Deploy Memcached as a cache for MySQL on an AWS Arm based Instance
Deploy Memcached as a cache for MySQL on an Azure Arm based Instance
Deploy Memcached as a cache for MySQL on a Google Cloud Arm based Instance
Deploy Memcached as a cache for Postgres on an AWS Arm based Instance
Deploy Memcached as a cache for Postgres on an Azure Arm based Instance
Deploy Memcached as a cache for Postgres on a Google Cloud Arm based Instance
You can deploy Memcached as a cache for Postgres on an AWS Arm based Instance using Terraform and Ansible.
In this section, you will deploy Memcached as a cache for Postgres on an AWS Instance.
If you are new to Terraform, you should look at Automate AWS EC2 instance creation using Terraform before starting this Learning Path.
You should have the prerequisite tools installed before starting the Learning Path.
Any computer which has the required tools installed can be used for this section. The computer can be your desktop or laptop computer or a virtual machine with the required tools.
You will need an AWS account to complete this Learning Path. Create an account if you don’t have one.
Before you begin, you will also need:
The instructions to create the keys are below.
Generate an SSH key-pair (public key, private key) using ssh-keygen to use for AWS EC2 access. To generate the key-pair, follow this
guide
If you already have an SSH key-pair present in the ~/.ssh directory, you can skip this step.
The installation of Terraform on your desktop or laptop needs to communicate with AWS. Thus, Terraform needs to be able to authenticate with AWS.
To generate and configure the Access key ID and Secret access key, follow this guide .
Using a text editor, save the code below in a file called main.tf.
provider "aws" {
  region = "us-east-2"
resource "aws_instance" "PSQL_TEST" {
  count           = "2"
  ami             = "ami-0ca2eafa23bc3dd01"
  instance_type   = "t4g.small"
  security_groups = [aws_security_group.Terraformsecurity.name]
  key_name        = aws_key_pair.deployer.key_name
  tags = {
    Name = "PSQL_TEST"
resource "aws_default_vpc" "main" {
  tags = {
    Name = "main"
resource "aws_security_group" "Terraformsecurity" {
  name        = "Terraformsecurity"
  description = "Allow TLS inbound traffic"
  vpc_id      = aws_default_vpc.main.id
  ingress {
    description = "TLS from VPC"
    from_port   = 5432
    to_port     = 5432
    protocol    = "tcp"
    cidr_blocks = ["0.0.0.0/0"]
  ingress {
    from_port   = 22
    to_port     = 22
    protocol    = "tcp"
  egress {
    from_port   = 0
    to_port     = 0
    protocol    = "-1"
  tags = {
    Name = "Terraformsecurity"
output "Master_public_IP" {
  value = [aws_instance.PSQL_TEST[0].public_ip, aws_instance.PSQL_TEST[1].public_ip]
resource "aws_key_pair" "deployer" {
  key_name   = "id_rsa"
  public_key = file("~/.ssh/id_rsa.pub")
// Generate inventory file
resource "local_file" "inventory" {
  depends_on = [aws_instance.PSQL_TEST]
  filename   = "/tmp/inventory"
  content    = <<EOF
          [db_master]
          ${aws_instance.PSQL_TEST[0].public_ip}
          ${aws_instance.PSQL_TEST[1].public_ip}
          [all:vars]
          ansible_connection=ssh
          ansible_user=ubuntu
          EOF
Make the changes listed below in main.tf to match your account settings.
In the provider section, update value to use your preferred AWS region.
(optional) In the aws_instance section, change the ami value to your preferred Linux distribution. The AMI ID for Ubuntu 22.04 on Arm is ami-0ca2eafa23bc3dd01. No change is needed if you want to use Ubuntu AMI.
The instance type is t4g.small. This is an Arm-based instance and requires an Arm Linux distribution.
The inventory file is automatically generated and does not need to be changed.
Use Terraform to deploy the main.tf file.
Run terraform init to initialize the Terraform deployment. This command downloads the dependencies required for AWS.
terraform init
The output should be similar to:
        Initializing the backend...
Initializing provider plugins...
- Reusing previous version of hashicorp/local from the dependency lock file
- Reusing previous version of hashicorp/aws from the dependency lock file
- Using previously-installed hashicorp/local v2.3.0
- Using previously-installed hashicorp/aws v4.52.0
Terraform has been successfully initialized!
You may now begin working with Terraform. Try running "terraform plan" to see
any changes that are required for your infrastructure. All Terraform commands
should now work.
If you ever set or change modules or backend configuration for Terraform,
rerun this command to reinitialize your working directory. If you forget, other
commands will detect it and remind you to do so if necessary.
Run terraform plan to create an execution plan.
terraform plan
A long output of resources to be created will be printed.
Run terraform apply to apply the execution plan and create all AWS resources.
terraform apply
Answer yes to the prompt to confirm you want to create AWS resources.
The public IP address will be different, but the output should be similar to:
        Apply complete! Resources: 6 added, 0 changed, 0 destroyed.
Outputs:
Master_public_IP = [
  "3.133.99.23",
  "18.217.248.242",
Install Postgres and the required dependencies.
