Before deploying HTTP applications with Kedify autoscaling, you need an ingress controller to handle incoming traffic. Most managed Kubernetes services (AWS EKS, Google GKE, Azure AKS) do not include an ingress controller by default. In this Learning Path, you install the NGINX Ingress Controller with Helm and target arm64 nodes.
If your cluster already has an ingress controller installed and configured, you can skip this step and proceed to the Autoscale HTTP applications with Kedify and Kubernetes Ingress section .
Add the NGINX Ingress Controller Helm repository:
helm repo add ingress-nginx https://kubernetes.github.io/ingress-nginx
helm repo update
Install the NGINX Ingress Controller (with nodeSelector and tolerations for arm64):
helm upgrade --install ingress-nginx ingress-nginx/ingress-nginx --namespace ingress-nginx --create-namespace --set "controller.nodeSelector.kubernetes\.io/arch=arm64" --set "controller.tolerations[0].key=kubernetes.io/arch" --set "controller.tolerations[0].operator=Equal" --set "controller.tolerations[0].value=arm64" --set "controller.tolerations[0].effect=NoSchedule" --set "controller.admissionWebhooks.patch.nodeSelector.kubernetes\.io/arch=arm64" --set "controller.admissionWebhooks.patch.tolerations[0].key=kubernetes.io/arch" --set "controller.admissionWebhooks.patch.tolerations[0].operator=Equal" --set "controller.admissionWebhooks.patch.tolerations[0].value=arm64" --set "controller.admissionWebhooks.patch.tolerations[0].effect=NoSchedule"
Wait for the load balancer to be ready:
kubectl wait --namespace ingress-nginx --for=condition=ready pod --selector=app.kubernetes.io/component=controller --timeout=300s
Managed clouds may take a few minutes to allocate a public IP address or hostname.
Retrieve the external IP address or hostname and store it in an environment variable:
export INGRESS_IP=$(kubectl get service ingress-nginx-controller --namespace=ingress-nginx -o jsonpath='{.status.loadBalancer.ingress[0].ip}{.status.loadBalancer.ingress[0].hostname}')
echo "Ingress IP/Hostname: $INGRESS_IP"
Typical values by provider:
a1234567890abcdef-123456789.us-west-2.elb.amazonaws.com)34.102.136.180)20.62.196.123)If no value is printed, wait briefly and re-run the command.
You have two options:
Option 1: DNS (recommended for production):
create a DNS record pointing application.keda to the external IP address or hostname of your ingress controller.
Option 2: host header (quick test):
use the external IP address or hostname directly with a Host: header:
curl -H "Host: application.keda" http://$INGRESS_IP
Here, $INGRESS_IP expands to the external IP address or hostname of the ingress controller.
List the controller pods and confirm they are running:
kubectl get pods --namespace ingress-nginx
You should see the ingress-nginx-controller pod in Running status.
Now that you have an ingress controller installed and configured, proceed to the next section to deploy an application and configure Kedify autoscaling.
