Why measure bandwidth?
Latency tells you how long one access takes. Bandwidth tells you how many bytes per second the datapath can sustain when the CPU issues many independent accesses. High latency can be tolerable if the core can keep enough requests in flight to saturate the available bandwidth. Measuring both gives you a complete picture of each cache level’s capability.
Measure single-core bandwidth with ASCT
The ASCT bandwidth-sweep benchmark measures the average memory bandwidth achieved by a single core at each level of the memory hierarchy (L1, L2, LLC, and DRAM). It sweeps data sizes automatically and reports the bandwidth at each cache level. It also generates a bandwidth-vs-size plot (bandwidth.png) in the output directory.
The bandwidth-sweep benchmark depends on latency-sweep to determine the optimal data size for each cache level. If you haven’t already run latency-sweep, ASCT runs it automatically as a dependency.
Run the bandwidth sweep on each system and save the results:
sudo asct run bandwidth-sweep --output-dir bandwidth_results_$(hostname)
The output on a Graviton2 instance is shown below:
        Bandwidth at different levels of cache
Datasize Used Level Bandwidth [GB/s]
     32.0625K    L1            159.4
         288K    L2             73.4
        16.5M   LLC             35.9
         544M  DRAM             20.9
Image Alt Text:Bandwidth sweep on Graviton2 showing bandwidth at each cache levelBandwidth sweep on Graviton2
The Graviton4 results are below:
     32.0625K    L1            321.0
         640K    L2             95.1
           8M   LLC             78.0
         544M  DRAM             37.0
Image Alt Text:Bandwidth sweep on Graviton4 showing bandwidth at each cache levelBandwidth sweep on Graviton4
Look at the stepping pattern: high bandwidth for L1, a lower plateau for L2, a further drop at the LLC, and then the DRAM floor.
Interpret bandwidth benchmark results
The bandwidth-sweep benchmark reports the bandwidth at the optimal data size for each cache level, using the boundaries that latency-sweep identified.
Key differences to look for between Graviton2 and Graviton4:
  • L1 bandwidth: Graviton4 shows roughly 2x the L1 bandwidth of Graviton2. This likely reflects multiple microarchitecture improvements in Neoverse V2.
  • L2 bandwidth: Neoverse V2’s larger 2 MB L2 keeps more data in the fast private cache, and microarchitecture improvements on Neoverse V2 also increase L2 fill bandwidth.
  • LLC bandwidth: Graviton4 more than doubles the LLC bandwidth of Graviton2, reflecting improvements in the interconnect and shared cache design on Neoverse V2.
  • DRAM bandwidth (single core): Graviton4 achieves higher single-core DRAM throughput because Neoverse V2 supports more outstanding memory requests than Neoverse N1, and DDR5 provides more bandwidth per channel than DDR4.
Convert bandwidth to bytes per cycle
To convert GB/s to bytes per cycle, use your core’s clock speed:
$$\text{Bytes/cycle} = \frac{\text{GB/s} \times 10^9}{\text{Clock (Hz)}}$$
This normalization lets you compare microarchitectural efficiency independent of clock speed. The benchmark measures combined load and store throughput, so the results reflect both the core’s execution throughput and the details of the benchmark’s access pattern rather than a simple read-only port limit.
Additional ASCT bandwidth benchmarks
The bandwidth-sweep measures single-core bandwidth at each cache level. ASCT includes additional bandwidth benchmarks for multi-core and system-level measurements:
BenchmarkCommandWhat it measures
Bandwidth sweepsudo asct run bandwidth-sweepSingle-core bandwidth at each cache level
Peak bandwidthsudo asct run peak-bandwidthMaximum system bandwidth using all cores, with multiple traffic patterns (all reads, read-write mixes, non-temporal)
Cross-NUMA bandwidthsudo asct run cross-numa-bandwidthAggregate bandwidth per NUMA node, local and remote
To run all bandwidth benchmarks at once:
In this section you:
  • Ran the ASCT bandwidth-sweep benchmark to measure single-core streaming bandwidth at each cache level
  • Observed bandwidth plateaus corresponding to L1, L2, LLC, and DRAM
  • Learned about additional ASCT benchmarks for peak and cross-NUMA bandwidth
The next section extends this to multi-core bandwidth, showing how shared resources like L3 and DRAM behave under contention.
