Explore related resources
Give feedback
AI-assisted
Close
How do I verify that Kedify and KEDA installed correctly?
Run kubectl get pods -n keda and confirm that the KEDA, HTTP scaler, and Kedify Agent pods show 1/1 in READY and Running in STATUS before continuing.
Do I need to install Traefik if my cluster already has an ingress controller?
No. If your cluster already has an ingress controller, skip the Traefik installation and use its endpoint and IngressClass name while deploying the application.
Which deployment target should I use for the ingress controller on Arm-based nodes?
Install Traefik with Helm and set its node selector and toleration for arm64 nodes to run the controller on Arm nodes in your cluster.
What do I need to connect the cluster to Kedify’s cloud service?
Use your Organization ID and API key from the Kedify Service dashboard. Provide these values when installing the Kedify Agent to establish the connection.
How do I know autoscaling is working after deploying the sample app?
Generate HTTP load against the application’s ingress and watch the service scale out. When load stops, it should scale back in, including scale-to-zero when idle.