Using a text editor, save the code below in a file called playbook.yaml. This Playbook installs & enables Postgres in the instances.
- hosts: all
  become: yes
  tasks:
    - name: Update the Machine & Install PostgreSQL
      shell: |
             sudo sh -c 'echo "deb http://apt.postgresql.org/pub/repos/apt/ `lsb_release -cs`-pgdg main" >> /etc/apt/sources.list.d/pgdg.list'
             sudo wget -q https://www.postgresql.org/media/keys/ACCC4CF8.asc -O - | sudo apt-key add -
             sudo apt-get update
             sudo apt-get install postgresql -y
             sudo systemctl start postgresql
      become: true
    - name: Update apt repo and cache on all Debian/Ubuntu boxes
      apt:  upgrade=yes update_cache=yes force_apt_get=yes cache_valid_time=3600
      become: true
    - name: Install Python pip and PostgreSQL package
      apt: name={{ item }} update_cache=true state=present force_apt_get=yes
      with_items:
      - python3-pip
      - acl
      become: true
    - name: Start and enable services
      service: "name={{ item }} state=started enabled=yes"
      with_items:
      - postgresql
    - name: Utility present
      ansible.builtin.package:
        state: present
    - name: Replace postgresql configuration file to allow remote connection
      ansible.builtin.lineinfile:
         path: "/etc/postgresql/15/main/postgresql.conf"
         line: '{{ item }}'
         owner: postgres
         group: postgres
         mode: '0777'
      with_items:
          - "listen_addresses = '*'"
      become: yes
      become_user: postgres
    - name: Allow trust connection for the db user
      postgresql_pg_hba:
        dest: "/etc/postgresql/15/main/pg_hba.conf"
        contype: host
        databases: all
        method: trust
        address: 0.0.0.0/0
        users: "all"
        create: true
      become: yes
      notify: restart postgres
  handlers:
    - name: restart postgres
      service: name=postgresql state=restarted
Run the playbook using the ansible-playbook command:
ansible-playbook playbook.yaml -i /tmp/inventory
Answer yes when prompted for the SSH connection.
Deployment may take a few minutes.
        PLAY [all] **************************************************************************************************************************************************
TASK [Gathering Facts] **************************************************************************************************************************************
ok: [3.133.99.23]
ok: [18.217.248.242]
TASK [Update the Machine & Install PostgreSQL] **************************************************************************************************************
changed: [18.217.248.242]
changed: [3.133.99.23]
TASK [Update apt repo and cache on all Debian/Ubuntu boxes] *************************************************************************************************
ok: [3.133.99.23]
TASK [Install Python pip and PostgreSQL package] ***************************************************************************************************************
ok: [18.217.248.242] => (item=python3-pip)
ok: [3.133.99.23] => (item=python3-pip)
TASK [Start and enable services] ****************************************************************************************************************************
ok: [18.217.248.242] => (item=postgresql)
ok: [3.133.99.23] => (item=postgresql)
TASK [Utility present] **************************************************************************************************************************************
ok: [3.133.99.23]
TASK [Replace postgresql configuration file to allow remote connection] *************************************************************************************
changed: [3.133.99.23] => (item=listen_addresses = '*')
changed: [18.217.248.242] => (item=listen_addresses = '*')
TASK [Allow trust connection for the db user] ***************************************************************************************************************
ok: [3.133.99.23]
PLAY RECAP **************************************************************************************************************************************************
18.217.248.242             : ok=8    changed=2    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
3.133.99.23                : ok=8    changed=2    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
To connect to the database, you need the public-ip of the instance where Postgres is deployed. You also need to use the Postgres Client to interact with the PostgreSQL database.
apt install -y postgresql-client
psql -h {public_ip of instance where Postgres deployed} -U postgres
Replace {public_ip of instance where Postgres deployed} with your value.
The output will be:
        ubuntu@ip-172-31-38-39:~/psql$ psql -h 3.133.99.23 -U postgres
psql (14.7 (Ubuntu 14.7-0ubuntu0.22.04.1), server 15.2 (Ubuntu 15.2-1.pgdg22.04+1))
WARNING: psql major version 14, server major version 15.
         Some psql features might not work.
SSL connection (protocol: TLSv1.3, cipher: TLS_AES_256_GCM_SHA384, bits: 256, compression: off)
Type "help" for help.
postgres=#
create database {your_database};
\c {your_database};
The output will be:
        postgres=# create database arm_test1;
CREATE DATABASE
postgres=# \c arm_test1
You are now connected to database "arm_test1" as user "postgres".```
create table book(name char(10),id varchar(10));
insert into book(name,id) values ('Abook','10'),('Bbook','20'),('Cbook','20'),('Dbook','30'),('Ebook','45'),('Fbook','40'),('Gbook
','69');
The output will be:
        arm_test1=# create table book(name char(10),id varchar(10));
CREATE TABLE
arm_test1=# insert into book(name,id) values ('Abook','10'),('Bbook','20'),('Cbook','20'),('Dbook','30'),('Ebook','45'),('Fbook','40'),('Gbook
','69');
INSERT 0 7
select * from {{your_table_name}};
The output will be:
        arm_test1=# select * from book;
    name    | id
 Abook      | 10
 Bbook      | 20
 Cbook      | 20
 Dbook      | 30
 Ebook      | 45
 Fbook      | 40
 Gbook     +| 69
(7 rows)
The output will be:
        postgres=# create database arm_test2;
CREATE DATABASE
postgres=# \c arm_test2
You are now connected to database "arm_test2" as user "postgres".
