In this section, you will build and run the llama.cpp server program using an OpenAI-compatible API on your AWS Arm-based server instance.
The Llama-3.1-8B model from Meta belongs to the Llama 3.1 model family and is free to use for research and commercial purposes. Before you use the model, visit the Llama website and fill in the form to request access.
Llama.cpp
is an open-source C/C++ project that enables efficient LLM inference on a variety of hardware - both locally, and in the cloud. You can conveniently host a Llama 3.1 model using llama.cpp.
Run the following commands to install make, cmake, gcc, g++, and other essential tools required for building Llama.cpp from source:
sudo apt install make cmake -y
sudo apt install gcc g++ -y
sudo apt install build-essential -y
You are now ready to start building llama.cpp.
Clone the source repository for Llama.cpp:
git clone https://github.com/ggerganov/llama.cpp
By default, llama.cpp builds for CPU only on Linux and Windows. You do not need to provide any extra switches to build it for the Arm CPU that you run it on.
Run make to build it:
cd llama.cpp
cmake -B build
cmake --build build --config Release
Check that llama.cpp has built correctly by running the help command:
./build/bin/llama-cli -h
If llama.cpp has been built correctly, you will see the help option displayed. The output snippet looks like this:
example usage:
text generation: ./llama-cli -m your_model.gguf -p "I believe the meaning of life is" -n 128
chat (conversation): ./llama-cli -m your_model.gguf -p "You are a helpful assistant" -cnv
You can now download the model using the huggingface cli:
huggingface-cli download cognitivecomputations/dolphin-2.9.4-llama3.1-8b-gguf dolphin-2.9.4-llama3.1-8b-Q4_0.gguf --local-dir . --local-dir-use-symlinks False
The GGUF model format, introduced by the Llama.cpp team, uses compression and quantization to reduce weight precision to 4-bit integers, significantly decreasing computational and memory demands and making Arm CPUs effective for LLM inference.
To requantize the model, run:
./build/bin/llama-quantize --allow-requantize dolphin-2.9.4-llama3.1-8b-Q4_0.gguf dolphin-2.9.4-llama3.1-8b-Q4_0_8_8.gguf Q4_0
This outputs a new file, dolphin-2.9.4-llama3.1-8b-Q4_0_8_8.gguf, which contains reconfigured weights that allow llama-cli to use SVE 256 and MATMUL_INT8 support.
This requantization is optimal specifically for Graviton3. For Graviton2, the optimal requantization should be performed in the Q4_0_4_4 format, and for Graviton4, the Q4_0_4_8 format is the most suitable for requantization.
You can utilize the llama.cpp server program and send requests through an OpenAI-compatible API. This allows you to develop applications that interact with the LLM multiple times without having to repeatedly start and stop it. Additionally, you can access the server from another machine where the LLM is hosted over the network.
Start the server from the command line, and it listens on port 8080:
./build/bin/llama-server -m dolphin-2.9.4-llama3.1-8b-Q4_0_8_8.gguf -n 2048 -t 64 -c 65536 --port 8080
The output from this command should look like:
main: server is listening on 127.0.0.1:8080 - starting the main loop
You can also adjust the parameters of the launched LLM to adapt it to your server hardware to achieve an ideal performance. For more parameter information, see the llama-server --help command.
You have started the LLM service on your AWS Graviton instance with an Arm-based CPU. In the next section, you will directly interact with the service using the OpenAI SDK.
