Manage ML workflows with MLflow on Google Axion C4A
Learn about MLflow and Google Axion C4A for machine learning
Configure Google Cloud firewall rules for MLflow
Create a Google Axion C4A virtual machine for MLflow
Install MLflow and track machine learning experiments
Deploy MLflow models as REST APIs
Select a Google Axion C4A instance with the
c4a-standard-4 machine type, which provides four vCPUs and 16 GB of memory. Use SUSE Linux for the VM.Allow inbound TCP access to port
5000 for the MLflow interface and port 6000 for the model-serving API. Attach the firewall rule to your VM through its network tag.Check the startup log for the listening address, then open
http://<VM-IP>:5000. You should see the MLflow interface after the server starts.Set
MLFLOW_TRACKING_URI to direct your MLflow client to the tracking server instead of a local directory. Run export MLFLOW_TRACKING_URI=http://127.0.0.1:5000.Confirm that your model appears in the MLflow Model Registry with a version and assigned alias. Then, call the REST endpoint and verify that its response contains predictions from the served model.
