Check the recorded events
Start by analyzing the report statistics:
sudo perf c2c report --stats -i baseline.data
Representative output from an Arm Neoverse-based system is similar to:
            Trace Event Information
  Total records                     :    1336447
  Load Operations                   :    1332642
  Load L1D hit                      :    1331026
  Load L2D hit                      :       1248
  Load LLC hit                      :        300
  Load Local DRAM                   :         68
  Load HIT Local Peer               :        112
  Load HIT Remote Peer              :          0
  Store Operations                  :       3805
  Store No available memory level   :       3805
  Unable to parse data source       :          0
    Global Shared Cache Line Event Information
  Total Shared Cache Lines          :         42
  Load HITs on shared lines         :     938977
  L1D hits on shared lines          :     938848
  L2D hits on shared lines          :         16
  LLC hits on shared lines          :        113
  Load hits on peer cache or nodes  :        112
  Store HITs on shared lines        :         81
  Store No available memory level   :         81
  Total Merged records              :         81
                 c2c details
  Events                            : arm_spe_0/ts_enable=1,pa_enable=1,load_filter=1,store_filter=1,min_latency=30/
                                    : dummy:u
                                    : memory
  Cachelines sort on                : Peer Snoop
  Cacheline data grouping           : offset,iaddr
The following values are the most relevant:
  • Total records: 1336447, including 1332642 loads and 3805 stores, confirms that Perf sampled the workload.
  • Load HIT Local Peer: 112 is direct evidence that sampled loads obtained data from a peer cache on the local system. The matching Load hits on peer cache or nodes: 112 value summarizes those hits across the lines classified as shared.
  • Total Shared Cache Lines: 42 means the recording contains 42 candidate shared lines. It doesn’t mean that every line belongs to BaselineCounters or is equally contended.
  • Store HITs on shared lines: 81 shows that store samples were associated with the shared lines. The much larger L1D-hit count describes accesses to those lines, but an L1D hit by itself isn’t a cache-line ownership transfer.
These statistics confirm that the recording contains sharing evidence, but they don’t identify which of the 42 lines is the baseline counter line. Use the detailed report to find the line with the largest absolute peer-snoop count and inspect its accesses.
Warning
A zero-event or zero-peer report doesn’t prove that false sharing is absent. Confirm the following:
  • The Java payload ran
  • The workload lasted long enough
  • The SPE kernel driver is available
  • Perf has permission to record
  • The installed Perf version decodes data sources for the processor
Display and rank shared lines
Generate a text report:
sudo perf c2c report --stdio -i baseline.data | tee baseline-c2c.txt
Perf normally ranks cache lines by its sharing metric. If the standard view hides lines because no peer data was decoded, display all recorded lines:
sudo perf c2c report --stdio --show-all -i baseline.data
Confirm that the c2c details section in the normal Arm report says Cachelines sort on: Peer Snoop. The first data row in the shared cache-line table is then the line with the highest peer-snoop count.
Inspect the extracted line’s records, loads, stores, and sampled CPUs. Also note the offsets and access symbols in the full report. A strong baseline candidate has all of the following properties:
  • Two or more CPUs access the same cache line.
  • Stores and loads repeatedly target offsets within that line.
  • The sharing count is large relative to other lines in the same recording.
  • The accesses occur while left-writer and right-writer run.
Don’t expect the exact addresses, counts, or percentages to match another machine. These values are all affected by SPE sampling, scheduling, object placement, and workload duration.
--show-all can reveal sampled addresses without creating peer snoop percentages. Absent peer percentages usually mean that Perf didn’t decode the required data-source information.
You can extract the most highly contended cache line address and complete summary row without reading the full report:
awk '
$1 ~ /^[0-9]+$/ && $2 ~ /^0x[[:xdigit:]]+$/ {
    print "Most contended cache line:", $2
    print "Report row:", $0
    found = 1
    exit
END {
    if (!found) {
        print "No shared cache-line row found" > "/dev/stderr"
        exit 1
The output is similar to:
        Most contended cache line: 0x101019100
Report row:       0         0x101019100     0   60983   32.14%       36       36        0   938563   938544       19        0        0       19        0   938508        0        36        0         0        0         0         0
The command prints the cache-line address from the second column and its full summary row. If the report isn’t sorted by Peer Snoop, the first row doesn’t necessarily have the highest peer-snoop count.
Note
Java Object Layout (JOL) and Perf provide complementary evidence. JOL shows that left and right are adjacent within BaselineCounters. Perf C2C shows whether accesses to a runtime cache line caused inter-core sharing. Neither tool alone proves that a specific sampled address belongs to a particular Java object.
You’ve used Perf C2C to identify the highest-ranked shared cache line and evaluate its peer-cache evidence.
Next, you’ll add contention padding to separate the two fields and record the padded workload for comparison.
