go test -bench is Go’s built-in benchmark runner. It repeatedly executes benchmark functions and reports latency (ns/op). With the -benchmem flag, it also reports memory usage (B/op) and allocations (allocs/op). It’s simple, reliable, and requires only writing benchmark functions in the standard Golang testing package.
Create a directory for your benchmark project and navigate to it:
mkdir gosort-bench
cd gosort-bench
Initialize a new module:
go mod init gosort-bench
This creates a go.mod file, which defines the module path (gosort-bench in this case) and marks the directory as a Go project. The go.mod file also allows Go to manage dependencies (external libraries) automatically, ensuring your project remains reproducible and easy to maintain.
Create a file named sorting.go:
nano sorting.go
Paste the following implementation into sorting.go:
package sorting
func BubbleSort(arr []int) {
n := len(arr)
for i := 0; i < n-1; i++ {
for j := 0; j < n-i-1; j++ {
if arr[j] > arr[j+1] {
arr[j], arr[j+1] = arr[j+1], arr[j]
func QuickSort(arr []int) {
quickSort(arr, 0, len(arr)-1)
func quickSort(arr []int, low, high int) {
if low < high {
pivot := partition(arr, low, high)
quickSort(arr, low, pivot-1)
quickSort(arr, pivot+1, high)
func partition(arr []int, low, high int) int {
pivot := arr[high]
i := low - 1
for j := low; j < high; j++ {
if arr[j] < pivot {
i++
arr[i], arr[j] = arr[j], arr[i]
arr[i+1], arr[high] = arr[high], arr[i+1]
return i + 1
The code contains two sorting methods, Bubble Sort and Quick Sort, which arrange numbers in order from smallest to largest:
To summarize, Bubble Sort is simple but slow, while Quick Sort is more efficient and usually much faster for big lists of numbers.
At this point, you have defined two sorting algorithms ready to be benchmarked.
To keep your project modular and maintainable, it’s best practice to place implementation code inside its own package folder. This allows benchmarks and other Go files to import it cleanly.
mkdir sorting
mv sorting.go sorting/
Create a benchmark file named sorting_benchmark_test.go in the project root:
nano sorting_benchmark_test.go
Paste the following code:
package sorting_test
import (
"math/rand"
"testing"
"gosort-bench/sorting"
const LENGTH = 10000
func makeRandomNumberSlice(n int) []int {
numbers := make([]int, n)
for i := range numbers {
numbers[i] = rand.Intn(n)
return numbers
func BenchmarkBubbleSort(b *testing.B) {
for i := 0; i < b.N; i++ {
b.StopTimer()
numbers := makeRandomNumberSlice(LENGTH)
b.StartTimer()
sorting.BubbleSort(numbers)
func BenchmarkQuickSort(b *testing.B) {
b.StopTimer()
b.StartTimer()
sorting.QuickSort(numbers)
The code implements a benchmark that measures the performance of Bubble Sort and Quick Sort in Go by generating a new list of 10,000 random numbers before each run to keep the test fair and consistent. The BenchmarkBubbleSort() function evaluates the slower Bubble Sort algorithm, while the BenchmarkQuickSort() function evaluates the faster Quick Sort algorithm, allowing you to compare their relative speeds and efficiency.
When you run the benchmark, Go will show you how long each sort takes and how much memory it uses, so you can compare the two sorting techniques.
Execute the benchmark suite using the following command:
go test -bench=. -benchmem
-bench=. runs every function whose name starts with Benchmark. -benchmem adds memory metrics (B/op, allocs/op) to the report.
Expected output:
goos: linux
goarch: arm64
pkg: gosort-bench
BenchmarkBubbleSort-4 32 36616759 ns/op 0 B/op 0 allocs/op
BenchmarkQuickSort-4 3506 340873 ns/op 0 B/op 0 allocs/op
PASS
ok gosort-bench 2.905s
The metrics reported by go test -bench include ns/op, which measures nanoseconds per operation and reflects latency where lower values are better, B/op, which shows the number of bytes allocated per operation and helps identify memory efficiency, and allocs/op, which indicates the number of heap allocations per operation and highlights how often memory is being allocated, with lower values preferred in all cases.
Results collected on an Arm64 D4ps_v6 Ubuntu Pro 24.04 LTS virtual machine:
| Benchmark | Value |
| BubbleSort (ns/op) | 36,616,759 |
| QuickSort (ns/op) | 340,873 |
| BubbleSort runs | 32 |
| QuickSort runs | 3,506 |
| Allocations/op | 0 |
| Bytes/op | 0 |
| Total time (s) | 2.905 |
Results collected on an x86-64 D4s_v6 Ubuntu Pro 24.04 LTS virtual machine:
| Benchmark | Value on Virtual Machine |
| BubbleSort (ns/op) | 42,801,947 |
| QuickSort (ns/op) | 512,726 |
| BubbleSort runs | 27 |
| QuickSort runs | 2,332 |
| Bytes/op | 0 |
| Total time (s) | 2.716 |
On Azure Cobalt 100 (Arm64), both BubbleSort and QuickSort run faster, with a larger advantage for QuickSort. The observed performance delta (~15–33%) highlights how Arm Neoverse cores excel at CPU-bound, integer-heavy workloads common in Go services.
For real-world Go applications, such as sorting, JSON processing, and other recursive or data-processing tasks, Azure Cobalt 100 Arm64 VMs can provide higher throughput and lower execution time than similarly sized x86-64 VMs. These results validate the benefits of running Go on Cobalt 100 and establish a baseline for extending benchmarks beyond simple sorting.
