Deploy Longhorn storage for Kubernetes on Azure Arm VMs
Understand Longhorn on Azure Cobalt 100
Create an Arm64 Azure virtual machine powered by Azure Cobalt 100
Allow network access to the Longhorn Web UI on Azure
Install and run Longhorn on a single-node Kubernetes cluster
Validate and benchmark Longhorn storage with fio
Validate persistent storage
In this section, you’ll create a PersistentVolumeClaim (PVC), attach it to a Kubernetes workload, verify that data survives pod recreation, and run storage benchmarking tests using fio on the Longhorn-backed volume.
To validate persistent storage, follow these steps:
Create a PersistentVolumeClaim
Create a Kubernetes PVC using the Longhorn StorageClass:
cat > pvc.yaml <<EOF
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
accessModes:
- ReadWriteOnce
storageClassName: longhorn
resources:
requests:
storage: 5Gi
EOF
Apply the PVC configuration:
kubectl apply -f pvc.yaml
The PVC requests a 5 GiB Longhorn-backed volume that can be mounted by a single Kubernetes node in read-write mode.
Verify the PersistentVolumeClaim
Check that the PVC is successfully provisioned.
kubectl get pvc
The output is similar to:
NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS VOLUMEATTRIBUTESCLASS AGE
longhorn-pvc Bound pvc-14ab1c22-be1c-4706-b9bc-f5b228007814 5Gi RWO longhorn <unset> 7s
The Bound status confirms that Longhorn successfully created and attached the persistent volume.
Deploy a test NGINX application
Create an NGINX pod that mounts the Longhorn-backed PVC:
cat > nginx-longhorn.yaml <<EOF
apiVersion: v1
kind: Pod
metadata:
spec:
containers:
- name: nginx
image: nginx
volumeMounts:
- mountPath: "/usr/share/nginx/html"
volumes:
- name: longhorn-storage
persistentVolumeClaim:
claimName: longhorn-pvc
EOF
Deploy the pod:
kubectl apply -f nginx-longhorn.yaml
This pod mounts the Longhorn volume inside the NGINX container and allows Kubernetes workloads to store persistent application data.
Verify the NGINX application pod
Check that the NGINX pod is running successfully:
kubectl get pods
NAME READY STATUS RESTARTS AGE
nginx-longhorn 1/1 Running 0 31s
Write data to the persistent volume
Open a shell inside the running NGINX container:
kubectl exec -it nginx-longhorn -- bash
Write sample data to the mounted Longhorn volume:
echo "Longhorn Storage Working on Arm64" > /usr/share/nginx/html/index.html
Exit the container:
exit
You’ve now created a file directly on the Longhorn-backed persistent volume.
Check whether data persists after pod deletion
Delete the running pod:
kubectl delete pod nginx-longhorn
Recreate the pod:
Verify that the data still exists after the pod recreation:
kubectl exec -it nginx-longhorn -- cat /usr/share/nginx/html/index.html
This output confirms that the data persists independently of the Kubernetes pod lifecycle.
Run storage benchmark tests using fio
After confirming that Longhorn-backed persistent storage works, follow these steps to benchmark the Longhorn volume:
Create fio benchmark pod
Create a benchmarking pod that mounts the Longhorn volume and installs fio for storage testing:
cat > fio-pod.yaml <<EOF
apiVersion: v1
kind: Pod
metadata:
spec:
containers:
- name: fio
image: ubuntu
command: ["/bin/bash", "-c"]
args:
- apt update && apt install -y fio && sleep infinity
volumeMounts:
- mountPath: /data
volumes:
EOF
Deploy the benchmarking pod:
kubectl apply -f fio-pod.yaml
Wait until the pod becomes ready:
kubectl wait --for=condition=Ready pod/fio-test --timeout=300s
The fio pod will install the benchmarking utility and keep the container running for interactive testing.
Open fio container shell
Open a shell inside the fio container:
kubectl exec -it fio-test -- bash
Verify that fio is installed correctly:
which fio
If fio is not installed, install it manually:
apt update
apt install -y fio
Run fio storage benchmark
In the container, run a random write workload against the Longhorn-backed persistent volume:
fio --name=benchmark \
--directory=/data \
--rw=randwrite \
--bs=4k \
--size=1G \
--numjobs=2 \
--time_based \
--runtime=60 \
--group_reporting
This benchmark performs random write operations with 4 KB block sizes for 60 seconds and measures storage throughput, latency, and IOPS.
benchmark: Laying out IO file (1 file / 1024MiB)
Jobs: 2 (f=2): [w(2)][100.0%][eta 00m:00s]
benchmark: (groupid=0, jobs=2): err= 0: pid=3344: Tue May 26 04:06:33 2026
write: IOPS=40.5k, BW=158MiB/s (166MB/s)(10.0GiB/64649msec)
After the benchmark completes, exit the container shell:
exit
The benchmark shows that Longhorn volumes are functioning correctly on the VM.
What you’ve accomplished
You now have a working Longhorn-backed persistent volume running on Kubernetes with validated storage persistence and benchmarking results.
Next, you can extend this workflow to deploy persistent storage for your Kubernetes workloads on Arm-based compute.
