Set up performance marker annotations
To visualize token generation at the Prefill and Decode stages, you can use Streamline’s marker annotation feature.
Note
Marker annotations are code markers that you insert into your application to identify specific events or time periods during execution. When Streamline captures performance data, these annotations appear in the timeline, making it easier to correlate performance data with specific application behavior.
This requires integrating annotation support into the llama.cpp project. More information about the marker annotation API can be found in the Streamline User Guide .
Note
You can either build natively on an Arm platform, or cross-compile on another architecture using an Arm cross-compiler toolchain.
Build the Streamline annotation library
Download and install Arm Performance Studio on your development machine.
Note
You can also download and install Arm Development Studio , as it also includes Streamline.
Streamline Annotation support code is located in the Arm Performance Studio installation directory under streamline/gator/annotate.
Clone the gator repository that matches your Streamline version and build the Annotation support library. You can build it natively on your current machine or cross-compile it for another Arm computer.
If you need to set up a cross-compiler, you can review the GCC install guide .
    sudo apt-get update
    sudo apt-get install -y ninja-build cmake gcc g++ g++-aarch64-linux-gnu curl zip unzip tar pkg-config git
    cd ~
    git clone https://github.com/ARM-software/gator.git
    cd gator
    ./build-linux.sh
    cd annotate
    make
    sudo apt-get update
    sudo apt-get install ninja-build cmake gcc g++ g++-aarch64-linux-gnu curl zip unzip tar pkg-config git
    cd ~
    cd gator
    make CROSS_COMPILE=/path/to/aarch64_linux_gcc_tool
Once complete, the static library libstreamline_annotate.a will be generated at ~/gator/annotate/libstreamline_annotate.a and the header file is at gator/annotate/streamline_annotate.h.
Integrate marker annotations into llama.cpp
Next, you need to install llama.cpp to run the LLM model.
Note
To make the performance profiling content easier to follow, this Learning Path uses a specific release version of llama.cpp to ensure the steps and results remain consistent.
Before building llama.cpp, create a directory streamline_annotation and copy the library libstreamline_annotate.a and the header file streamline_annotate.h into the new directory:
cd ~
wget https://github.com/ggml-org/llama.cpp/archive/refs/tags/b6202.tar.gz
tar -xvzf b6202.tar.gz
mv llama.cpp-b6202 llama.cpp
cd ./llama.cpp
mkdir streamline_annotation
cp ~/gator/annotate/libstreamline_annotate.a ~/gator/annotate/streamline_annotate.h streamline_annotation
To link the libstreamline_annotate.a library when building llama-cli, use an editor to add the following lines at the end of llama.cpp/tools/main/CMakeLists.txt:
set(STREAMLINE_LIB_PATH "${CMAKE_SOURCE_DIR}/streamline_annotation/libstreamline_annotate.a")
target_include_directories(llama-cli PRIVATE "${CMAKE_SOURCE_DIR}/streamline_annotation")
target_link_libraries(llama-cli PRIVATE "${STREAMLINE_LIB_PATH}")
To add marker annotations to llama-cli, edit the file llama.cpp/tools/main/main.cpp and make three modifications.
First, add the include file at the top of main.cpp with the other include files:
#include "streamline_annotate.h"
Next, the find the common_init() call in the main() function and add the Streamline setup macro below it so that the code looks like this:
    common_init();
    //Add the Annotation setup code
    ANNOTATE_SETUP;
Finally, add a marker annotation inside the main loop. Add the complete code instead of the annotation comments so it looks like:
          for (int i = 0; i < (int) embd.size(); i += params.n_batch) {
                int n_eval = (int) embd.size() - i;
                if (n_eval > params.n_batch) {
                    n_eval = params.n_batch;
                LOG_DBG("eval: %s\n", string_from(ctx, embd).c_str());
                // Add marker annotation code for Streamline
                  char printf_buf[200];
                  sprintf(printf_buf, "past %d, n_eval %d", n_past,n_eval );
                  ANNOTATE_MARKER_STR(printf_buf);
                // End of marker annotation
                if (llama_decode(ctx, llama_batch_get_one(&embd[i], n_eval))) {
                    LOG_ERR("%s : failed to eval\n", __func__);
                    return 1;
A string is added to the marker annotation to record the position of input tokens and the number of tokens to be processed.
Compile llama-cli with annotation support
For convenience, llama-cli is statically linked.
Create a new directory build under the llama.cpp root directory and change to the new directory:
cd ~/llama.cpp
mkdir build && cd build
Next, configure the project:
    cmake .. \
      -DGGML_NATIVE=ON \
      -DLLAMA_F16C=OFF \
      -DLLAMA_GEMM_ARM=ON \
      -DBUILD_SHARED_LIBS=OFF \
      -DCMAKE_EXE_LINKER_FLAGS="-static -g" \
      -DGGML_OPENMP=OFF \
      -DCMAKE_C_FLAGS="-march=native -g" \
      -DCMAKE_CXX_FLAGS="-march=native -g" \
      -DGGML_CPU_KLEIDIAI=ON \
      -DLLAMA_BUILD_TESTS=OFF \
      -DLLAMA_BUILD_EXAMPLES=ON \
      -DLLAMA_CURL=OFF
    cmake .. \
      -DCMAKE_SYSTEM_NAME=Linux \
      -DCMAKE_SYSTEM_PROCESSOR=arm \
      -DCMAKE_C_COMPILER=aarch64-linux-gnu-gcc \
      -DCMAKE_CXX_COMPILER=aarch64-linux-gnu-g++ \
      -DLLAMA_NATIVE=OFF \
      -DLLAMA_F16C=OFF \
      -DGGML_OPENMP=OFF \
      -DCMAKE_C_FLAGS="-march=armv8.2-a+dotprod+i8mm -g" \
      -DCMAKE_CXX_FLAGS="-march=armv8.2-a+dotprod+i8mm -g" \
      -DLLAMA_CURL=OFF
Set CMAKE_C_COMPILER and CMAKE_CXX_COMPILER to your cross compiler path. Make sure that -march in CMAKE_C_FLAGS and CMAKE_CXX_FLAGS matches your Arm CPU hardware.
With the flags above you can run llama-cli on an Arm CPU that supports Neon dot product and 8-bit integer multiply (i8mm) instructions.
The -static and -g options are also specified to produce a statically linked executable, so it can run on different Arm64 Linux/Android environments without needing shared libraries and to include debug information, which makes source code and function-level profiling in Streamline much easier.
Now you can build the project using cmake:
cd ~/llama.cpp/build
cmake --build ./ --config Release -j $(nproc)
After the building process completes, you can find the llama-cli in the ~/llama.cpp/build/bin/ directory.
You have successfully integrated Streamline annotations into llama.cpp and built an annotated version of llama-cli. The marker annotations you added will help identify token generation events during profiling. In the next section, you’ll use this instrumented executable to capture performance data with Streamline and analyze the distinct characteristics between Prefill and Decode stages during LLM inference.
