Deploy Keycloak on Azure Cobalt 100 Arm64 VMs
Explore Keycloak identity management on Azure Cobalt 100
Create an Azure Cobalt 100-based Arm64 virtual machine
Allow access to Keycloak and the Flask application on Azure
Deploy Keycloak on an Azure Cobalt 100-based Arm64 virtual machine
Integrate Flask OAuth2 with Keycloak on Azure Cobalt 100
Verify that you can connect to the instance over SSH and update the system packages.
Add inbound rules for ports
8080, 9000, and 5000. Test from a browser using the VM’s public IP and the configured ports to confirm access.Ensure that PostgreSQL is installed, running, and reachable on the VM. Check that the Keycloak database settings match the PostgreSQL database, user, and connection details that you configured.
Open the Flask application and start the login flow. You should be redirected to the Keycloak login page and, after authenticating, returned to the Flask app with an authenticated session.
Yes. You’ll install both on the Azure Cobalt 100-based VM and expose them through separate inbound rules in the network security group.
