Overview
This section walks you through baseline testing to confirm that Helm works correctly on an Arm64-based Kubernetes cluster by validating core workflows such as install, upgrade, and uninstall.
Add Helm repository
Add the Bitnami Helm chart repository and update the local index:
helm repo add bitnami https://charts.bitnami.com/bitnami
helm repo update
You should see an output similar to:
        "bitnami" has been added to your repositories
Hang tight while we grab the latest from your chart repositories...
...Successfully got an update from the "bitnami" chart repository
Update Complete. ⎈Happy Helming!⎈
Install a sample application
Install a sample NGINX application to validate that Helm can create releases:
helm install nginx bitnami/nginx
The output is similar to:
LAST DEPLOYED: Thu Jan 15 20:13:37 2026
NAMESPACE: default
STATUS: deployed
REVISION: 1
TEST SUITE: None
NOTES:
CHART NAME: nginx
CHART VERSION: 22.4.3
APP VERSION: 1.29.4
Validate deployment
Verify that Helm created the release:
helm list
Confirm Helm recorded the release and that the deployment exists.
        NAME    NAMESPACE       REVISION        UPDATED                                 STATUS          CHART           APP VERSION
nginx   default         1               2026-01-15 20:13:37.325530458 +0000 UTC deployed        nginx-22.4.3    1.29.4
Check Kubernetes resources:
kubectl get pods
kubectl get svc
        NAME                     READY   STATUS    RESTARTS   AGE
nginx-6d597599b8-hrn7t   1/1     Running   0          116s
NAME         TYPE           CLUSTER-IP     EXTERNAL-IP   PORT(S)                      AGE
kubernetes   ClusterIP      10.96.0.1      <none>        443/TCP                      3m33s
nginx        LoadBalancer   10.96.88.148   <pending>     80:30166/TCP,443:32128/TCP   117s
All pods should be in Running state. If pods show Pending, wait 30 to 60 seconds for container images to download and retry.
Validate Helm lifecycle
Confirm that Helm supports the full application lifecycle on Arm64.
Upgrade the release
Update the existing release to a new revision:
helm upgrade nginx bitnami/nginx
Test Helm’s ability to update an existing release to a new revision.
        Release "nginx" has been upgraded. Happy Helming!
Uninstall the release
Remove the release and associated resources:
helm uninstall nginx
        release "nginx" uninstalled
You’ve validated Helm’s core functionality by:
  • Installing a sample application using Helm charts
  • Upgrading an existing release to a new revision
  • Uninstalling releases and cleaning up resources
  • Verifying that all workflows execute successfully on Arm64
Next, you’ll benchmark Helm’s performance by measuring concurrent operations and evaluating how well it handles parallel workloads on your Arm64 Kubernetes cluster.
