Overview
Explore llama.cpp architecture and the inference workflow
Integrate Streamline Annotations into llama.cpp
Analyze token generation performance with Streamline profiling
Implement operator-level performance analysis with Annotation Channels
Examine multi-threaded performance patterns in llama.cpp
You can use Streamline Annotation Channels to analyze the execution time of each node in the compute graph, which is especially valuable for understanding and optimizing performance on Arm-based systems. Annotation Channels are specialized annotations that group related operations into separate visual channels in Streamline. Unlike simple markers, channels allow you to track multiple concurrent operations and see their relationships over time.
More details on Annotation Channels can be found in the Group and Channel annotations section of the Streamline User Guide.
In llama.cpp, tensor nodes are executed in the CPU backend inside the function ggml_graph_compute_thread() in the file ~/llama.cpp/ggml/src/ggml-cpu/ggml-cpu.c.
In the selected release tag, the loop over tensor nodes looks like this (around line 2862):
for (int node_n = 0; node_n < cgraph->n_nodes && atomic_load_explicit(&tp->abort, memory_order_relaxed) != node_n; node_n++) {
struct ggml_tensor * node = cgraph->nodes[node_n];
ggml_compute_forward(¶ms, node);
To monitor operator execution time, you can create annotation channels for each type of operators such as GGML_OP_MUL_MAT, GGML_OP_SOFTMAX, GGML_OP_ROPE, and GGML_OP_MUL. Matrix operations (GGML_OP_MUL_MAT) take a significant portion of execution time. These operations include both GEMM (General Matrix Multiply) and GEMV (General Matrix-Vector multiply) operations. You’ll create two dedicated annotation channels for GEMM and GEMV respectively to analyze their performance separately. The annotation starts at the beginning of ggml_compute_forward() and stops at the end. This approach allows you to monitor the computation time of each tensor node/operator.
First, add the Streamline annotation header file to ggml-cpu.c:
#include "streamline_annotate.h"
Edit the ggml_graph_compute_thread() function in the file ~/llama.cpp/ggml/src/ggml-cpu/ggml-cpu.c.
Add the following code in front and after the ggml_compute_forward(¶ms, node).
Your code now looks like:
// +++ Start Annotation Channel for Streamline
char printf_buf[256];
sprintf(printf_buf," %s, %s", node->name, ggml_get_name(node));
if(node->op==GGML_OP_MUL_MAT ) {
if (node->src[1]->ne[1] == 1)
ANNOTATE_CHANNEL(0, printf_buf); //It is GEMV
else
ANNOTATE_CHANNEL(1, printf_buf); //It is GEMM
else
ANNOTATE_CHANNEL((node->op)+2, printf_buf);
// --- Start Annotation Channel for Streamline
// +++ End Annotation Channel for Streamline
if(node->op==GGML_OP_MUL_MAT) {
ANNOTATE_CHANNEL_END(0);
else
ANNOTATE_CHANNEL_END(1);
else
ANNOTATE_CHANNEL_END((node->op)+2);
// --- End Annotation Channel for Streamline
You can also add information about the shape and size of source tensors by replacing the sprintf function as follows:
sprintf(printf_buf,"%s %s %d_%d_%d %d_%d_%d", node->name, ggml_get_name(node), \
node->src[0]? node->src[0]->ne[0] : 0, \
node->src[0]? node->src[0]->ne[1] : 0 , \
node->src[0]? node->src[0]->ne[2] : 0 ,\
node->src[1]? node->src[1]->ne[0] : 0, \
node->src[1]? node->src[1]->ne[1] : 0, \
node->src[1]? node->src[1]->ne[2] : 0 \
Edit ~/llama.cpp/ggml/src/ggml-cpu/CMakeLists.txt to include the Streamline Annotation header file and libstreamline_annotate.a library by adding these lines:
set(STREAMLINE_LIB_PATH "${CMAKE_SOURCE_DIR}/streamline_annotation/libstreamline_annotate.a")
target_include_directories( ${GGML_CPU_NAME} PRIVATE "${CMAKE_SOURCE_DIR}/streamline_annotation")
target_link_libraries(${GGML_CPU_NAME} PRIVATE ${STREAMLINE_LIB_PATH} )
Then, build llama-cli again.
Run llama-cli and collect profiling data with Streamline as you did in the previous section.
Arm Streamline displays string annotations as text overlays in the relevant channels in the Timeline view, such as Channel 0, as shown in the following screenshot.
Annotation channel
The letter A is displayed in the process list to indicate the presence of annotations.
String annotations are also displayed in the Message column in the Log view.
Annotation log
The screenshot of annotation channel view at prefill stage is shown as below:
Annotation channel at Prefill stage
The operator name in the screenshot above is manually edited. If you want the operator name to be shown instead of the Channel number by Streamline, you can add ANNOTATE_NAME_CHANNEL to the ggml_graph_compute_thread function.
This annotation macro is defined as:
ANNOTATE_NAME_CHANNEL(channel, group, string)
For example:
ANNOTATE_NAME_CHANNEL(0, 0, "MUL_MAT_GEMV");
ANNOTATE_NAME_CHANNEL(1, 0, "MUL_MAT_GEMM");
The code above sets the name of annotation channel 0 as MUL_MAT_GEMV and channel 1 as MUL_MAT_GEMM.
Zoom into the timeline view to examine additional details:
When moving the cursor over an annotation channel, Streamline shows:
Annotation channel zoom in
The example above shows a GGML_OP_MUL_MAT operator for the FFN_UP node.
The source tensors have shapes [1024, 2816] and [1024, 68].
This view makes it clear that:
MUL_MAT GEMM operations in the attention and FFN layers.MUL_MAT GEMV operation in the result_output linear layer.The annotation channel view for the Decode stage is shown below:
Annotation channel at Decode stage
Zooming in provides additional details:
Annotation channel string
This view reveals that the majority of time in Decode is spent on MUL_MAT GEMV operations within the attention and FFN layers. Unlike the Prefill stage, no GEMM operations are executed in these layers during Decode. The result_output linear layer contains a large GEMV operation that takes an even larger proportion of runtime in Decode compared to Prefill. This pattern is expected since each token generation at Decode is shorter due to KV cache reuse, making the result_output layer more dominant in the overall execution profile.
You have successfully implemented Annotation Channels to analyze individual operators within llama.cpp. This detailed view reveals how different operators contribute to overall execution time and shows the stark differences between Prefill (GEMM-dominated) and Decode (GEMV-dominated) stages. The next section will explore how these operations utilize multiple CPU cores and threads.
