Most developers don’t need deep knowledge of a CPU’s memory consistency model. Programming languages and runtimes abstract the CPU’s model by providing their own memory ordering rules, synchronization constructs, and libraries. As long as the developer uses these correctly, compilers and runtime engines ensure that the code executes correctly on any CPU - whether its memory ordering is strong or weak.
Developers might want to dig deeper into this topic for various reasons including:
In this Learning Path, you will use publicly available tools to explore thread synchronization on Arm CPUs. You will gain enough working knowledge of these tools to explore thread synchronization concepts.
At the end of this Learning Path, you can find details of further resources that you can consult to gain a deeper understanding of this subject.
The formal definition of the Arm memory model is described in the
Arm Architecture Reference Manual for A-profile architecture
(often referred to as “the Arm ARM”) under the section called The AArch64 Application Level Memory Model. The ordering requirements defined in the Arm ARM is a transliteration of the aarch64.cat file hosted on the Arm
herd7 simulator tool
. In fact, the aarch64.cat file is the authoritative definition of the Arm memory model. As a formal definition, it is inherently complex.
The herd7 simulator tests snippets of Arm assembly against the formal definition of the Arm memory model (the aarch64.cat file mentioned above). The litmus7 tool runs the same snippets of assembly on actual Arm hardware, enabling a direct comparison between the formal model and the real-world behavior of an actual Arm CPU. These snippets of assembly are called litmus tests.
It’s important to note that an Arm CPU implementation might exhibit stronger ordering than the formal memory model. This is not a violation; the CPU still executes code in a way that is compliant with the memory ordering rules.
Herd7 and Litmus7 are part of the diy7 tool suite. You can install the diy7 tool suite by following the installation instructions . Install the tools on an Arm Linux system so that both herd7 and litmus7 can be compared side by side.
Start an Arm-based cloud instance. This example uses a t4g.xlarge AWS instance running Ubuntu 22.04 LTS, but other instances types are possible.
If you are new to cloud-based virtual machines, refer to Get started with Servers and Cloud Computing .
First confirm you are using a Arm-based instance:
uname -m
You should see the following output:
aarch64
Install OCaml Package Manager (opam). You need opam to install the herdtools7 tool suite:
sudo apt update
sudo apt install opam -y
Set up opam to install the tools:
opam init
opam update
eval $(opam env)
Now install the herdtool7 tool suite (which includes both litmus7 and herd7):
opam install herdtools7
You can run --help on both tools to review all available options:
herd7 --help
litmus7 --help
The input to both herd7 and litmus7 tools are snippets of assembly code, called litmus tests.
Shown below are some examples of running the tools with a litmus test.
Run herd7 with a litmus test:
herd7 ./test.litmus
Run litmus7 with a litmus test:
litmus7 ./test.litmus
Run litmus7 with 5,000,000 test iterations (default is 1,000,000):
litmus7 ./test.litmus -s 5000000
Run a litmus7 test in parallel on 8 CPUs:
litmus7 ./test.litmus -a 8
Run litmus7 with GCC emitting atomic instructions as required by the litmus test (explained later):
litmus7 ./test.litmus -ccopts="-mcpu=native"
Continue to the next section to learn about a litmus test example.
