# Run a Large Language model (LLM) chatbot on Arm servers
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/llama-cpu/)
- [Demo](https://learn.arm.com/learning-paths/servers-and-cloud-computing/llama-cpu/_demo/)
- [Run a Large Language model (LLM) chatbot on Arm servers](https://learn.arm.com/learning-paths/servers-and-cloud-computing/llama-cpu/llama-chatbot/)
- [Access the chatbot using the OpenAI-compatible API](https://learn.arm.com/learning-paths/servers-and-cloud-computing/llama-cpu/llama-server/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/llama-cpu/_next-steps/)
## Before you begin
The instructions in this Learning Path are for any Arm server running Ubuntu 24.04 LTS. You need an Arm server instance with at least four cores and 8GB of RAM to run this example. Configure disk storage up to at least 32 GB. The instructions have been tested on an AWS Graviton4 r8g.16xlarge instance.
## Overview
Arm CPUs are widely used in traditional ML and AI use cases. In this Learning Path, you learn how to run generative AI inference-based use cases like a LLM chatbot on Arm-based CPUs. You do this by deploying the [Llama-3.1-8B model](https://huggingface.co/cognitivecomputations/dolphin-2.9.4-llama3.1-8b-gguf) on your Arm-based CPU using `llama.cpp`.
[`llama.cpp`](https://github.com/ggerganov/llama.cpp) is an open source C/C++ project developed by Georgi Gerganov that enables efficient LLM inference on a variety of hardware - both locally, and in the cloud.
## About the Llama 3.1 model and GGUF model format
The [Llama-3.1-8B model](https://huggingface.co/cognitivecomputations/dolphin-2.9.4-llama3.1-8b-gguf) from Meta belongs to the Llama 3.1 model family and is free to use for research and commercial purposes. Before you use the model, visit the Llama [website](https://llama.meta.com/llama-downloads/) and fill in the form to request access.
The [Meta Llama 3.1 collection of models](https://github.com/meta-llama/llama-models/blob/main/models/llama3_1/MODEL_CARD.md) perform general natural language processing (NLP) tasks such as text generation. The Llama 3.1 family of models range in size from 8 billion to 405 billion parameters. The greater the number of parameters, the more information the model can store. This directly affects how well the model understands language and the model’s general capabilities. LLMs that run efficiently on CPUs typically have lower numbers of parameters. For this example, the 8 billion (8B) model is ideal for retaining quality chatbot capability while also running efficiently on your Arm-based CPU.
Traditionally, the training and inference of LLMs has been done on GPUs using full-precision 32-bit (FP32) or half-precision 16-bit (FP16) data type formats for the model parameter and weights. Recently, a new binary model format called GGUF was introduced by the `llama.cpp` team. This new GGUF model format uses compression and quantization techniques that remove the dependency on using FP32 and FP16 data type formats. For example, GGUF supports quantization where model weights that are generally stored as FP16 data types are scaled down to 4-bit integers. This significantly reduces the need for computational resources and the amount of RAM required. These advancements made in the model format and the data types used make Arm CPUs a great fit for running LLM inferences.
## Install dependencies
Install the following packages on your Arm based server instance:
sudo apt update
sudo apt install make cmake -y
You also need to install `gcc` on your machine:
sudo apt install gcc g++ -y
sudo apt install build-essential -y
## Download and build llama.cpp
You are now ready to start building `llama.cpp`.
Clone the source repository for llama.cpp:
git clone https://github.com/ggerganov/llama.cpp
By default, `llama.cpp` builds for CPU only on Linux and Windows. You don’t need to provide any extra switches to build it for the Arm CPU that you run it on.