arm_test2=# create table movie(name char(10),id varchar(10));
CREATE TABLE
arm_test2=# insert into movie(name,id) values ('Amovie','1'), ('Bmovie','2'), ('Cmovie','3'), ('Dmovie','4'), ('Emovie','5'), ('Fmovie','6'), ('Gmovie','7');
INSERT 0 7
arm_test2=# select * from movie;
    name    | id
 Amovie     | 1
 Bmovie     | 2
 Cmovie     | 3
 Dmovie     | 4
 Emovie     | 5
 Fmovie     | 6
 Gmovie     | 7
(7 rows)
You will create two .py files on the host machine to deploy Memcached as a PostgreSQL cache using Python: values.py and memcached.py.
values.py to store the IP addresses of the instances and the databases created in them.
PSQL_TEST=[["{{public_ip of PSQL_TEST[0]}}", "arm_test1"],
["{{public_ip of PSQL_TEST[1]}}", "arm_test2"]]
Replace {{public_ip of PSQL_TEST[0]}} & {{public_ip of PSQL_TEST[1]}} with the public IPs generated in the /tmp/inventory file after running the Terraform commands.
memcached.py to access data from Memcached and, if not present, store it in the Memcached.
import sys
import psycopg2
import pymemcache
from values import *
from ast import literal_eval
import argparse
parser = argparse.ArgumentParser()
parser.add_argument("-db", "--database", help="Database")
parser.add_argument("-k", "--key", help="Key")
parser.add_argument("-q", "--query", help="Query")
args = parser.parse_args()
memc = pymemcache.Client("127.0.0.1:11211");
for i in range(0,2):
    if (PSQL_TEST[i][1]==args.database):
        try:
            conn = psycopg2.connect (host = PSQL_TEST[i][0], dbname = PSQL_TEST[i][1], user="postgres")
        except psycopg2.OperationalError as e:
             print('Unable to connect!\n{0}').format(e)
             sys.exit (1)
        psqldata = memc.get(args.key)
        if not psqldata:
            cursor = conn.cursor()
            cursor.execute(args.query)
            rows = cursor.fetchall()
            memc.set(args.key,rows,120)
            print ("Updated memcached with PSQL data")
            for x in rows:
                print(x)
        else:
            print ("Loaded data from memcached")
            data = tuple(literal_eval(psqldata.decode("utf-8")))
            for row in data:
                print (row)
        break
else:
    print("this database doesn't exist")
Change the range in for loop according to the number of instances created.
To execute the script, run the following command:
python3 memcached.py -db {database_name} -k {key} -q {query}
Replace {database_name} with the database you want to access, {query} with the query you want to run in the database, and {key} with a variable to store the result of the query in Memcached.
When the script is executed for the first time, the data is loaded from the PostgreSQL database and stored on the Memcached server.
The output will be:
        ubuntu@ip-172-31-38-39:~/psql$ python3 memcached.py -db arm_test1 -k aa -q "select * from book limit 3"
('Abook     ', '10')
('Bbook     ', '20')
('Cbook     ', '20')
        ubuntu@ip-172-31-38-39:~/psql$ python3 memcached.py -db arm_test2 -k bb -q "select * from movie limit 3"
('Amovie    ', '1')
('Bmovie    ', '2')
('Cmovie    ', '3')
When executed after that, it loads the data from Memcached. In the example above, the information stored in Memcached is in the form of rows from a Python DB cursor. When accessing the information (within the 120-second expiry time), the data is loaded from Memcached and dumped.
The output will be:
('Abook     ', '10')
('Bbook     ', '20')
('Cbook     ', '20')
('Amovie    ', '1')
('Bmovie    ', '2')
('Cmovie    ', '3')
Execute the steps below to verify that the PostgreSQL query is getting stored in Memcached.
telnet localhost 11211
get <key>
NOTE:- Key is the variable in which we store the data. In the above command, we are storing the data from the tables book and movie in AA and BB respectively.
The output will be:
        ubuntu@ip-172-31-38-39:~/psql$ telnet localhost 11211
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
get aa
VALUE aa 0 66
[('Abook     ', '10'), ('Bbook     ', '20'), ('Cbook     ', '20')]
END
get bb
VALUE bb 0 63
[('Amovie    ', '1'), ('Bmovie    ', '2'), ('Cmovie    ', '3')]
END
telnet> close
You have successfully deployed Memcached as a cache for PostgreSQL on an AWS Arm based Instance.
Run terraform destroy to delete all resources created.
terraform destroy
Continue the Learning Path to deploy Memcached as a cache for Postgres on an Azure Arm based Instance.
