Now that you have an Axion instance running Ubuntu 24.04, you can SSH into it via the Google Cloud console:
This will bring up a separate window with a shell connected to your instance.
This Ubuntu image does not include Java, so you need to install it. First update apt:
sudo apt update
Then install the default Java Runtime Environment:
sudo apt install default-jre
Check to ensure that the JRE is properly installed:
java -version
Your output will look like this:
openjdk version "21.0.3" 2024-04-16
OpenJDK Runtime Environment (build 21.0.3+9-Ubuntu-1ubuntu1)
OpenJDK 64-Bit Server VM (build 21.0.3+9-Ubuntu-1ubuntu1, mixed mode, sharing)
Once the JRE is installed, you will want to install the default JDK:
sudo apt install default-jdk
After completion of the JDK installation, check the version:
javac -version
The output will look like this:
javac 21.0.3
It’s important to ensure that your version of OpenJDK is at least 11.0.9. There is a large performance gap between OpenJDK-11.0.8 and OpenJDK 11.0.9. A patch added in 11.0.9 reduces false-sharing cache contention. For more information you can view patch JDK-8248214 .
spring-petclinic is an example Spring-based application that is simple to build and run.
First, download the repo:
git clone https://github.com/spring-projects/spring-petclinic.git
Next, enter the cloned directory and run the build script:
cd spring-petclinic
./mvnw package
This will build the jar file. Once built, you can test the web server by running the jar:
java -jar target/*.jar
Once the application is running, you can open the web app in a web browser by visiting
http://<EXTERNAL_IP>:8080
Where <EXTERNAL_IP> is the value you obtained in the
last section
