Run Minecraft on an Arm-based Oracle Cloud Infrastructure instance
Create an Arm VM on Oracle Cloud Infrastructure
Install the Minecraft server on an Arm-based virtual machine
Connect to the server from the Minecraft client
Create an Arm-based Ampere A1 instance with Oracle Linux 9.
For Minecraft 26 or earlier, install Java 25 OpenJDK for aarch64. Use:
sudo dnf install java-25-openjdk.aarch64 -y.Use
tmux to create a persistent terminal session and start the server inside that session. You can disconnect and later reattach to the tmux session without stopping the server.Open TCP port
25565 in the Linux firewall. Run: sudo firewall-cmd --permanent --add-port=25565/tcp and sudo firewall-cmd --reload.Verify the OCI network policy for the instance allows inbound TCP traffic on port
25565 to the VM. Update the OCI security settings if needed, then try connecting again.
