You can profile a Java application using perf by including a Java agent that enables symbol resolution. This allows perf to capture meaningful method names instead of raw memory addresses.
The required library is libperf-jvmti.so, a JVM Tool Interface (JVMTI) agent that bridges perf and the JVM. It ensures that stack traces collected during profiling can be accurately resolved to Java methods.
In this section, you’ll configure Tomcat to use this Java agent and generate a flame graph using the FlameGraph toolkit.
Locate the libperf-jvmti.so library:
pushd /usr/lib
find . -name libperf-jvmti.so`
The output will show the path to the shared object file:
Open the Tomcat launch script:
vi apache-tomcat-11.0.9/bin/catalina.sh
Add the following line (replace the path if different on your system):
JAVA_OPTS="$JAVA_OPTS -agentpath:/usr/lib/linux-tools-6.8.0-63/libperf-jvmti.so -XX:+PreserveFramePointer"
Now shutdown and restart Tomcat:
cd apache-tomcat-11.0.9/bin
./shutdown.sh
./startup.sh
Run the following command to record a 10-second profile of the Tomcat process:
sudo perf record -g -k1 -p $(jps | awk /Bootstrap/'{print $1}') -- sleep 10
This generates a file named perf.data.
If needed, restart wrk on your x86 client to generate load during profiling.
Clone the FlameGraph repository and add it to your PATH:
git clone https://github.com/brendangregg/FlameGraph.git
export PATH=$PATH:`pwd`/FlameGraph
sudo perf inject -j -i perf.data | perf script | stackcollapse-perf.pl | flamegraph.pl &> profile.svg
You can now launch profile.svg in a browser to analyse the profiling result:
Java flame graph built through Java agent and perf
