Give feedback
AI-assisted
Close
How do I verify the instance and Go toolchain are Arm-based before benchmarking?
Run go version and check that it reports linux/arm64. Also run go env GOOS GOARCH and confirm GOARCH is arm64.
What should I check to keep the default Go GC baseline intact?
Confirm that GOGC, GOMEMLIMIT, GODEBUG, and GOMAXPROCS aren’t set. Use env | grep -E '^(GOGC|GOMEMLIMIT|GODEBUG|GOMAXPROCS)=' || true and unset any variables that appear.
What result should I expect after the baseline benchmark run?
You should have a runtime snapshot (Go version, GOOS/GOARCH, CPU count, and memory) and raw benchmark output in default_gc_benchmark.txt. Run benchstat default_gc_benchmark.txt next to create the summary used to compare and interpret the baseline metrics.
How do I interpret the Benchstat metrics related to GC?
ns/op shows time per operation (lower is faster), B/op shows bytes allocated per operation, and allocs/op shows the number of allocations per operation—lower values generally reduce GC pressure. gc/op indicates how often GC cycles occur per operation. A lower gc/op means GC runs less frequently for the same work.
How do I capture CPU and heap profiles without changing GC behavior?
Leave GOGC, GOMEMLIMIT, GODEBUG, and GOMAXPROCS unset and run the benchmark using the profiling commands. The run writes CPU and heap profiles alongside the benchmark results while preserving default GC behavior.
