Deploy a PyTorch vision chatbot on Google Axion
Overview
This Learning Path demonstrates how to build and deploy a vision-enabled chatbot using open-source large language models (LLMs) optimized for Arm-based servers.
Vision chatbots accept both images and text as input, then generate text responses using the image as context. The instructions in this Learning Path are tailored for Arm servers running Ubuntu 24.04 LTS and have been tested on a Google Cloud c4a-standard-64 instance. You will need an Arm server instance with at least 32 CPU cores to run this example.
You’ll learn how to run a vision chatbot LLM inference using PyTorch and Hugging Face Transformers, efficiently leveraging Arm CPUs to process image-and-text input and produce relevant, contextual replies.
Install dependencies
Install the following packages on your Arm-based server instance:
sudo apt update
sudo apt install python3-pip python3-venv -y
Create a file with your Python dependencies
Using your preferred text editor, add the following Python dependencies to your requirements.txt file:
streamlit
numpy
sentencepiece
pillow
flask
transformers
huggingface_hub
Install Python dependencies
Now create a Python virtual environment and install the dependencies.
Create a virtual environment:
python3 -m venv llama-vision
Activate the virtual environment:
source llama-vision/bin/activate
Install the required libraries using pip:
pip install -r requirements.txt
Install PyTorch
Install the PyTorch package, which includes the Kleidi AI optimizations from the nightly build, using the following command:
pip install torch==2.15.0.dev20260929+cpu --extra-index-url https://download.pytorch.org/whl/nightly/cpu/
If the specified PyTorch version fails to install, try installing any PyTorch nightly build from
PyTorch Nightly Builds
released after version 2.15.0.dev20260929+cpu. Upon failure, pip should display a list of available versions. If one is available, select a version newer than 2.15.0.dev20260929+cpu from that list and retry the installation command with the selected version.
Install Torch AO
Clone the Torch AO repository:
git clone https://github.com/pytorch/ao.git
cd ao
Checkout the required branch:
git checkout 24c966cb8931507ef389715bc5f19a11c28b0484
Install Torch AO:
python setup.py install
cd ..
Hugging Face Cli Login
To use the Llama-3.2-11B-Vision-Instruct model from Hugging Face, you need to request access or accept the terms. You need to log in to Hugging Face using a token.
hf auth login
Enter your Hugging Face token. You can generate a token from Hugging Face Hub by clicking your profile on the top right corner and selecting Access Tokens.
You must also visit the Hugging Face link printed in the login output and accept the terms by clicking the Agree and access repository button or filling out the request-for-access form, depending on the model.
