AWS Lambda is a serverless, event-driven compute service that lets you run code without managing servers.
Lambda runs your code on high-availability compute infrastructure and frees you from spending time administering servers.
You can configure Lambda functions to run on Graviton processors.
This Learning Path shows you how to deploy AWS Lambda functions using Terraform and select “arm64” as the architecture.
You should have the prerequisite tools installed before starting the Learning Path.
Any computer which has the required tools installed can be used for this section. The computer can be your desktop or laptop computer or a virtual machine with the required tools.
You will need an AWS account to complete this Learning Path. Create an account if you don’t have one.
Before you begin you will also need:
The instructions to create the keys are below.
The installation of Terraform on your desktop or laptop needs to communicate with AWS. Thus, Terraform needs to be able to authenticate with AWS.
To generate and configure the Access key ID and Secret access key, follow this guide .
Before you begin, confirm you have an AWS account and you can login to the AWS console.
index.jsThis is the source code for the Lambda function.
exports.handler = function (event, context) {
console.log(event);
context.succeed('hello ' + event.name + ', are you using ' + event.type);
The Lambda function will simply print a message. The message adds the event.name and event.type inputs to the output string.
index.js to a subdirectory named nodejs
mkdir nodejs ; cp index.js nodejs
Terraform will zip the Lambda source code so the source needs to be separated from the rest of the project files in a subdirectory.
main.tf
provider "aws" {
region = "us-east-1"
provider "archive" {}
data "archive_file" "lambda_zip_dir" {
type = "zip"
output_path = "nodejs.zip"
source_dir = "nodejs"
data "aws_iam_policy_document" "policy" {
statement {
sid = ""
effect = "Allow"
principals {
identifiers = ["lambda.amazonaws.com"]
type = "Service"
actions = ["sts:AssumeRole"]
resource "aws_iam_role" "iam_for_lambda" {
name = "iam_for_lambda"
assume_role_policy = data.aws_iam_policy_document.policy.json
resource "aws_lambda_function" "lambda" {
function_name = "indexjs"
filename = data.archive_file.lambda_zip_dir.output_path
source_code_hash = data.archive_file.lambda_zip_dir.output_base64sha256
role = aws_iam_role.iam_for_lambda.arn
handler = "index.handler"
runtime = "nodejs18.x"
architectures = ["arm64"]
data "aws_lambda_invocation" "example" {
function_name = aws_lambda_function.lambda.function_name
input = <<JSON
"name": "Arm_user",
"type": "Testing"
JSON
output "result" {
value = data.aws_lambda_invocation.example.result
output.tf
output "lambda" {
value = aws_lambda_function.lambda.qualified_arn
You should have three files ready to deploy the Lambda function using Terraform. You have main.tf and output.tf in the current directory, and index.js in a subdirectory named nodejs
Running the Lambda function displays the ARN (Amazon Resource Names) of the Lambda resource and the output message from the code.
Use Terraform to deploy the main.tf file.
Run terraform init to initialize the Terraform deployment. This command downloads the dependencies required for AWS.
terraform init
The output should be similar to:
Initializing the backend...
Initializing provider plugins...
- Finding latest version of hashicorp/aws...
- Finding latest version of hashicorp/archive...
- Installing hashicorp/aws v4.58.0...
- Installed hashicorp/aws v4.58.0 (signed by HashiCorp)
- Installing hashicorp/archive v2.3.0...
- Installed hashicorp/archive v2.3.0 (signed by HashiCorp)
Terraform has created a lock file .terraform.lock.hcl to record the provider
selections it made above. Include this file in your version control repository
so that Terraform can guarantee to make the same selections by default when
you run "terraform init" in the future.
Terraform has been successfully initialized!
You may now begin working with Terraform. Try running "terraform plan" to see
any changes that are required for your infrastructure. All Terraform commands
should now work.
If you ever set or change modules or backend configuration for Terraform,
rerun this command to reinitialize your working directory. If you forget, other
commands will detect it and remind you to do so if necessary.
Run terraform plan to create an execution plan.
terraform plan
A long output of resources to be created will be printed.
Any errors in the Terraform setup are usually identified by terraform plan.
Run terraform apply to apply the execution plan and create all AWS resources:
terraform apply
Answer yes to the prompt to confirm you want to create AWS resources.
The result should print output similar to:
Apply complete! Resources: 2 added, 0 changed, 0 destroyed.
Outputs:
lambda = "arn:aws:lambda:us-east-1:200211127965:function:indexjs:$LATEST"
result = "\"hello Arm_user, are you using Testing\""
You have successfully created and executed the Lambda function on AWS.
To verify the creation of the Lambda function to to the AWS console and select AWS Lambda. Click on Functions and verify the Lambda function indexjs is displayed.
Click on the function indexjs and scroll down to the Runtime settings
You will see the Architecture listed as arm64
You can use the Test tab of the Lambda console to run the function again.
Enter the text below in the Event JSON input area.
"name": "Arm_user",
"type": "Testing"
Click the Test button to run the function.
You should see the same output as running the function with Terraform.
"hello Arm_user, are you using Testing"
You have successfully deployed a Lambda function using Node.js on an AWS Graviton2 processor.
Run terraform destroy to delete all resources created.
terraform destroy
After you run terraform destroy the Lambda function is gone from the AWS console.
Continue the Learning Path to create a Lambda function in Python.
