Get started with Helm on Google Axion C4A (Arm-based)
Create a Google Axion C4A virtual machine on Google Cloud
Install Helm
Validate Helm workflows on a Google Axion C4A virtual machine
Prepare a GKE cluster for Helm deployments
PostgreSQL Deployment Using Custom Helm Chart
Deploy Redis on GKE
Deploy NGINX with public access
Benchmark Helm concurrency on a Google Axion C4A virtual machine
In this section you’ll deploy Redis on Kubernetes using a custom Helm chart. After deployment, Redis will be running with internal access using a ClusterIP Service and basic connectivity validated using redis-cli.
Create a Helm chart skeleton:
helm create my-redis
my-redis/
├── Chart.yaml
├── values.yaml
└── templates/
The default Helm chart includes several files that aren’t required for a basic Redis deployment. Remove the following files from my-redis/templates/ to avoid unnecessary complexity and template errors: ingress.yaml, hpa.yaml, serviceaccount.yaml, tests/, NOTES.txt, and httproute.yaml.
cd ./my-redis/templates
rm -rf hpa.yaml ingress.yaml serviceaccount.yaml tests/ NOTES.txt httproute.yaml
cd $HOME/helm-microservices
Only Redis-specific templates will be maintained.
Replace the entire contents of my-redis/values.yaml:
replicaCount: 1
image:
repository: redis
tag: "7"
pullPolicy: IfNotPresent
service:
type: ClusterIP
port: 6379
This configuration centralizes settings, simplifies future updates, and prevents Helm template evaluation issues.
Replace the entire contents of my-redis/templates/deployment.yaml:
apiVersion: apps/v1
kind: Deployment
metadata:
name: {{ include "my-redis.fullname" . }}
spec:
replicas: 1
selector:
matchLabels:
app: {{ include "my-redis.name" . }}
template:
metadata:
labels:
spec:
containers:
- name: redis
image: "{{ .Values.image.repository }}:{{ .Values.image.tag }}"
ports:
- containerPort: 6379
Redis runs as a single pod with no persistence configured, which is suitable for learning and caching use cases.
Replace the entire contents of my-redis/templates/service.yaml to create an internal service:
apiVersion: v1
kind: Service
metadata:
spec:
type: ClusterIP
ports:
- port: 6379
selector:
Install Redis and validate that it’s running:
helm install redis ./my-redis
Confirm that the redis pod is operating:
kubectl get pods
kubectl get svc
Get the Redis pod name from the output, then test connectivity:
kubectl exec -it <redis-pod-name> -- redis-cli ping
Replace <redis-pod-name> with the actual pod name (for example, redis-my-redis-75c88646fb-6lz8v).
You should see an output similar to:
NAME READY STATUS RESTARTS AGE
postgres-app-my-postgres-6dbc8759b6-jgpxs 1/1 Running 0 6m38s
redis-my-redis-75c88646fb-6lz8v 1/1 Running 0 13s
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
kubernetes ClusterIP 34.118.224.1 <none> 443/TCP 37m
postgres-app-my-postgres ClusterIP 34.118.233.240 <none> 5432/TCP 22m
redis-my-redis ClusterIP 34.118.229.221 <none> 6379/TCP 3m19s
Finally, execute a sample ping via redis:
kubectl exec -it <redis-pod> -- redis-cli ping
PONG
The Redis pod should be in Running state and the service should be ClusterIP type.
You’ve successfully deployed Redis using a custom Helm chart with internal access via a Kubernetes Service. You’ve validated connectivity and created a clean, reusable Helm structure that’s accessible via the service name redis.
Next, you’ll deploy NGINX as a frontend service with public access to complete your microservices deployment.
