Overview
Launch an Arm-based c4a-standard-4 instance
Launch an Intel Emerald Rapids c4-standard-8 instance
Install Go, Sweet, and Benchstat
Benchmark types and metrics
Manually run benchmarks
Manually run Benchstat
Install the automated benchmark and Benchstat runner
Run the automated benchmark and Benchstat runner
Now that setup is complete, it’s important to understand the benchmarks you’ll run and the performance metrics you’ll use to evaluate results across systems.
Whether running manually or automatically, the benchmarking process consists of two main steps:
Running benchmarks with Sweet: sweet executes the benchmarks on each VM, generating raw performance data.
Analyzing results with Benchstat: benchstat compares the results from different VMs to identify performance differences. Benchstat can output results in text format (default) or CSV format. The text format provides a human-readable tabular view, while CSV allows for further processing with other tools.
Sweet comes ready to run with the following benchmarks:
| Benchmark | Description | Example command |
| biogo-igor | Processes pairwise alignment data using the biogo library, grouping repeat feature families and outputting results in JSON format. | sweet run -count 10 -run="biogo-igor" config.toml |
| biogo-krishna | Pure-Go implementation of the PALS algorithm for pairwise sequence alignment, measuring alignment runtime performance. | sweet run -count 10 -run="biogo-krishna" config.toml |
| bleve-index | Indexes a subset of Wikipedia articles into a Bleve full-text search index to assess indexing throughput and resource usage. | sweet run -count 10 -run="bleve-index" config.toml |
| cockroachdb | Executes CockroachDB KV workloads with varying read percentages (0%, 50%, 95%) and node counts (1 & 3) to evaluate database performance. | sweet run -count 10 -run="cockroachdb" config.toml |
| esbuild | Bundles and minifies JavaScript/TypeScript code using esbuild on a representative codebase to measure build speed and efficiency. | sweet run -count 10 -run="esbuild" config.toml |
| etcd | Uses the official etcd benchmarking tool to stress-test an etcd cluster, measuring request latency and throughput for key-value operations. | sweet run -count 10 -run="etcd" config.toml |
| go-build | Compiles a representative Go module (or the Go toolchain) to measure compilation time and memory (RSS) usage on supported platforms. | sweet run -count 10 -run="go-build" config.toml |
| gopher-lua | Executes Lua scripts using the GopherLua VM to benchmark the performance of a pure-Go Lua interpreter. | sweet run -count 10 -run="gopher-lua" config.toml |
| markdown | Parses and renders Markdown documents to HTML using a Go-based markdown library to evaluate parsing and rendering throughput. | sweet run -count 10 -run="markdown" config.toml |
| tile38 | Stress-tests a Tile38 geospatial database with WITHIN, INTERSECTS, and NEARBY queries to measure spatial query performance. | sweet run -count 10 -run="tile38" config.toml |
When running benchmarks, several key metrics are collected to evaluate performance. The following summarizes the most common metrics and their significance:
This metric measures the time taken to complete a single operation, indicating the raw speed of execution. It directly reflects the performance efficiency of a system for a specific task, making it one of the most fundamental benchmarking metrics.
A system with lower seconds per operation completes tasks faster. This metric primarily reflects CPU performance but can also be influenced by memory access speeds and I/O operations. If seconds per operation is the only metric showing significant difference while memory metrics are similar, the performance difference is likely CPU-bound.
This metric provides a clear measure of system performance capacity, making it essential for understanding raw processing power and scalability potential. A system performing more operations per second has greater processing capacity.
This metric reflects overall system performance including CPU speed, memory access efficiency, and I/O capabilities.
If operations per second is substantially higher while memory usage remains proportional, the system likely has superior CPU performance. High operations per second with disproportionately high memory usage may indicate performance gains through memory-intensive optimizations. A system showing higher operations per second but also higher resource consumption may be trading efficiency for raw speed.
This metric is essentially the inverse of “seconds per operation” and provides a more intuitive way to understand throughput capacity.
Resident Set Size (RSS) represents the portion of memory occupied by a process that is held in RAM (not swapped out). It shows the typical memory footprint during operation, indicating memory efficiency and potential for scalability.
Lower average RSS indicates more efficient memory usage. A system with lower average RSS can typically handle more concurrent processes before memory becomes a bottleneck. This metric reflects both algorithm efficiency and memory management capabilities.
If one VM has significantly higher seconds per operation but lower RSS, it may be trading speed for memory efficiency. Systems with similar CPU performance but different RSS values indicate different memory optimization approaches; lower RSS with similar CPU performance suggests better memory management, which is a critical indicator of performance in memory-constrained environments.
Peak RSS bytes is the maximum Resident Set Size reached during execution, representing the worst-case memory usage scenario. The peak RSS metric helps to understand memory requirements and potential for memory-related bottlenecks during intensive operations.
Lower peak RSS indicates better handling of memory-intensive operations. High peak RSS values can indicate memory spikes that might cause performance degradation through swapping or out-of-memory conditions.
Large differences between average and peak RSS suggest memory usage volatility. A system with lower peak RSS but similar performance is better suited for memory-constrained environments.
Peak VM Bytes is the maximum Virtual Memory size used, including both RAM and swap space allocated to the process.
Lower peak VM indicates more efficient use of the total memory address space. High VM usage with low RSS suggests the system is effectively using virtual memory management. Extremely high VM with proportionally low RSS might indicate memory fragmentation issues.
If peak VM is much higher than peak RSS, the system is relying heavily on virtual memory management. Systems with similar performance but different VM usage patterns may have different memory allocation strategies. High VM with performance degradation suggests potential memory-bound operations due to excessive paging.
When comparing metrics across two systems, keep the following in mind:
A system is likely CPU-bound if seconds per operation differs significantly while memory metrics remain similar.
A system is likely memory-bound if performance degrades as memory metrics increase, especially when peak RSS approaches available physical memory.
The ideal system shows lower values across all metrics - faster execution with smaller memory footprint. Systems with similar seconds per operation but significantly different memory metrics indicate different optimization priorities.
Lower memory metrics (especially peak values) suggest better scalability for concurrent workloads. Systems with lower seconds per operation but higher memory usage may perform well for single tasks but scale poorly.
Large gaps between average and peak memory usage suggest opportunities for memory optimization. High seconds per operation with low memory usage suggests CPU optimization potential.
Here are some general tips to keep in mind as you explore benchmarking across different apps and instance types:
On Intel and AMD processors with hyper-threading, each vCPU corresponds to a logical core (hardware thread), and two vCPUs share a single physical core. On Arm processors (which do not use hyper-threading), each vCPU corresponds to a full physical core. For comparison, this Learning Path uses a 4-vCPU Arm instance against an 8-vCPU Intel instance, maintaining a 2:1 Intel:Arm vCPU ratio to keep parity on physical CPU resources.
Run each benchmark at least 10 times to account for outliers and produce statistically meaningful results.
Results can be bound by CPU, memory, or I/O performance. If you see significant differences in one metric but not others, it might indicate a bottleneck in that area; running the same benchmark with different configurations (for example, using more CPU cores or more memory) can help identify the bottleneck.
