Before you begin
Run the instructions in this Learning Path on an Arm-based Linux server with Arm Statistical Profiling Extension (SPE) enabled. For instructions to confirm that SPE is enabled on your server, see Enable and verify Arm SPE support .
Install the OpenJDK 21 Java Development Kit (JDK) on your Arm-based Ubuntu server:
sudo apt update
sudo apt install -y openjdk-21-jdk
Prepare the baseline example
Before you run the examples, resolve the absolute path to the Java executable. Derive javac_bin from the same JDK so the compiler and runtime versions match.
Use the same terminal throughout this Learning Path. If you open a new terminal, you’ll need to rerun the following commands:
java_bin=$(readlink -f "$(command -v java)")
javac_bin="$(dirname "$java_bin")/javac"
"$java_bin" -version
"$javac_bin" -version
Note
Using the absolute path is important when Perf starts the payload with sudo, because the restricted sudo PATH might not contain your Java installation.
Set up the false-sharing demo
In your workspace, create a file named FalseSharingDemo.java with the following code:
import java.util.concurrent.CountDownLatch;
/** A small workload that is likely to exhibit cache-line false sharing. */
public final class FalseSharingDemo {
    private static final long ITERATIONS = 500_000_000L;
    interface Counters {
        void incrementLeft();
        void incrementRight();
        long sum();
    static final class BaselineCounters implements Counters {
        volatile long left;
        volatile long right;
        public void incrementLeft() { left++; }
        public void incrementRight() { right++; }
        public long sum() { return left + right; }
    public static void main(String[] args) throws Exception {
        if (args.length != 1 || !args[0].equals("baseline")) {
            throw new IllegalArgumentException("use: baseline");
        Counters counters = new BaselineCounters();
        CountDownLatch ready = new CountDownLatch(2);
        CountDownLatch start = new CountDownLatch(1);
        Thread left = new Thread(
                () -> runWorker(ready, start, counters::incrementLeft),
                "left-writer");
        Thread right = new Thread(
                () -> runWorker(ready, start, counters::incrementRight),
                "right-writer");
        left.start();
        right.start();
        ready.await();
        long begin = System.nanoTime();
        start.countDown();
        left.join();
        right.join();
        double seconds = (System.nanoTime() - begin) / 1_000_000_000.0;
        System.out.printf("mode=baseline seconds=%.6f sum=%d pid=%d%n",
                seconds, counters.sum(), ProcessHandle.current().pid());
    private static void runWorker(
            CountDownLatch ready, CountDownLatch start, Runnable update) {
        try {
            ready.countDown();
            start.await();
            for (long i = 0; i < ITERATIONS; i++) {
                update.run();
        } catch (InterruptedException exception) {
            Thread.currentThread().interrupt();
            throw new RuntimeException(exception);
The example has two worker threads that update adjacent volatile long fields. Each worker performs 500 million increments, making the sharing behavior easier to sample.
Compile the baseline:
"$javac_bin" FalseSharingDemo.java
The following commands use logical CPUs 0 and 1. Confirm that both CPUs are in the current shell’s permitted affinity list:
taskset -pc $$
If needed, replace 0,1 with two online CPUs from the reported list.
Run the baseline:
taskset -c 0,1 "$java_bin" FalseSharingDemo baseline
The output is similar to:
        mode=baseline seconds=45.123456 sum=1000000000 pid=12345
Your elapsed time and process ID will differ. Confirm that the output contains mode=baseline and sum=1000000000.
taskset restricts the Java Virtual Machine (JVM) and its threads to the selected logical CPUs. It doesn’t assign one writer thread to each CPU, so either thread can migrate within the permitted set.
Inspect the baseline layout with JOL
Java Object Layout (JOL) is an OpenJDK tool that’s used to inspect JVM object-layout details, including field offsets, alignment gaps, and total object size.
Download the JOL CLI 0.17 full JAR from Maven Central into the directory containing the compiled FalseSharingDemo classes:
curl -LO https://repo.maven.apache.org/maven2/org/openjdk/jol/jol-cli/0.17/jol-cli-0.17-full.jar
The full JAR includes the dependencies required by the command-line tool. Inspect BaselineCounters with the same JDK used for the workload:
"$java_bin" -cp jol-cli-0.17-full.jar:. \
  org.openjdk.jol.Main internals 'FalseSharingDemo$BaselineCounters'
A representative OpenJDK 21 layout is similar to:
        FalseSharingDemo$BaselineCounters object internals:
OFF  SZ   TYPE DESCRIPTION               VALUE
  0   8        (object header: mark)     0x0000000000000001
  8   4        (object header: class)    0x01085290
 12   4        (alignment/padding gap)
 16   8   long BaselineCounters.left     0
 24   8   long BaselineCounters.right    0
Instance size: 32 bytes
Space losses: 4 bytes internal + 0 bytes external = 4 bytes total
In this configuration, the header is 12 bytes: an 8-byte mark word and a 4-byte compressed class pointer. A long is aligned to an 8-byte boundary so that it can be accessed efficiently as one aligned value rather than straddling two 8-byte words. JOL therefore shows a 4-byte gap before left. The header itself hasn’t been padded to 16 bytes.
The two fields are adjacent at offsets 16 and 24. They can occupy one 64-byte cache line, although their offsets within the object don’t reveal where the object was placed relative to a physical cache-line boundary. Your layout can differ with the JDK and virtual machine configuration.
Record the baseline with Perf C2C
The Arm Statistical Profiling Extension (SPE) is a hardware profiling feature that samples operations and records information about how the operations executed with low overhead. For sampled memory operations, SPE can record the data address, access type, latency, and memory-source information. For more information, see the Arm SPE performance analysis white paper .
On supported Arm systems, perf c2c uses SPE to sample loads and stores, then groups their addresses into cache lines. Peer-cache and peer-node data-source values indicate that another CPU’s cache supplied data. Perf C2C uses this evidence to rank cache lines that are likely to be shared between CPUs.
Note
On Neoverse V2-based systems, use Perf 6.13 or later. Earlier versions can record SPE packets but don’t decode Neoverse V2 data-source values into peer-cache hits. For other Neoverse processors, confirm that your Perf version supports the processor’s SPE data-source encoding.
Check the Perf version:
perf version
Before recording, confirm that Linux exposes an Arm SPE performance monitoring unit (PMU):
find /sys/bus/event_source/devices -maxdepth 1 \
  -name 'arm_spe_*' -printf '%f\n'
The output should list at least one SPE PMU, usually arm_spe_0:
        arm_spe_0
If the command produces no output, don’t continue to perf c2c record. Follow the SPE enablement and verification instructions , then repeat the check. Without an exposed SPE PMU, Perf reports failed: no PMU supports the memory events.
After the SPE PMU appears, record the workload:
sudo perf c2c record -o baseline.data -- \
Confirm again that the payload prints mode=baseline and sum=1000000000. The absolute "$java_bin" path is expanded by the shell before sudo runs Perf, avoiding the restricted sudo PATH.
You’ve created a baseline example, inspected its layout with JOL, and recorded the baseline with Perf C2C.
Next, you’ll analyze the recorded baseline.data file.