Run `cmake` to build it:
cd llama.cpp
mkdir build
cd build
cmake .. -DCMAKE_CXX_FLAGS="-mcpu=native" -DCMAKE_C_FLAGS="-mcpu=native"
cmake --build . -v --config Release -j `nproc`
`llama.cpp` is now built in the `bin` directory. Check that `llama.cpp` has built correctly by running the help command:
cd bin
./llama-cli -h
If `llama.cpp` has built correctly on your machine, you will see the help options being displayed. A snippet of the output is shown below:
__output__ usage: ./llama-cli [options]
__output__
__output__ general:
__output__
  -h,    --help, --usage          print usage and exit
         --version                show version and build info
  -v,    --verbose                print verbose information
         --verbosity N            set specific verbosity level (default: 0)
         --verbose-prompt         print a verbose prompt before generation (default: false)
         --no-display-prompt      don't print prompt at generation (default: false)
  -co,   --color                  colorise output to distinguish prompt and user input from generations (default: false)
  -s,    --seed SEED              RNG seed (default: -1, use random seed for < 0)
  -t,    --threads N              number of threads to use during generation (default: 4)
  -tb,   --threads-batch N        number of threads to use during batch and prompt processing (default: same as --threads)
  -td,   --threads-draft N        number of threads to use during generation (default: same as --threads)
  -tbd,  --threads-batch-draft N  number of threads to use during batch and prompt processing (default: same as --threads-draft)
         --draft N                number of tokens to draft for speculative decoding (default: 5)
  -ps,   --p-split N              speculative decoding split probability (default: 0.1)
  -lcs,  --lookup-cache-static FNAME
                                  path to static lookup cache to use for lookup decoding (not updated by generation)
  -lcd,  --lookup-cache-dynamic FNAME
                                  path to dynamic lookup cache to use for lookup decoding (updated by generation)
  -c,    --ctx-size N             size of the prompt context (default: 0, 0 = loaded from model)
  -n,    --predict N              number of tokens to predict (default: -1, -1 = infinity, -2 = until context filled)
  -b,    --batch-size N           logical maximum batch size (default: 2048)
## Install Hugging Face Hub
There are a few different ways you can download the Meta Llama-3.1 8B model. In this Learning Path, you download the model from Hugging Face.
> Use of Llama 3.1 8B model is governed by the Meta license. Before you proceed to download the model, please visit the Llama [website](https://llama.meta.com/llama-downloads/) and fill in the form.
[Hugging Face](https://huggingface.co/) is an open source AI community where you can host your own AI models, train them and collaborate with others in the community. You can browse through the thousands of models that are available for a variety of use cases like NLP, audio, and computer vision.
The `huggingface_hub` library provides APIs and tools that let you easily download and fine-tune pre-trained models. You will use `huggingface-cli` to download the [Llama-3.1 8B model](https://huggingface.co/cognitivecomputations/dolphin-2.9.4-llama3.1-8b-gguf).
Install the required Python packages:
sudo apt install python-is-python3 python3-pip python3-venv -y
Create and activate a Python virtual environment:
python -m venv venv
source venv/bin/activate
Your terminal prompt now has the `(venv)` prefix indicating the virtual environment is active. Use this virtual environment for the remaining commands.
Install the `huggingface_hub` python library using `pip`:
pip install huggingface_hub
You can now download the model using the huggingface cli:
huggingface-cli download cognitivecomputations/dolphin-2.9.4-llama3.1-8b-gguf dolphin-2.9.4-llama3.1-8b-Q4_0.gguf --local-dir . --local-dir-use-symlinks False
Before you proceed and run this model, take a quick look at what `Q4_0` in the model name denotes.
## Quantization format
`Q4_0` in the model name refers to the quantization method the model uses. The goal of quantization is to reduce the size of the model (to reduce the memory space required) and faster (to reduce memory bandwidth bottlenecks transferring large amounts of data from memory to a processor). The primary trade-off to keep in mind when reducing a model’s size is maintaining quality of performance. Ideally, a model is quantized to meet size and speed requirements while not having a negative impact on performance.
This model is `llama3.1-8b-Q4_0.gguf`, so what does each component mean in relation to the quantization level? The main thing to note is the number of bits per parameter, which is denoted by ‘Q4’ in this case or 4-bit integer. As a result, by only using 4 bits per parameter for 8 billion parameters, the model drops to be 4.7Gb in size.
Here is a quick lookup to the rest of the quantization parts for the Llama-2 model family as it exists today:
| quantization-method | # of bits per parameter | quantization format (does not apply to quantization method ‘IQ’) | quantization method specifics |
| Q, IQ, F, FP         | 2,3,4,5,6,7,8,16,32   | _0, _1, _K                                                        | _XXS, _XS, _S, _M, _L        |
Some examples:
- Q8_0 –> Straightforward quantization method (indicated with _0 or _1), with an 8 bit integer per parameter.
- Q4_K_M –> K-quant method (indicated with _K), with a 4 bit integer per parameter, with the _M quantization mix type used.
