Using a file editor of your choice, copy the Java snippet below into a file named HeapUsageExample.java.
This code example allocates 1 million string objects to fill up the heap. You can use this example to easily observe the effects of different GC tuning parameters.
public class HeapUsageExample {
public static void main(String[] args) {
System.out.println("Starting the application...");
try {
// Create a large number of objects to quickly use up the heap
for (int i = 0; i < 1000000; i++) {
String[] array = new String[1000];
for (int j = 0; j < array.length; j++) {
array[j] = "Object " + j;
} catch (OutOfMemoryError e) {
System.err.println("OutOfMemoryError caught: " + e.getMessage());
System.out.println("Application finished.");
To observe what the Garbage Collector is doing, one option is to enabling logging while the JVM is running.
To enable this, you need to pass in some command-line arguments. The gc option logs the GC information. The filecount option creates a rolling log to prevent uncontrolled growth of logs with the drawback that historical logs might be rewritten and lost.
Run the following command to enable logging with JDK 11 and higher:
java -Xms512m -Xmx1024m -XX:+UseSerialGC -Xlog:gc:file=gc.log:tags,uptime,time,level:filecount=10,filesize=16m HeapUsageExample.java
If you are using JDK8, use the following command instead:
java -Xms512m -Xmx1024m -XX:+UseSerialGC -Xloggc:gc.log -XX:+PrintGCTimeStamps -XX:+UseGCLogFileRotation HeapUsageExample.java
The -Xms512m and -Xmx1024 options create a minimum and maximum heap size of 512 MiB and 1GiB respectively. This is to avoid waiting too long to see activity within the GC. Additionally, you can force the JVM to use the serial garbage collector with the -XX:+UseSerialGC flag.
You will now see a log file, named gc.log created within the same directory.
Open gc.log and the contents should look similar to:
[2024-11-08T15:04:54.304+0000][0.713s][info][gc] GC(2) Pause Young (Allocation Failure) 139M->3M(494M) 3.627ms
[2024-11-08T15:04:54.350+0000][0.759s][info][gc] GC(3) Pause Young (Allocation Failure) 139M->3M(494M) 3.699ms
These logs provide insights into the frequency, duration, and impact of Young garbage collection events. The results can vary depending on your system.
- Frequency: ~ every 46 ms
- Pause duration: ~ 3.6 ms
- Reduction size: ~ 139 MB (or 3M objects)
This logging method can be quite verbose, and makes it challenging to debug a live running application.
Using a file editor of your choice, copy the java code below into a file named WhileLoopExample.java.
This java code snippet is a long-running example that prints out a random integer and double precision floating point number four times a second:
import java.util.Random;
public class GenerateRandom {
Random rand = new Random();
while (true) {
// Generate random integer in range 0 to 999
int rand_int1 = rand.nextInt(1000);
// Print random integer
System.out.println("Random Integers: " + rand_int1);
// Generate random double
double rand_dub1 = rand.nextDouble();
// Print random double
System.out.println("Random Doubles: " + rand_dub1);
// Sleep for 1/4 second (250 milliseconds)
try {
Thread.sleep(250);
} catch (InterruptedException e) {
System.err.println("Thread interrupted: " + e.getMessage());
Start the Java program with the command below. This will use the default parameters for the garbage collection:
java WhileLoopExample.java
While the program is running, open another terminal session.
In the new terminal use the jstat command to print out the JVM statistics specifically related to the GC using the -gcutil flag:
jstat -gcutil $(pgrep java) 1000
You will observe output like the following until ctl+c is pressed:
S0 S1 E O M CCS YGC YGCT FGC FGCT CGC CGCT GCT
0.00 100.00 6.11 1.81 71.05 73.21 1 0.010 0 0.000 0 0.000 0.010
The columns of interest are:
