You can create an Arm-based Cobalt 100 virtual machine in several ways: using the Microsoft Azure portal, the Azure CLI, or Infrastructure as Code (IaC) tools. This Learning Path uses the Azure portal to walk you through creating a virtual machine with an Arm-based Cobalt 100 processor, which is from the D-Series v6 general-purpose virtual machines.
These VMs are designed for a wide range of workloads and offer Arm-based performance with the Cobalt 100 CPU. To learn more about the Dpsv6 size series, see the official Dpsv6 size series guide from Microsoft Azure.
If you have never used the Microsoft Cloud Platform before, see the Microsoft guide on how to Create a Linux virtual machine in the Azure portal .
Creating a virtual machine based on Azure Cobalt 100 is no different from creating any other virtual machine in Azure. To create an Azure virtual machine, launch the Azure portal and navigate to Virtual Machines.
Selecting the D-Series v6 family of virtual machines
Allow inbound port rules
Review and create an Azure Cobalt 100 Arm64 VM
Download private key and create resources
Your virtual machine is now ready and running. To connect, use SSH with your private key and the VM’s public IP address.
VM deployment confirmation in Azure portal
To learn more about Arm-based virtual machine in Azure, refer to Getting Started with Microsoft Azure in Get started with Arm-based cloud instances .
