Deploy Memcached as a cache for MySQL on an AWS Arm based Instance
Deploy Memcached as a cache for MySQL on an Azure Arm based Instance
Deploy Memcached as a cache for MySQL on a Google Cloud Arm based Instance
Deploy Memcached as a cache for Postgres on an AWS Arm based Instance
Deploy Memcached as a cache for Postgres on an Azure Arm based Instance
Deploy Memcached as a cache for Postgres on a Google Cloud Arm based Instance
You can deploy Memcached as a cache for Postgres on Azure using Terraform and Ansible.
In this section, you will deploy Memcached as a cache for Postgres on an Azure instance.
If you are new to Terraform, you should look at Automate Azure instance creation using Terraform before starting this Learning Path.
You should have the prerequisite tools installed before starting the Learning Path.
Any computer which has the required tools installed can be used for this section. The computer can be your desktop or laptop computer or a virtual machine with the required tools.
You will need an Azure portal account to complete this Learning Path. Create an account if you don’t have one.
Before you begin, you will also need:
The instructions to login to the Azure CLI and create the keys are below.
The installation of Terraform on your Desktop/Laptop needs to communicate with Azure. Thus, Terraform needs to be authenticated.
For Azure authentication, follow this guide .
Generate an SSH key-pair (public key, private key) using ssh-keygen to use for Azure instance access. To generate the key-pair, follow this
guide
If you already have an SSH key-pair present in the ~/.ssh directory, you can skip this step.
For Azure Arm based instance deployment, the Terraform configuration is broken into three files: providers.tf, variables.tf and main.tf. Here we are creating 2 instances.
Add the following code in providers.tf file to configure Terraform to communicate with Azure.
terraform {
required_version = ">=0.12"
required_providers {
azurerm = {
source = "hashicorp/azurerm"
version = "~>2.0"
random = {
source = "hashicorp/random"
version = "~>3.0"
tls = {
source = "hashicorp/tls"
version = "~>4.0"
provider "azurerm" {
features {}
Create a variables.tf file for describing the variables referenced in the other files with their type and a default value.
variable "resource_group_location" {
default = "eastus2"
description = "Location of the resource group."
variable "resource_group_name_prefix" {
default = "rg"
description = "Prefix of the resource group name that's combined with a random ID so name is unique in your Azure subscription."
Add the resources required to create a virtual machine in main.tf.
resource "random_pet" "rg_name" {
prefix = var.resource_group_name_prefix
resource "azurerm_resource_group" "rg" {
location = var.resource_group_location
name = random_pet.rg_name.id
# Create virtual network
resource "azurerm_virtual_network" "my_terraform_network" {
name = "myVnet"
address_space = ["10.1.0.0/16"]
location = azurerm_resource_group.rg.location
resource_group_name = azurerm_resource_group.rg.name
# Create subnet
resource "azurerm_subnet" "my_terraform_subnet" {
name = "mySubnet"
virtual_network_name = azurerm_virtual_network.my_terraform_network.name
address_prefixes = ["10.1.1.0/24"]
# Create Public IPs
resource "azurerm_public_ip" "my_terraform_public_ip" {
name = "myPublicIP${format("%02d", count.index)}-test"
count = 2
allocation_method = "Dynamic"
# Create Network Security Group and rule
resource "azurerm_network_security_group" "my_terraform_nsg" {
name = "myNetworkSecurityGroup"
security_rule {
name = "SSH"
priority = 1001
direction = "Inbound"
access = "Allow"
protocol = "Tcp"
source_port_range = "*"
destination_port_range = "22"
source_address_prefix = "*"
destination_address_prefix = "*"
security_rule {
name = "PSQL"
priority = 1002
access = "Allow"
protocol = "Tcp"
destination_port_range = "5432"
# Create network interface
resource "azurerm_network_interface" "my_terraform_nic" {
count = 2
name = "NIC-${format("%02d", count.index)}-test"
ip_configuration {
name = "my_nic_configuration"
subnet_id = azurerm_subnet.my_terraform_subnet.id
private_ip_address_allocation = "Dynamic"
public_ip_address_id = azurerm_public_ip.my_terraform_public_ip.*.id[count.index]
# Connect the security group to the network interface
resource "azurerm_network_interface_security_group_association" "example" {
count = 2
network_interface_id = azurerm_network_interface.my_terraform_nic.*.id[count.index]
network_security_group_id = azurerm_network_security_group.my_terraform_nsg.id
# Generate random text for a unique storage account name
resource "random_id" "random_id" {
keepers = {
# Generate a new ID only when a new resource group is defined
resource_group = azurerm_resource_group.rg.name
byte_length = 8
# Create storage account for boot diagnostics
resource "azurerm_storage_account" "my_storage_account" {
name = "diag${random_id.random_id.hex}"
account_tier = "Standard"
account_replication_type = "LRS"
# Create virtual machine
resource "azurerm_linux_virtual_machine" "PSQL_TEST" {
name = "PSQL_TEST${format("%02d", count.index + 1)}"
count = 2
network_interface_ids = [azurerm_network_interface.my_terraform_nic.*.id[count.index]]
size = "Standard_D2ps_v5"
os_disk {
name = "myOsDisk${format("%02d", count.index + 1)}"
caching = "ReadWrite"
storage_account_type = "Premium_LRS"
source_image_reference {
publisher = "Canonical"
offer = "0001-com-ubuntu-server-focal"
sku = "20_04-lts-arm64"
version = "20.04.202209200"
computer_name = "myvm"
admin_username = "ubuntu"
disable_password_authentication = true
admin_ssh_key {
username = "ubuntu"
public_key = file("~/.ssh/id_rsa.pub")
boot_diagnostics {
storage_account_uri = azurerm_storage_account.my_storage_account.primary_blob_endpoint
resource "local_file" "inventory" {
depends_on = [azurerm_linux_virtual_machine.PSQL_TEST]
filename = "/tmp/inventory"
content = <<EOF
[db_master]
${azurerm_linux_virtual_machine.PSQL_TEST[0].public_ip_address}
${azurerm_linux_virtual_machine.PSQL_TEST[1].public_ip_address}
[all:vars]
ansible_connection=ssh
ansible_user=ubuntu
EOF
The inventory file is automatically generated and does not need to be changed.
