Get started with Helm on Google Axion C4A (Arm-based)
Create a Google Axion C4A virtual machine on Google Cloud
Install Helm
Validate Helm workflows on a Google Axion C4A virtual machine
Prepare a GKE cluster for Helm deployments
PostgreSQL Deployment Using Custom Helm Chart
Deploy Redis on GKE
Deploy NGINX with public access
Benchmark Helm concurrency on a Google Axion C4A virtual machine
You’ll deploy PostgreSQL on Kubernetes using a custom Helm chart with persistent storage. After completing this section, PostgreSQL will be running with persistent storage using PVC, secure credentials using Kubernetes Secrets, and connectivity using psql.
Ensure Kubernetes and Helm are working:
kubectl get nodes
helm version
If these commands fail, fix them first before continuing.
Create a dedicated folder to store all Helm charts for microservices:
mkdir helm-microservices
cd helm-microservices
Create a Helm chart skeleton:
helm create my-postgres
Directory structure:
helm-microservices/
└── my-postgres/
├── Chart.yaml
├── values.yaml
└── templates/
Remove unnecessary default files from my-postgres/templates/:
cd ./my-postgres/templates
rm -rf hpa.yaml ingress.yaml serviceaccount.yaml tests/ NOTES.txt httproute.yaml
cd $HOME/helm-microservices
Only PostgreSQL-specific templates will be maintained.
Replace the entire contents of my-postgres/values.yaml with the following to centralize all configurable settings including container image details, database credentials, and persistent storage configuration:
replicaCount: 1
image:
repository: postgres
tag: "15"
pullPolicy: IfNotPresent
postgresql:
username: admin
password: admin123
database: mydb
persistence:
enabled: true
mountPath: /var/lib/postgresql
dataSubPath: data
This configuration ensures consistent settings, avoids Helm template evaluation errors, and simplifies upgrades and maintenance.
Create my-postgres/templates/secret.yaml to store PostgreSQL credentials securely:
apiVersion: v1
kind: Secret
metadata:
name: {{ include "my-postgres.fullname" . }}
type: Opaque
stringData:
POSTGRES_USER: {{ .Values.postgresql.username }}
POSTGRES_PASSWORD: {{ .Values.postgresql.password }}
POSTGRES_DB: {{ .Values.postgresql.database }}
This approach prevents hard-coding credentials and follows Kubernetes security best practices.
Create my-postgres/templates/pvc.yaml with the following content to request persistent storage so PostgreSQL data remains available even if the pod restarts. Note the specification of the storage class that will be used my-hyperdisk-sc which was created and added to our cluster in the previous section. This hyperdisk-based storage class is required for the c4a architecture:
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
name: {{ include "my-postgres.fullname" . }}-pvc
spec:
accessModes:
- ReadWriteOnce
storageClassName: my-hyperdisk-sc
resources:
requests:
storage: {{ .Values.persistence.size }}
Without a PVC, PostgreSQL data would be lost whenever the pod restarts.
Replace the entire contents of my-postgres/templates/deployment.yaml:
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
replicas: 1
selector:
matchLabels:
app: {{ include "my-postgres.name" . }}
template:
metadata:
labels:
spec:
containers:
- name: postgres
image: "{{ .Values.image.repository }}:{{ .Values.image.tag }}"
imagePullPolicy: {{ .Values.image.pullPolicy }}
ports:
- containerPort: 5432
envFrom:
- secretRef:
env:
- name: PGDATA
value: "{{ .Values.persistence.mountPath }}/{{ .Values.persistence.dataSubPath }}"
volumeMounts:
- name: postgres-data
mountPath: {{ .Values.persistence.mountPath }}
volumes:
persistentVolumeClaim:
claimName: {{ include "my-postgres.fullname" . }}-pvc
This configuration ensures PGDATA avoids the common lost+found directory issue, persistent storage is mounted safely, and secrets inject credentials at runtime.
Replace the entire contents of my-postgres/templates/service.yaml to enable internal cluster communication:
apiVersion: v1
kind: Service
metadata:
spec:
type: ClusterIP
ports:
- port: 5432
targetPort: 5432
selector:
PostgreSQL should remain accessible only inside the Kubernetes cluster.
cd $HOME
helm uninstall postgres-app || true
helm install postgres-app ./my-postgres
The output is similar to:
LAST DEPLOYED: Mon Jan 19 16:28:29 2026
NAMESPACE: default
STATUS: deployed
REVISION: 1
TEST SUITE: None
Check the pod and PVC status:
kubectl get pods
kubectl get pvc
Check the STATUS of the pod first. If it’s not Running, wait 30 seconds and retry.
You should see an output similar to:
NAME READY STATUS RESTARTS AGE
postgres-app-my-postgres-6dbc8759b6-jgpxs 1/1 Running 0 40s
>kubectl get pvc
NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS VOLUMEATTRIBUTESCLASS AGE
postgres-app-my-postgres-pvc Bound pvc-5f3716df-39bb-4683-990a-c5cd3906fbce 10Gi RWO standard-rwo <unset> 33s
Connect to PostgreSQL. First, get the pod name:
kubectl get pods
Then connect using the pod name from the output:
kubectl exec -it <postgres-pod-name> -- psql -U admin -d mydb
Replace <postgres-pod-name> with the actual pod name (for example, postgres-app-my-postgres-6dbc8759b6-jgpxs).
psql (15.15 (Debian 15.15-1.pgdg13+1))
Type "help" for help.
mydb=#
Run test queries:
CREATE TABLE test (id INT);
INSERT INTO test VALUES (1);
SELECT * FROM test;
mydb=# CREATE TABLE test (id INT);
SELECT * FROM test;
CREATE TABLE
INSERT 0 1
id
1
(1 row)
You’ve successfully created a custom Helm chart and deployed PostgreSQL on Kubernetes with persistent storage, secure credentials using Secrets, and verified database functionality.
Next, you’ll deploy Redis on your GKE cluster using another custom Helm chart for internal communication within your Kubernetes environment.
