Deploy Memcached as a cache for MySQL on an AWS Arm based Instance
Deploy Memcached as a cache for MySQL on an Azure Arm based Instance
Deploy Memcached as a cache for MySQL on a Google Cloud Arm based Instance
Deploy Memcached as a cache for Postgres on an AWS Arm based Instance
Deploy Memcached as a cache for Postgres on an Azure Arm based Instance
Deploy Memcached as a cache for Postgres on a Google Cloud Arm based Instance
You can deploy Memcached as a cache for Postgres on Google Cloud using Terraform and Ansible.
In this section, you will deploy Memcached as a cache for Postgres on a Google Cloud instance.
If you are new to Terraform, you should look at Automate GCP instance creation using Terraform before starting this Learning Path.
You should have the prerequisite tools installed before starting the Learning Path.
Any computer which has the required tools installed can be used for this section. The computer can be your desktop or laptop computer or a virtual machine with the required tools.
You will need a Google Cloud account to complete this Learning Path. Create an account if you don’t have one.
Before you begin you will also need:
The instructions to login to the Google Cloud CLI and create the keys are below.
The installation of Terraform on your Desktop/Laptop needs to communicate with GCP. Thus, Terraform needs to be authenticated.
To obtain GCP user credentials, follow this guide .
Generate an SSH key-pair (public key, private key) using ssh-keygen to use for GCP instance access. To generate the key-pair, follow this
guide
If you already have an SSH key-pair present in the ~/.ssh directory, you can skip this step.
Using a text editor, save the code below in a file called main.tf. Here we are creating 2 instances.
provider "google" {
project = "{project_id}"
region = "us-central1"
zone = "us-central1-a"
resource "google_compute_instance" "PSQL_TEST" {
name = "psqltest-${count.index + 1}"
count = "2"
machine_type = "t2a-standard-1"
boot_disk {
initialize_params {
image = "ubuntu-os-cloud/ubuntu-2204-lts-arm64"
network_interface {
network = "default"
access_config {
// Ephemeral public IP
metadata = {
ssh-keys = "ubuntu:${file("~/.ssh/id_rsa.pub")}"
resource "google_compute_firewall" "rules" {
name = "my-firewall-rule"
network = "default"
description = "Open ssh connection and psql port"
source_ranges = ["0.0.0.0/0"]
allow {
protocol = "icmp"
allow {
protocol = "tcp"
ports = ["22", "5432"]
resource "google_compute_network" "default" {
name = "test-network1"
resource "local_file" "inventory" {
depends_on = [google_compute_instance.PSQL_TEST]
filename = "/tmp/inventory"
content = <<EOF
[db_master]
${google_compute_instance.PSQL_TEST[0].network_interface.0.access_config.0.nat_ip}
${google_compute_instance.PSQL_TEST[1].network_interface.0.access_config.0.nat_ip}
[all:vars]
ansible_connection=ssh
ansible_user=ubuntu
EOF
In the provider and google_compute_firewall sections, update the project_id with your value.
The inventory file is automatically generated and does not need to be changed.
Use Terraform to deploy the main.tf file.
Run terraform init to initialize the Terraform deployment. This command downloads the dependencies required for GCP.
terraform init
The output should be similar to:
Initializing the backend...
Initializing provider plugins...
- Finding latest version of hashicorp/google...
- Finding latest version of hashicorp/local...
- Installing hashicorp/google v4.57.0...
- Installed hashicorp/google v4.57.0 (signed by HashiCorp)
- Installing hashicorp/local v2.4.0...
- Installed hashicorp/local v2.4.0 (signed by HashiCorp)
Terraform has created a lock file .terraform.lock.hcl to record the provider
selections it made above. Include this file in your version control repository
so that Terraform can guarantee to make the same selections by default when
you run "terraform init" in the future.
Terraform has been successfully initialized!
You may now begin working with Terraform. Try running "terraform plan" to see
any changes that are required for your infrastructure. All Terraform commands
should now work.
If you ever set or change modules or backend configuration for Terraform,
rerun this command to reinitialize your working directory. If you forget, other
commands will detect it and remind you to do so if necessary.
Run terraform plan to create an execution plan.
terraform plan
A long output of resources to be created will be printed.
Run terraform apply to apply the execution plan and create all GCP resources.
terraform apply
Answer yes to the prompt to confirm you want to create GCP resources.
Apply complete! Resources: 5 added, 0 changed, 0 destroyed.
Install Postgres and the required dependencies on both the instances.
You can use the same playbook.yaml file used in the section,
Run the playbook using the ansible-playbook command:
ansible-playbook playbook.yaml -i /tmp/inventory
Answer yes when prompted for the SSH connection.
Deployment may take a few minutes.
PLAY [all] *****************************************************************************************************************************************************
TASK [Gathering Facts] *****************************************************************************************************************************************
The authenticity of host '34.123.220.201 (34.123.220.201)' can't be established.
ED25519 key fingerprint is SHA256:uovagzUgma1rzZ5k4vLu2XytOB7c8zxmqwaZnCCc1fo.
This key is not known by any other names
The authenticity of host '34.66.63.213 (34.66.63.213)' can't be established.
ED25519 key fingerprint is SHA256:QjI0vHnjqAI8ySD4JOzwnH6akD+UBpmHZiS0DV6xf7Q.
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
yes
ok: [34.123.220.201]
ok: [34.66.63.213]
TASK [Update the Machine & Install PostgreSQL] *****************************************************************************************************************
changed: [34.123.220.201]
changed: [34.66.63.213]
TASK [Update apt repo and cache on all Debian/Ubuntu boxes] ****************************************************************************************************
TASK [Install PostgreSQL packages] *****************************************************************************************************************************
TASK [Install Python pip] **************************************************************************************************************************************
changed: [34.66.63.213] => (item=python3-pip)
changed: [34.123.220.201] => (item=python3-pip)
TASK [Start and enable services] *******************************************************************************************************************************
ok: [34.66.63.213] => (item=postgresql)
ok: [34.123.220.201] => (item=postgresql)
TASK [Utility present] *****************************************************************************************************************************************
TASK [Replace postgresql configuration file to allow remote connection] ****************************************************************************************
changed: [34.66.63.213] => (item=listen_addresses = '*')
[WARNING]: Module remote_tmp /var/lib/postgresql/.ansible/tmp did not exist and was created with a mode of 0700, this may cause issues when running as another
user. To avoid this, create the remote_tmp dir with the correct permissions manually
changed: [34.123.220.201] => (item=listen_addresses = '*')
TASK [Allow trust connection for the db user] ******************************************************************************************************************
RUNNING HANDLER [restart postgres] *****************************************************************************************************************************
PLAY RECAP *****************************************************************************************************************************************************
34.123.220.201 : ok=10 changed=8 unreachable=0 failed=0 skipped=0 rescued=0 ignored=0
34.66.63.213 : ok=10 changed=8 unreachable=0 failed=0 skipped=0 rescued=0 ignored=0
Follow the instructions given in this documentation to connect to the database from local machine.
Follow the instructions given in this documentation to deploy Memcached as a cache for PostgreSQL using Python.
You have successfully deployed Memcached as a cache for PostgreSQL on a Google Cloud Arm based Instance.
Run terraform destroy to delete all resources created.
terraform destroy