Use Terraform to deploy the main.tf file.
Run terraform init to initialize the Terraform deployment. This command downloads the dependencies required for Azure.
terraform init
The output should be similar to:
Initializing the backend...
Initializing provider plugins...
- Reusing previous version of hashicorp/local from the dependency lock file
- Reusing previous version of hashicorp/tls from the dependency lock file
- Reusing previous version of hashicorp/azurerm from the dependency lock file
- Reusing previous version of hashicorp/random from the dependency lock file
- Using previously-installed hashicorp/local v2.4.0
- Using previously-installed hashicorp/tls v4.0.4
- Using previously-installed hashicorp/azurerm v2.99.0
- Using previously-installed hashicorp/random v3.4.3
Terraform has been successfully initialized!
You may now begin working with Terraform. Try running "terraform plan" to see
any changes that are required for your infrastructure. All Terraform commands
should now work.
If you ever set or change modules or backend configuration for Terraform,
rerun this command to reinitialize your working directory. If you forget, other
commands will detect it and remind you to do so if necessary.
Run terraform plan to create an execution plan.
terraform plan
A long output of resources to be created will be printed.
Run terraform apply to apply the execution plan and create all Azure resources.
terraform apply
Answer yes to the prompt to confirm you want to create Azure resources.
Apply complete! Resources: 16 added, 0 changed, 0 destroyed.
Install Postgres and the required dependencies on both the instances.
You can use the same playbook.yaml file used in the section,
Run the playbook using the ansible-playbook command:
ansible-playbook playbook.yaml -i /tmp/inventory
Answer yes when prompted for the SSH connection.
Deployment may take a few minutes.
PLAY [all] *****************************************************************************************************************************************************
TASK [Gathering Facts] *****************************************************************************************************************************************
The authenticity of host '20.122.0.160 (20.122.0.160)' can't be established.
ED25519 key fingerprint is SHA256:GhKxVqkbB/6iHm6oAWM0tI95xbUGZA/bPkcwAHPzfno.
This key is not known by any other names
The authenticity of host '20.119.220.61 (20.119.220.61)' can't be established.
ED25519 key fingerprint is SHA256:wOq1vChpoThK8ctVUm1TeK+k73nguA+NVv6gKBMgNxw.
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
yes
ok: [20.122.0.160]
ok: [20.119.220.61]
TASK [Update the Machine & Install PostgreSQL] *****************************************************************************************************************
changed: [20.119.220.61]
changed: [20.122.0.160]
TASK [Update apt repo and cache on all Debian/Ubuntu boxes] ****************************************************************************************************
TASK [Install PostgreSQL packages] *****************************************************************************************************************************
TASK [Install Python pip & Python package] *********************************************************************************************************************
changed: [20.119.220.61] => (item=python3-pip)
changed: [20.122.0.160] => (item=python3-pip)
TASK [Start and enable services] *******************************************************************************************************************************
ok: [20.122.0.160] => (item=postgresql)
ok: [20.119.220.61] => (item=postgresql)
TASK [Utility present] *****************************************************************************************************************************************
TASK [Replace postgresql configuration file to allow remote connection] ****************************************************************************************
changed: [20.119.220.61] => (item=listen_addresses = '*')
changed: [20.122.0.160] => (item=listen_addresses = '*')
[WARNING]: Module remote_tmp /var/lib/postgresql/.ansible/tmp did not exist and was created with a mode of 0700, this may cause issues when running as another
user. To avoid this, create the remote_tmp dir with the correct permissions manually
TASK [Allow trust connection for the db user] ******************************************************************************************************************
RUNNING HANDLER [restart postgres] *****************************************************************************************************************************
PLAY RECAP *****************************************************************************************************************************************************
20.119.220.61 : ok=10 changed=8 unreachable=0 failed=0 skipped=0 rescued=0 ignored=0
20.122.0.160 : ok=10 changed=8 unreachable=0 failed=0 skipped=0 rescued=0 ignored=0
Follow the instructions given in this documentation to connect to the database from local machine.
Follow the instructions given in this documentation to deploy Memcached as a cache for Postgres using Python.
You have successfully deployed Memcached as a cache for PostgreSQL on an Azure Arm based Instance.
Run terraform destroy to delete all resources created.
terraform destroy
Continue the Learning Path to deploy Memcached as a cache for Postgres on a GCP Arm based Instance.