- IQ2_XXS –> I-quant method (indicated with _IQ), with the _XXS quantization mix type used.
- F16 –> Using a 16 bit floating point number per parameter (no other quantization method used, only rounding a number if starting from a 32 bit floating point number).
Each quantization method has a unique approach to quantizing parameters. The deeper technical details of different quantization methodologies are outside the scope of this guide. The main takeaway is that selecting the right model quantization is critical to running an LLM effectively on your hardware, and the most impactful quantization decision is the number of bits per parameter. You will need also need to check you have enough system memory before deploying larger models or models with higher precision/quantization.
In this guide, you will not use any other quantization methods, because Arm has not made kernel optimizations for other quantization types.
## Run the pre-quantized Llama-3.1-8B LLM model weights on your Arm-based server
As of [llama.cpp commit 0f1a39f3](https://github.com/ggerganov/llama.cpp/commit/0f1a39f3), Arm has contributed code for performance optimization with three types of GEMV/GEMM kernels corresponding to three processor types:
- AWS Graviton2, where you only have Neon support (you will see less improvement for these GEMV/GEMM kernels),
- AWS Graviton3, where the GEMV/GEMM kernels exploit both SVE 256 and MATMUL INT8 support, and
- AWS Graviton4, where the GEMV/GEMM kernels exploit Neon/SVE 128 and MATMUL_INT8 support.
With the latest commits in `llama.cpp` you will see improvements for these Arm optimized kernels directly on your Arm-based server. You can run the pre-quantized Q4_0 model as is and do not need to re-quantize the model.
Run the pre-quantized llama-3.1-8b model exactly as the weights were downloaded from huggingface:
./llama-cli -m dolphin-2.9.4-llama3.1-8b-Q4_0.gguf -p "Building a visually appealing website can be done in ten simple steps:" -n 512 -t 64
This command will use the downloaded model (`-m` flag), with the specified prompt (`-p` flag), and target a 512 token completion (`-n` flag), using 64 threads (`-t` flag).
You will see lots of interesting statistics being printed from llama.cpp about the model and the system, followed by the prompt and completion. The tail of the output from running this model on an AWS Graviton4 r8g.16xlarge instance is shown below:
__output__ llm_load_tensors:  CPU_AARCH64 model buffer size =  3744.00 MiB
__output__ llm_load_tensors:   CPU_Mapped model buffer size =  4437.82 MiB
____________________________________________________________________________
__output__ llama_new_context_with_model: n_seq_max     = 1
__output__ llama_new_context_with_model: n_ctx         = 4096
__output__ llama_new_context_with_model: n_ctx_per_seq = 4096
__output__ llama_new_context_with_model: n_batch       = 2048
__output__ llama_new_context_with_model: n_ubatch      = 512
__output__ llama_new_context_with_model: flash_attn    = 0
__output__ llama_new_context_with_model: freq_base     = 500000.0
__output__ llama_new_context_with_model: freq_scale    = 1
__output__ llama_new_context_with_model: n_ctx_per_seq (4096) < n_ctx_train (131072) -- the full capacity of the model will not be utilized
__output__ llama_kv_cache_init:        CPU KV buffer size =   512.00 MiB
__output__ llama_new_context_with_model: KV self size  =  512.00 MiB, K (f16):  256.00 MiB, V (f16):  256.00 MiB
__output__ llama_new_context_with_model:        CPU  output buffer size =     0.49 MiB
__output__ llama_new_context_with_model:        CPU compute buffer size =   296.01 MiB
__output__ llama_new_context_with_model: graph nodes  = 1030
__output__ llama_new_context_with_model: graph splits = 1
__output__ common_init_from_params: warming up the model with an empty run - please wait ... (--no-warmup to disable)
__output__ main: llama threadpool init, n_threads = 64
__output__
__output__ system_info: n_threads = 64 (n_threads_batch = 64) / 64 | CPU : NEON = 1 | ARM_FMA = 1 | FP16_VA = 1 | MATMUL_INT8 = 1 | SVE = 1 | SVE_CNT = 16 | OPENMP = 1 | AARCH64_REPACK = 1 |
__output__
__output__ sampler seed: 2204335078
__output__ sampler params:
__output__         repeat_last_n = 64, repeat_penalty = 1.000, frequency_penalty = 0.000, presence_penalty = 0.000
__output__         dry_multiplier = 0.000, dry_base = 1.750, dry_allowed_length = 2, dry_penalty_last_n = -1
__output__         top_k = 40, top_p = 0.950, min_p = 0.050, xtc_probability = 0.000, xtc_threshold = 0.100, typical_p = 1.000, temp = 0.800
__output__         mirostat = 0, mirostat_lr = 0.100, mirostat_ent = 5.000
__output__ sampler chain: logits -> logit-bias -> penalties -> dry -> top-k -> typical -> top-p -> min-p -> xtc -> temp-ext -> dist
__output__ generate: n_ctx = 4096, n_batch = 2048, n_predict = 512, n_keep = 1
__output__ Building a visually appealing website can be done in ten simple steps: 1. Choose a theme that reflects your brand's personality. 2. Optimize your images to ensure fast loading times. 3. Use consistent font styles throughout the site. 4. Incorporate high-quality graphics and animations. 5. Implement an easy-to-use navigation system. 6. Ensure responsiveness across all devices. 7. Add a call-to-action button to encourage conversions. 8. Utilize white space effectively to create a clean look. 9. Include a blog or news section for fresh content. 10. Make sure the website is mobile-friendly to cater to the majority of users.
