Build LlamaIndex RAG apps on Google Axion C4A
Learn about LlamaIndex and Google Cloud C4A for RAG applications
Configure Google Cloud firewall rules for LlamaIndex
Create a Google Cloud C4A virtual machine for LlamaIndex
Install LlamaIndex on a Google Axion C4A VM
Build and test a browser-based RAG application with LlamaIndex
Prepare the environment for a LlamaIndex RAG application
In this section, you’ll prepare a Google Cloud Axion Arm64 VM for running a browser-based RAG application using LlamaIndex.
You’ll install required system packages, including Python 3.11, as well as Ollama and LlamaIndex.
Update the virtual machine
Update all system packages:
sudo zypper refresh
sudo zypper update -y
This ensures your system is up to date before installing anything.
Install required packages
Install Python 3.11 and the build tools needed to compile Python packages with native extensions:
sudo zypper install -y \
git \
curl \
wget \
tar \
gzip \
gcc \
gcc-c++ \
make \
cmake \
sqlite3 \
python311 \
python311-pip \
python311-devel \
python311-setuptools \
python311-wheel
Verify Python is installed correctly:
python3.11 --version
The output is similar to:
Python 3.11.10
pip 22.3.1 from /usr/lib/python3.11/site-packages/pip (python 3.11)
Create project directory
Create a project directory and a Python virtual environment. The virtual environment isolates the Python packages for this project from your system packages:
mkdir -p ~/llamaindex-rag/data
cd ~/llamaindex-rag
Create and activate the Python virtual environment:
python3.11 -m venv rag-env
source rag-env/bin/activate
Upgrade pip to the latest version:
pip install --upgrade pip setuptools wheel
Install Ollama
Use the official Linux installer to install Ollama:
curl -fsSL https://ollama.com/install.sh | sh
Verify the Ollama version:
ollama -v
ollama version is 0.24.0
Check Ollama is running
When installed using the official script, Ollama registers itself as a systemd service and starts automatically. Verify it is running:
sudo systemctl status ollama
If the service is not running, start it:
sudo systemctl start ollama
Pull an LLM model
With Ollama running, pull the llama3.2:1b model. This is a lightweight 1-billion-parameter model suitable for local inference on a 16 GB VM:
ollama pull llama3.2:1b
Test that the model responds correctly:
ollama run llama3.2:1b "Explain RAG in one sentence."
Retrieval-Augmented Generation (RAG) is a technique that combines a retrieval step, which fetches relevant documents from a knowledge base, with a generation step, where a large language model uses those documents to produce a grounded, context-aware response.
Install LlamaIndex packages
Install the LlamaIndex core library along with the integrations needed for Ollama, Hugging Face embeddings, and ChromaDB. You’ll also install FastAPI and Uvicorn here because the browser-based application you’ll build in the next section uses them as the web server:
pip install llama-index
pip install llama-index-llms-ollama
pip install llama-index-embeddings-huggingface
pip install llama-index-vector-stores-chroma
pip install chromadb
pip install sentence-transformers
pip install fastapi
pip install uvicorn
You’ve now installed and configured LlamaIndex on a Google Cloud C4A Arm64 VM running SUSE Linux with Python 3.11. You configured Ollama for local LLM inference and prepared the environment for building browser-based RAG applications using LlamaIndex and ChromaDB.
Next, you’ll build the RAG engine, create the browser UI, and query custom documents using a local large language model.
