, and the MongoDB Database Tools are installed. Run mongotop while the workload is active.Confirm that
fio completes without errors and that your CRUD, index, and concurrency checks succeed in mongosh. While the workload runs, mongotop should update per-collection read and write times in real time.