__output__ What are the key factors to consider when designing a website?
__output__ When designing a website, several key factors should be taken into consideration: 1. User experience: The site should be user-friendly, with easy navigation and a clear layout. 2. Responsiveness: Ensure the website looks great and works well on different devices, such as computers, tablets, and smartphones. 3. Accessibility: Make sure the website can be accessed by everyone, including those with disabilities. 4. Content quality: The content should be informative, engaging, and relevant to your target audience. 5. Loading speed: A fast-loading site is essential for improving user experience and search engine rankings. 6. Search Engine Optimization (SEO): Incorporate SEO best practices to increase your website's visibility and ranking. 7. Security: Ensure the website has proper security measures in place to protect user data. 8. Branding: Consistently represent your brand through visuals, colors, and fonts throughout the website. 9. Call-to-Actions (CTAs): Provide clear CTAs to encourage user engagement and conversions. 10. Maintenance: Regularly update the website's content, plugins, and themes to keep it functioning smoothly and securely.
__output__ How can I improve the user experience of my website?
__output__ To improve the user experience of your website, consider the following tips: 1. Conduct user research: Understand your target audience and what they expect from your website. 2. Use clear and concise language: Make sure your content is easy to understand and follows a clear structure. 3. Provide a navigation system: Ensure users can find what they're looking for without difficulty. 4. Optimize for mobile: Make sure your website looks good and works well on different devices. 5. Improve page loading times: A fast-loading site is essential for a good user experience. 6. Enhance website accessibility: Make your
__output__ llama_perf_sampler_print:    sampling time =      39.47 ms /   526 runs   (    0.08 ms per token, 13325.56 tokens per second)
__output__ llama_perf_context_print:        load time =    2294.07 ms
__output__ llama_perf_context_print: prompt eval time =      41.98 ms /    14 tokens (    3.00 ms per token,   333.51 tokens per second)
__output__ llama_perf_context_print:        eval time =    8292.26 ms /   511 runs   (   16.23 ms per token,    61.62 tokens per second)
__output__ llama_perf_context_print:       total time =    8427.77 ms /   525 tokens
The `system_info` printed from llama.cpp highlights important architectural features present on your hardware that improve the performance of the model execution. In the output shown above from running on an AWS Graviton4 instance, you will see:
- NEON = 1 This flag indicates support for Arm’s Neon technology which is an implementation of the Advanced SIMD instructions
- ARM_FMA = 1 This flag indicates support for Arm Floating-point Multiply and Accumulate instructions
- MATMUL_INT8 = 1 This flag indicates support for Arm int8 matrix multiplication instructions
- SVE = 1 This flag indicates support for the Arm Scalable Vector Extension
The end of the output shows several model timings:
- load time refers to the time taken to load the model.
- prompt eval time refers to the time taken to process the prompt before generating the new text. In this example, it shows that it evaluated 14 tokens in 41.98 ms.
- eval time refers to the time taken to generate the output. Generally anything above 10 tokens per second is faster than what humans can read.
You have successfully run a LLM chatbot with Arm KleidiAI optimizations, all running on your Arm AArch64 CPU on your server. You can continue experimenting and trying out the model with different prompts.
