Measure repeated pairs
Use the dual-mode program to measure repeated pairs. Keep the Java Development Kit (JDK), logical CPUs, iteration count, Java Virtual Machine (JVM) flags, and background system load consistent.
First, run one warm-up pair:
for mode in baseline padded; do
  taskset -c 0,1 "$java_bin" \
    --add-exports java.base/jdk.internal.vm.annotation=ALL-UNNAMED \
    -XX:-RestrictContended FalseSharingDemo "$mode"
done
Then, collect five measured pairs, alternating which mode runs first.
Save the program output so that the individual results remain available:
: > timings.txt
for pair in 1 2 3 4 5; do
  if (( pair % 2 )); then
    modes="baseline padded"
  else
    modes="padded baseline"
  fi
  for mode in $modes; do
      -XX:-RestrictContended FalseSharingDemo "$mode" | tee -a timings.txt
  done
done
Note
Run alternating baseline and padded pairs. Don’t draw a conclusion from one timing comparison.
Confirm that every line has the expected mode and sum=1000000000.
Display the five elapsed values for each mode in ascending order:
  awk -v selected="$mode" '
    $1 == "mode=" selected {
      for (i = 1; i <= NF; i++)
        if ($i ~ /^seconds=/) {
          split($i, value, "=")
          print value[2]
    }' timings.txt | sort -n | awk -v selected="$mode" '
      { values[NR] = $1 }
      END {
        printf "%s: ", selected
        for (i = 1; i <= NR; i++) printf "%s%s", values[i], (i < NR ? " " : "\n")
        if (NR == 5) printf "%s median: %s\n", selected, values[3]
done
The output is similar to:
        baseline: 14.929432 15.045710 15.537969 16.851870 17.709697
baseline median: 15.537969
padded: 2.866497 2.867312 2.867552 2.869511 2.909067
padded median: 2.867552
With five measurements, the third sorted value is the median.
The baseline usually takes considerably longer because the writers repeatedly transfer ownership of their shared cache line. The exact difference depends on object placement, scheduling, processor topology, and system noise. If results overlap, repeat more pairs and examine their variability before concluding that padding helped.
Note
The reported seconds= value comes from System.nanoTime() around the worker phase. It excludes JVM startup but includes the release of the start latch, worker execution, and the joins. The value is therefore useful for comparing these two modes, but it’s not an end-to-end application latency measurement.
Review what you tested
You created a Java workload in which two threads update separate volatile long fields, used Java Object Layout (JOL) to inspect their layout, and used Perf C2C to observe inter-core sharing. You then added @Contended to place the fields in separate contention groups and inspected the padded layout.
In the representative results, the baseline fields were adjacent at offsets 16 and 24 in a 32-byte object, making it possible for both fields to occupy one 64-byte cache line. The baseline report’s highest-ranked line contained 36 local peer hits. After padding, JOL showed that the fields moved to offsets 144 and 280, with 128 bytes of padding between them. This prevented the fields from occupying the same 64-byte cache line, but increased the object size from 32 bytes to 288 bytes. The extra 256 bytes per object are the memory-footprint cost of this mitigation.
Review the measured impact
Compare the absolute peer-hit counts in the baseline and padded Perf C2C reports, then use repeated timing pairs to compare their median worker-phase runtimes. Account for the memory-footprint cost when deciding whether to apply contention padding.
In the representative Perf C2C results, the highest-ranked line after padding contained 4 local peer hits instead of 36. This approximately 89% reduction in the top-line peer count is consistent with removing the original false-sharing hot spot. The addresses came from separate JVM processes, however, so this comparison doesn’t prove that either reported address belonged to the counter object.
Across the five representative alternating measurement pairs, the median worker-phase runtimes were the following:
  • Baseline: 15.5 seconds
  • Padded: 2.9 seconds
For these representative measurements, adding @Contended reduced the median runtime by 81.5%, making the padded mode approximately 5.42 times faster.
The program performed the same one billion increments in both modes. Separating the fields reduced the cache-line ownership transfers that delayed the baseline workers.
These results apply to this sample, processor, JVM, and test environment. Object placement, CPU scheduling, topology, and background activity can change the result. In a real application, use repeated measurements and Perf evidence before adding @Contended, and balance any runtime improvement against the larger object size, heap occupancy, and possible garbage-collection cost.
What you’ve accomplished
You’ve now compared baseline and padded Java worker-phase runtimes.
You can extend this workflow to real applications to add padding and measure runtime improvements.
