Deploy AWS Lambda functions on AWS Graviton processors
Deploy Node.js Lambda functions on Graviton processors with Terraform
Deploy Python Lambda functions on Graviton processors with Terraform
You can also write Lambda functions using Python.
Before you begin
You can reuse everything your learned from the previous topic and replace the Node.js code with a Lambda function written in Python.
Deploy Lambda function via Terraform
- Using a text editor, save the code below in a file called
python_lambda.py
This is the source code for the Lambda function.
def lambda_handler(event, context):
message = 'Hello {}{}!'.format(event['first_name'], event['last_name'])
return {
'message' : message
The Lambda function will simply print a message. The message adds the first_name and last_name inputs to the output string.
This example doesn’t place the Python source code in a subdirectory, leave it in the current directory.
main.tf
provider "aws" {
region = "us-east-1"
provider "archive" {}
data "archive_file" "lambda_zip_dir" {
type = "zip"
output_path = "python_lambda.zip"
source_file = "python_lambda.py"
data "aws_iam_policy_document" "policy" {
statement {
sid = ""
effect = "Allow"
principals {
identifiers = ["lambda.amazonaws.com"]
type = "Service"
actions = ["sts:AssumeRole"]
resource "aws_iam_role" "iam_for_lambda" {
name = "iam_for_lambda"
assume_role_policy = data.aws_iam_policy_document.policy.json
resource "aws_lambda_function" "lambda" {
function_name = "python_lambda"
filename = data.archive_file.lambda_zip_dir.output_path
source_code_hash = data.archive_file.lambda_zip_dir.output_base64sha256
role = aws_iam_role.iam_for_lambda.arn
handler = "python_lambda.lambda_handler"
runtime = "python3.8"
architectures = ["arm64"]
data "aws_lambda_invocation" "example" {
function_name = aws_lambda_function.lambda.function_name
input = <<JSON
"first_name": "Arm-",
"last_name": "user"
JSON
output "result" {
value = data.aws_lambda_invocation.example.result
output.tf
output "lambda" {
value = aws_lambda_function.lambda.qualified_arn
You should have three files ready to deploy the Lambda function using Terraform. You have main.tf, output.tf, and python_lambda.py in the current directory.
Running the Lambda function displays the ARN (Amazon Resource Names) of the Lambda resource and the output message from the code.
Terraform Commands
Use Terraform to deploy the main.tf file.
Create a Terraform execution plan
Run terraform plan to create an execution plan.
terraform plan
A long output of resources to be created will be printed.
Any errors in the Terraform setup are usually identified by terraform plan.
Apply a Terraform execution plan
Run terraform apply to apply the execution plan and create all AWS resources:
terraform apply
Answer yes to the prompt to confirm you want to create AWS resources.
The result should print output similar to:
Apply complete! Resources: 0 added, 1 changed, 0 destroyed.
Outputs:
lambda = "arn:aws:lambda:us-east-1:200211127965:function:python_lambda:$LATEST"
result = "{\"message\": \"Hello Arm-user!\"}"
You have successfully created and executed the Python Lambda function on AWS.
Verify the Lambda function
To verify the creation of the Lambda function to to the AWS console and select AWS Lambda. Click on Functions and verify the Lambda function python_lambda is displayed.
You can use the Test tab of the Lambda console to run the function again.
Enter the text below in the Event JSON input area.
"last_name": "user"
Click the Test button to run the function.
You should see the same output as running the function with Terraform.
"hello Arm_user, are you using Testing"
You have successfully deployed a Lambda function using Python on an AWS Graviton2 processor.
Clean up resources
Run terraform destroy to delete all resources created.
terraform destroy
After you run terraform destroy the Lambda function is gone from the AWS console.
