Understand the benchmark metrics
To understand what the benchmark results are showing, first open the Benchstat summary:
cat default_gc_benchstat.txt
The metrics you see explain the following:
MetricWhat it tells you
ns/opTime per completed operation. Lower is better for throughput.
B/opHeap bytes allocated per operation. Lower usually reduces garbage collection (GC) pressure.
allocs/opHeap allocation count per operation. Lower usually reduces GC pressure.
gc/opGC cycles per operation. Lower means GC runs less often per completed operation.
stw-ns/op or stw-sec/opGC pause cost per operation. Lower means less stop-the-world pause time is paid per completed operation.
stw-ns/GC or stw-sec/GCPause cost per GC cycle. Lower means each GC cycle pauses for less time.
These metrics answer different questions. For example, stw-ns/GC can increase while stw-ns/op stays flat or decreases if GC runs less often per completed operation.
Read the profiles
Next, open the CPU profile summary:
cat cpu_default_top.txt
Look for functions that dominate CPU time. In an allocation-heavy benchmark, you can expect to see time in string handling, allocation paths, and some runtime or GC support functions.
The flat column shows CPU time spent directly in that function. The cum (cumulative) column includes time spent in the function and all functions it called. A function with low flat but high cum is spending most of its time in callees, which can point to allocation chains or deep call stacks.
On the validated m8g.xlarge instance, the top CPU profile entries include string scanning, string concatenation, split handling, and allocation paths:
      flat  flat%   sum%        cum   cum%
     2.45s 15.53% 15.53%      2.45s 15.53%  internal/bytealg.IndexByteString
     2.37s 15.02% 30.54%      4.65s 29.47%  runtime.concatstrings
     1.28s  8.11% 38.66%      8.07s 51.14%  strings.genSplit
     0.85s  5.39% 44.04%      1.35s  8.56%  runtime.mallocgcTiny
     0.72s  4.56% 53.36%      5.17s 32.76%  runtime.mallocgc
IndexByteString and concatstrings dominate because the benchmark splits the payload with strings.Split, which scans for ; byte-by-byte, and builds key:length strings with + concatenation on every iteration. These operations create a large volume of short-lived strings, giving the GC constant work to do. On Graviton, pprof makes these allocation chains directly visible because the arm64 stack unwinder captures the full call path without frame pointer ambiguity.
Open the heap allocation profile summary and look for application functions that allocate the most heap memory:
cat mem_default_alloc_top.txt
Reducing allocation volume in those functions usually gives the Go garbage collector less work to do.
On the validated m8g.xlarge instance, the allocation profile shows that strings.genSplit and the benchmark function account for nearly all allocated bytes:
    7.57GB 64.49% 64.49%     7.57GB 64.49%  strings.genSplit
    4.16GB 35.45% 99.94%    11.74GB 99.94%  example.com/go-gc-default/parsebench.BenchmarkParseAndAllocate
         0     0% 99.94%     2.90GB 24.70%  strings.Split (inline)
         0     0% 99.94%     4.67GB 39.79%  strings.SplitN (inline)
Keep a baseline to compare to future changes
These results show your default Go GC baseline for this benchmarking app on AWS Graviton. By keeping the following files together — for example, in a versioned folder or archive — you can see how code changes affect overall performance:
        default_runtime_baseline.txt
default_gc_benchmark.txt
default_gc_profile_run.txt
cpu_default.out
cpu_default_top.txt
mem_default.out
You’ve now interpreted a documented default GC baseline showing operation time, allocation rate, GC frequency, and stop-the-world pause costs on AWS Graviton.
Next, you’ll apply code changes to the benchmark and measure how each change affects these metrics.
