This section demonstrates how to install the Go programming language toolchain on Ubuntu Pro 24.04 LTS (Arm64), configure your development environment, and verify the setup for optimal performance on Azure Cobalt 100 virtual machines.
Download the latest Arm64-optimized Go distribution directly from the official Go website. This ensures you get the best performance on Azure Cobalt 100 processors:
wget https://go.dev/dl/go1.25.0.linux-arm64.tar.gz
There are many enhancements added to Golang version 1.18, that have resulted in up to a 20% increase in performance for Golang workloads on Arm-based servers. For further information, see the AWS blog Making your Go workloads up to 20% faster with Go 1.18 and AWS Graviton .
The Arm Ecosystem Dashboard also recommends Golang version 1.18 as the minimum recommended on the Arm platforms.
Unpack the downloaded archive into /usr/local, which is the conventional directory for installing system-wide software on Linux. This ensures the Go toolchain is available for all users and integrates cleanly with the system’s environment.
sudo tar -C /usr/local -xzf ./go1.25.0.linux-arm64.tar.gz
To make the Go toolchain accessible from any directory, add its binary location to your shell’s PATH environment variable. Updating your .bashrc file ensures this change persists across sessions:
echo 'export PATH="$PATH:/usr/local/go/bin"' >> ~/.bashrc
Apply the environment changes to your current shell session without requiring a logout/login cycle:
source ~/.bashrc
Confirm that Go is properly installed and accessible:
go version
Expected output for Azure Cobalt 100 Arm64:
go version go1.25.0 linux/arm64
Use the following command to display Go’s environment variables and confirm that key paths (such as GOROOT and GOPATH) are correctly set:
go env GOROOT GOPATH GOARCH GOOS
You should see output similar to:
AR='ar'
CC='gcc'
CGO_CFLAGS='-O2 -g'
CGO_CPPFLAGS=''
CGO_CXXFLAGS='-O2 -g'
CGO_ENABLED='1'
CGO_FFLAGS='-O2 -g'
CGO_LDFLAGS='-O2 -g'
CXX='g++'
GCCGO='gccgo'
GO111MODULE=''
GOARCH='arm64'
GOARM64='v8.0'
GOAUTH='netrc'
GOBIN=''
GOCACHE='/home/ubuntu/.cache/go-build'
GOCACHEPROG=''
GODEBUG=''
GOENV='/home/ubuntu/.config/go/env'
GOEXE=''
GOEXPERIMENT=''
GOFIPS140='off'
GOFLAGS=''
GOGCCFLAGS='-fPIC -pthread -Wl,--no-gc-sections -fmessage-length=0 -ffile-prefix-map=/tmp/go-build119388372=/tmp/go-build -gno-record-gcc-switches'
GOHOSTARCH='arm64'
GOHOSTOS='linux'
GOINSECURE=''
GOMOD='/dev/null'
GOMODCACHE='/home/ubuntu/go/pkg/mod'
GONOPROXY=''
GONOSUMDB=''
GOOS='linux'
GOPATH='/home/ubuntu/go'
GOPRIVATE=''
GOPROXY='https://proxy.golang.org,direct'
GOROOT='/usr/local/go'
GOSUMDB='sum.golang.org'
GOTELEMETRY='local'
GOTELEMETRYDIR='/home/ubuntu/.config/go/telemetry'
GOTMPDIR=''
GOTOOLCHAIN='auto'
GOTOOLDIR='/usr/local/go/pkg/tool/linux_arm64'
GOVCS=''
GOVERSION='go1.25.0'
GOWORK=''
PKG_CONFIG='pkg-config'
The Go installation on Ubuntu Pro 24.04 LTS (Arm64) VM is now complete and you are ready to proceed with Go application development, benchmarking, or performance tuning on Azure Cobalt 100 VMs.
