Deploy Kafka on Azure Cobalt 100 Arm64 VMs
Select a D-Series v6 VM from the Dpsv6 size series, which uses the Cobalt 100 Arm-based CPU.
Use Ubuntu Pro 24.04 (Arm64).
No. Kafka
4.1.0 supports KRaft mode, which removes the need for ZooKeeper. Start the broker in KRaft mode.Open separate terminals for each of the following tasks: starting the Kafka broker (KRaft), creating a topic, running a consumer, and running a producer. If the consumer receives the messages that you produce, the end-to-end flow works.
Ensure that the broker is running and the topic is ready, then run the official
kafka-producer-perf-test.sh and kafka-consumer-perf-test.sh tools. Review the reported throughput and latency metrics to confirm that the benchmark completed, and to capture baseline results.
