In this section, you will install Kedify on your Kubernetes cluster using Helm. You will add the Kedify chart repository, then install three separate Helm charts: KEDA (Kedify build) for event-driven autoscaling, the HTTP Scaler for HTTP-based scaling, and the Kedify Agent for connecting your cluster to Kedify’s cloud service. You will then verify the installation. This enables HTTP autoscaling on Kubernetes with KEDA and Kedify, including arm64 nodes.
For more information and other installation methods on Arm, see the Kedify installation documentation .
You will need:
From the Kedify dashboard, copy your Organization ID (Organization → Details) and retrieve or create an API key.
If you already have a Kedify Agent deployed, decode the key from the existing Secret:
kubectl get secret -n keda kedify-agent -o=jsonpath='{.data.apikey}' | base64 --decode
Otherwise, in the Kedify dashboard go to Organization → API Keys, select Create Agent Key, and copy the key.
The API key is shared across all agent installations. If you regenerate it, update existing agents and keep it secret.
Optionally, export these values for reuse in the following commands:
export YOUR_ORG_ID="<your-org-id>"
export YOUR_API_KEY="<your-agent-api-key>"
export CLUSTER_NAME="my-arm-cluster"
Add the Kedify Helm repository and update your local index:
helm repo add kedifykeda https://kedify.github.io/charts
helm repo update
Most providers (such as EKS and AKS) schedule pods on Arm nodes when you specify a nodeSelector for kubernetes.io/arch=arm64. On Google Kubernetes Engine (GKE), Arm nodes commonly have an explicit taint, so matching tolerations are required. To stay portable across providers, configure both nodeSelector and tolerations.
For a portable deployment across cloud providers, configure both nodeSelector and tolerations in your Helm values or CLI flags.
Run the following Helm command to install the Kedify build of KEDA into the keda namespace:
helm upgrade --install keda kedifykeda/keda \
--namespace keda \
--create-namespace \
--devel \
--set "nodeSelector.kubernetes\.io/arch=arm64" \
--set "tolerations[0].key=kubernetes.io/arch" \
--set "tolerations[0].operator=Equal" \
--set "tolerations[0].value=arm64" \
--set "tolerations[0].effect=NoSchedule"
Install the Kedify HTTP Scaler with matching node selector and tolerations:
helm upgrade --install keda-add-ons-http kedifykeda/keda-add-ons-http \
--namespace keda \
--devel \
--set "interceptor.nodeSelector.kubernetes\.io/arch=arm64" \
--set "interceptor.tolerations[0].key=kubernetes.io/arch" \
--set "interceptor.tolerations[0].operator=Equal" \
--set "interceptor.tolerations[0].value=arm64" \
--set "interceptor.tolerations[0].effect=NoSchedule" \
--set "scaler.nodeSelector.kubernetes\.io/arch=arm64" \
--set "scaler.tolerations[0].key=kubernetes.io/arch" \
--set "scaler.tolerations[0].operator=Equal" \
--set "scaler.tolerations[0].value=arm64" \
--set "scaler.tolerations[0].effect=NoSchedule"
Edit the cluster name, Organization ID, and API key (or rely on the exported environment variables), then run:
helm upgrade --install kedify-agent kedifykeda/kedify-agent \
--namespace keda \
--set "agent.nodeSelector.kubernetes\.io/arch=arm64" \
--set "agent.tolerations[0].key=kubernetes.io/arch" \
--set "agent.tolerations[0].operator=Equal" \
--set "agent.tolerations[0].value=arm64" \
--set "agent.tolerations[0].effect=NoSchedule" \
--set "agent.kedifyProxy.globalValues.nodeSelector.kubernetes\.io/arch=arm64" \
--set "agent.kedifyProxy.globalValues.tolerations[0].key=kubernetes.io/arch" \
--set "agent.kedifyProxy.globalValues.tolerations[0].operator=Equal" \
--set "agent.kedifyProxy.globalValues.tolerations[0].value=arm64" \
--set "agent.kedifyProxy.globalValues.tolerations[0].effect=NoSchedule" \
--set clusterName="${CLUSTER_NAME:-my-arm-cluster}" \
--set agent.orgId="${YOUR_ORG_ID}" \
--set agent.apiKey="${YOUR_API_KEY}"
List pods in the keda namespace to confirm all components are running:
kubectl get pods -n keda
Expected output (names might vary):
NAME READY STATUS RESTARTS AGE
keda-add-ons-http-external-scaler-xxxxx 1/1 Running 0 1m
keda-add-ons-http-interceptor-xxxxx 1/1 Running 0 1m
keda-admission-webhooks-xxxxx 1/1 Running 0 1m
keda-operator-xxxxx 1/1 Running 0 1m
keda-operator-metrics-apiserver-xxxxx 1/1 Running 0 1m
kedify-agent-xxxxx 1/1 Running 0 1m
Proceed to the next section to install an ingress controller, deploy a sample HTTP app, and test autoscaling.
