Configure an Arm Linux cloud instance for kernel building
Before you begin, you need an Arm cloud instance with SSH access.
This Learning Path uses AWS as the example platform, but you can follow the same steps on any cloud provider that offers 64-bit Arm Ubuntu instances.
For demonstration purposes, you can use an AWS m6g.12xlarge instance. Any sufficiently large instance on your chosen provider works, however, smaller instances take longer or risk running out of memory during compilation. If you use a different instance type, the minimum requirements are an Arm instance running at least 24 vCPUs with 200 GB of free storage.
Ubuntu 24.04 LTS is the operating system. Other Linux distributions may work. If you find a different distribution that works well, or you’d like to request support for a different distribution, open an issue or a pull request in the project repository .
Install required dependencies
With your build instance running and accessible via SSH, install the required dependencies, and clone the kernel-build repository:
# These commands install the compilation toolchain, kernel build tools, and utilities needed for the build scripts.
sudo apt update
sudo apt install -y git python3 python3-pip python3-venv python-is-python3 build-essential bc rsync dwarves flex bison libssl-dev libelf-dev btop yq jq
# These commands clone the helper repo and make the scripts executable.
git clone https://github.com/geremyCohen/arm_kernel_install_guide.git ~/arm_kernel_install_guide
cd ~/arm_kernel_install_guide
chmod +x scripts/*.sh
Note
All commands in this Learning Path assume you’re in the project directory at $HOME/arm_kernel_install_guide when you run them.
The repository you just cloned contains helper scripts for building and managing kernel artifacts. Specifically, the scripts/kernel_build_and_install.sh script orchestrates cloning the upstream kernel tree, configuring TuxMake, building artifacts, and optionally installing the kernel. The script runs non-interactively, and once invoked it proceeds without confirmation.
Understand the script flags
The kernel_build_and_install.sh script supports two main workflows:
  • General usage - Build kernels for direct installation or downstream packaging
  • Fastpath usage - Build kernels with additional headers and perf configuration needed by the Fastpath validation tool
About Fastpath
Fastpath is a command-line tool designed for monitoring Linux kernel performance by executing structured performance benchmarks on various hardware platforms. It automates the collection, storage, and analysis of performance data to assess how Linux kernel modifications impact different workloads. Fastpath enables developers and performance engineers to detect regressions, validate optimizations, and track long-term performance trends.
Key use cases include:
  • Kernel performance tracking across updates
  • Hardware comparison between different systems
  • Automated CI/CD benchmarking
If you need only general kernel building, use the first workflow. If you want to use Fastpath for kernel performance validation, use the second workflow. For more information, see the Fastpath documentation .
General usage flags
FlagDescription
--demo-default-buildShortcut: builds v6.18.1 with default configs and leaves Fastpath disabled
--tag <tag> / --tags <list> / --tag-latestSelect one or more kernel tags. Multiple tags build in parallel; the latest stable release can be added via --tag-latest
--install-from <dir> / --install-format <flat|deb|auto>Install an existing build (flat artifacts or .deb packages) without recompiling
--dry-runGenerate a self-contained plan script (stored in /tmp/kernel_plan_*.sh) with the resolved arguments and exit without running the build
--kernel-install [tag|bool]Install a kernel right after it finishes building. When multiple tags build, provide the specific tag to install
--change-to-64k <bool>Generate a 64 KB page-size kernel. Often combined with the install flags to test high-page builds
--config-file <path>Reuse a captured stock config instead of /boot/config-$(uname -r)
--include-bindeb-pkgAdds the bindeb-pkg target so .deb packages are produced alongside Image.gz and modules.tar.xz
--kernel-command-line <string>Override GRUB’s GRUB_CMDLINE_LINUX when installing a kernel
--append-to-kernel-version <text>Attach custom suffixes to EXTRAVERSION (for example, --append "-lab")
--kernel-dir <path> / --venv-path <path>Control where the kernel git checkout lives and which Python venv hosts TuxMake. Build artifacts always land under ~/kernels/<tag>
Fastpath usage flags
FlagDescription
--demo-fastpath-buildShortcut: builds v6.18.1 and v6.19-rc1 with Fastpath configs enabled
--fastpath <bool>Manually enable/disable the Fastpath configuration overlay (installs Docker as needed)
Verify the setup
Check that the script is executable and displays help information:
./scripts/kernel_build_and_install.sh --help
The expected output is similar to:
        Usage: kernel_build_and_install.sh [OPTIONS]
Options:
  --demo-default-build          Build v6.18.1 with default configuration
  --demo-fastpath-build         Build v6.18.1 and v6.19-rc1 with Fastpath configs
  --tag <tag>                   Specify a kernel version to build
  --tags <tag1,tag2,...>        Build multiple kernel versions in parallel
  --kernel-install [true|false|tag]  Install kernel after building
  --fastpath [true|false]       Enable Fastpath configuration overlay
  --change-to-64k [true|false]  Build kernel with 64 KB page size
  --help                        Display this help message
In this section, you’ve:
  • Configured an Arm cloud instance with the required build dependencies
  • Cloned the kernel build helper repository
  • Learned about the available build script flags for general and Fastpath workflows
  • Verified your build environment is ready
The next section covers standard kernel build workflows for direct installation or downstream packaging.
