Set up your GKE environment
In this section you’ll prepare a Google Kubernetes Engine (GKE) cluster for deploying Helm charts. The GKE cluster hosts the following services:
  • PostgreSQL
  • Redis
  • NGINX
This setup differs from the earlier KinD-based local cluster, which was used only for local validation.
Prerequisites
Ensure that Docker, kubectl, and Helm are installed, and that you have a Google Cloud account available. If Helm and kubectl aren’t installed, complete the previous section first.
Verify kubectl installation
Confirm that kubectl is available:
kubectl version --client
You should see an output similar to:
        Client Version: v1.30.1
Kustomize Version: v5.0.4-0.20230601165947-6ce0bf390ce3
Install Python 3.11
Install Python 3.11:
sudo zypper install -y python311
which python3.11
Install Google Cloud SDK (gcloud)
The Google Cloud SDK is required to create and manage GKE clusters.
Download and extract:
wget https://dl.google.com/dl/cloudsdk/channels/rapid/downloads/google-cloud-sdk-460.0.0-linux-arm.tar.gz
tar -xvf google-cloud-sdk-460.0.0-linux-arm.tar.gz
Install gcloud:
./google-cloud-sdk/install.sh
After installation completes, exit and reconnect to apply the PATH changes:
exit
Initialize gcloud
Authenticate and configure the Google Cloud CLI:
gcloud init
During initialization, select Login with a new account. You’ll be prompted to authenticate using your browser and receive an auth code to copy back. Select the project you want to use and choose default settings when unsure.
Get the list of Google project IDs
Retrieve the list of project IDs:
gcloud projects list
The output is similar to:
        PROJECT_ID              NAME             PROJECT_NUMBER
arm-lp-test             arm-lp-test      834184475014
Note the PROJECT_ID for use in the next step.
Set the active project
Ensure the correct GCP project is selected:
gcloud config set project <YOUR_PROJECT_ID>
Replace <YOUR_PROJECT_ID> with your actual project ID from the previous step.
Install the auth plugin for gcloud
gcloud components install gke-gcloud-auth-plugin
Enable Kubernetes API
Enable the required API for GKE:
gcloud services enable container.googleapis.com
Create a GKE cluster
Create a Kubernetes cluster to host Helm deployments:
gcloud container clusters create helm-arm64-cluster \
  --zone us-central1-a \
  --machine-type c4a-standard-4 \
  --num-nodes 2 \
  --no-enable-ip-alias
Configure kubectl access to GKE
Fetch cluster credentials:
gcloud container clusters get-credentials helm-arm64-cluster \
Verify cluster access
Confirm Kubernetes access:
kubectl get nodes
        NAME                                                STATUS   ROLES    AGE     VERSION
gke-helm-arm64-cluster-default-pool-f4ab8a2d-5h6f   Ready    <none>   5h54m   v1.33.5-gke.1308000
gke-helm-arm64-cluster-default-pool-f4ab8a2d-5ldp   Ready    <none>   5h54m   v1.33.5-gke.1308000
All nodes should be in Ready state and the Kubernetes control plane should be accessible.
Remove the taint on the cluster nodes for arm64 support
Remove the taint on the nodes to ensure proper scheduling on arm64 VMs. For each node starting with gke, run the following taint command. For example using the node IDs in the output above:
Note
Note the required “-” at the end… its needed!
kubectl taint nodes gke-helm-arm64-cluster-default-pool-f4ab8a2d-5h6f kubernetes.io/arch=arm64:NoSchedule-
kubectl taint nodes gke-helm-arm64-cluster-default-pool-f4ab8a2d-5ldp kubernetes.io/arch=arm64:NoSchedule-
Replace the node names with your actual node names from the previous command output.
The output should be similar to:
        node/gke-helm-arm64-cluster-default-pool-f4ab8a2d-5h6f untainted
node/gke-helm-arm64-cluster-default-pool-f4ab8a2d-5ldp untainted
Create hyperdisk storage class for our cluster
In order to use the c4a architecture with our cluster, a new storage class must be created.
Create a new file, hyperdisk.yaml, with this content:
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
provisioner: pd.csi.storage.gke.io
parameters:
  type: hyperdisk-balanced # Or hyperdisk-ssd, etc.
reclaimPolicy: Delete
volumeBindingMode: WaitForFirstConsumer
Apply the hyperdisk.yaml file to the cluster:
kubectl apply -f ./hyperdisk.yaml
Confirm that the new storage class has been added:
kubectl get storageclass
The output should contain the new my-hyperdisk-sc storage class:
        NAME                     PROVISIONER             RECLAIMPOLICY   VOLUMEBINDINGMODE      ALLOWVOLUMEEXPANSION   AGE
my-hyperdisk-sc          pd.csi.storage.gke.io   Delete          WaitForFirstConsumer   false                  7m27s
premium-rwo              pd.csi.storage.gke.io   Delete          WaitForFirstConsumer   true                   20m
standard                 kubernetes.io/gce-pd    Delete          Immediate              true                   20m
standard-rwo (default)   pd.csi.storage.gke.io   Delete          WaitForFirstConsumer   true                   20m
The new storage class will be used in the next section.
You’ve successfully prepared your GKE environment by installing and configuring the Google Cloud SDK, creating a GKE cluster, connecting kubectl to the cluster, and verifying cluster access. Your environment is now ready to deploy applications using Helm charts.
Next, you’ll deploy PostgreSQL on your GKE cluster using a custom Helm chart with persistent storage and secure credentials.
