You can simulate latency and packet loss to test how your application performs under adverse network conditions. This is especially useful when evaluating the impact of congestion, jitter, or unreliable connections in distributed systems.
The Linux tc (traffic control) lets you manipulate network interface behavior such as delay, loss, or reordering.
First, on the client system, identify the name of your network interface:
ip addr show
The output below shows that the ens5 network interface device (NIC) is the device that you want to manipulate.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: ens5: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9001 qdisc mq state UP group default qlen 1000
link/ether 0a:92:1b:a9:63:29 brd ff:ff:ff:ff:ff:ff
inet 10.248.213.97/26 metric 100 brd 10.248.213.127 scope global dynamic ens5
valid_lft 1984sec preferred_lft 1984sec
inet6 fe80::892:1bff:fea9:6329/64 scope link
Run the following command on the client system to add an emulated delay of 10ms on ens5:
sudo tc qdisc add dev ens5 root netem delay 10ms
Rerun the basic TCP test as before on the client:
iperf3 -c SERVER -v
[ 5] local 10.248.213.97 port 43170 connected to 10.248.213.104 port 5201
Starting Test: protocol: TCP, 1 streams, 131072 byte blocks, omitting 0 seconds, 10 second test, tos 0
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 282 MBytes 2.36 Gbits/sec 0 8.02 MBytes
[ 5] 1.00-2.00 sec 302 MBytes 2.53 Gbits/sec 0 8.02 MBytes
[ 5] 2.00-3.00 sec 301 MBytes 2.52 Gbits/sec 0 8.02 MBytes
[ 5] 3.00-4.00 sec 302 MBytes 2.54 Gbits/sec 0 8.02 MBytes
[ 5] 4.00-5.00 sec 302 MBytes 2.53 Gbits/sec 0 8.02 MBytes
[ 5] 5.00-6.00 sec 304 MBytes 2.55 Gbits/sec 0 8.02 MBytes
[ 5] 6.00-7.00 sec 302 MBytes 2.53 Gbits/sec 0 8.02 MBytes
[ 5] 7.00-8.00 sec 303 MBytes 2.54 Gbits/sec 0 8.02 MBytes
[ 5] 8.00-9.00 sec 303 MBytes 2.54 Gbits/sec 0 8.02 MBytes
[ 5] 9.00-10.00 sec 301 MBytes 2.53 Gbits/sec 0 8.02 MBytes
Test Complete. Summary Results:
[ 5] 0.00-10.00 sec 2.93 GBytes 2.52 Gbits/sec 0 sender
[ 5] 0.00-10.01 sec 2.93 GBytes 2.52 Gbits/sec receiver
CPU Utilization: local/sender 3.4% (0.0%u/3.4%s), remote/receiver 11.0% (0.4%u/10.7%s)
snd_tcp_congestion cubic
rcv_tcp_congestion cubic
iperf Done.
The Cwnd size has grown larger to compensate for the longer response time.
The bitrate has dropped from ~4.9 to ~2.3 Gbit/sec - demonstrating how even modest latency impacts throughput.
To test the resiliency of a distributed application, you can add a simulated packet loss of 1%. As opposed to a 10ms delay, this will result in no acknowledgment being received for 1% of packets.
Given TCP is a lossless protocol, a retry must be sent.
Run these commands on the client system. The first removes the delay configuration, and the second command introduces a 1% packet loss:
sudo tc qdisc del dev ens5 root
sudo tc qdisc add dev ens5 root netem loss 1%
Now rerunning the basic TCP test, and you will see an increased number of retries (Retr) and a corresponding drop in bitrate:
iperf3 -c SERVER -v
The output is now:
[ 5] 0.00-10.00 sec 4.41 GBytes 3.78 Gbits/sec 5030 sender
[ 5] 0.00-10.00 sec 4.40 GBytes 3.78 Gbits/sec receiver
The tc tool can simulate:
For advanced options, refer to Refer to the tc man page .
