Explore related resources
Give feedback
AI-assisted
Close
How do I choose the kernel version tag when building with TuxMake?
The examples use valid Linux version tags such as v6.18.1, but you can select any other valid tag. Pass your chosen tag to the --tags flag and TuxMake builds that version.
What result should I expect after installing a custom kernel?
You should see a new GRUB entry for the installed kernel. After reboot, the running kernel version should match the one you built, and the corresponding modules should be available.
What should I check if my build is very slow or runs out of memory?
Use a sufficiently large Arm instance, as smaller instances take longer and can run out of memory during compilation. Confirm that you have ample free storage before starting the build.
Can I combine --fastpath true with --kernel-install?
No. Fastpath is a build-only workflow, so don’t combine --fastpath true (or its demo shortcut) with --kernel-install or any --install-from commands. Build the kernel, then copy the flat artifacts to your test environment.
Which workflow should I use if I want packages instead of installing directly?
Run ./scripts/kernel_build_and_install.sh --tags v6.18.1 --include-bindeb-pkg to produce Debian packages alongside the flat kernel artifacts. The .deb files are written under ~/kernels/v6.18.1 for later transfer and installation.
