Overview
Launch an Arm-based c4a-standard-4 instance
Launch an Intel Emerald Rapids c4-standard-8 instance
Install Go, Sweet, and Benchstat
Benchmark types and metrics
Manually run benchmarks
Manually run Benchstat
Install the automated benchmark and Benchstat runner
Run the automated benchmark and Benchstat runner
In this section, you’ll install Go, Sweet, and Benchstat on both virtual machines:
Together, these tools help you evaluate Go performance on both Arm and x86 architectures.
Subsequent steps in this Learning Path assume you are running this script (installing) from your home directory ($HOME), resulting in the creation of a $HOME/benchmarks/sweet final install path. If you install to a different directory, update the paths in later steps to match your custom location.
Start by copying and pasting the script below on both of your GCP VMs. This script automatically detects your system architecture, installs the appropriate Go version, and sets up Sweet, Benchstat, and the Go benchmark suite.
Paste the full block into your terminal. This creates and runs an installer script directly from your home directory:
#!/usr/bin/env bash
# Write the install script to filesystem using a HEREDOC
cat <<'EOF' > install_go_and_sweet.sh
sudo apt-get -y update
sudo apt-get -y install git build-essential
# Detect architecture - this allows the same script to work on both
# Arm (c4a) and x86 (c4) VMs without modification
ARCH=$(uname -m)
case "$ARCH" in
arm64|aarch64)
GO_PKG="go1.24.2.linux-arm64.tar.gz"
x86_64|amd64)
GO_PKG="go1.24.2.linux-amd64.tar.gz"
echo "Unsupported architecture: $ARCH"
exit 1
esac
# Download and install architecture-specific Go environments
URL="https://go.dev/dl/${GO_PKG}"
echo "Downloading $URL..."
wget -q --show-progress "$URL"
echo "Extracting $GO_PKG to /usr/local..."
sudo tar -C /usr/local -xzf "$GO_PKG"
echo "Go 1.24.2 installed successfully for $ARCH."
export GOPATH=$HOME/go
export GOBIN=$GOPATH/bin
export PATH=$PATH:$GOBIN:/usr/local/go/bin
# Install Sweet, benchmarks, and benchstat tools
go install golang.org/x/benchmarks/sweet/cmd/sweet@latest
go install golang.org/x/perf/cmd/benchstat@latest
git clone https://github.com/golang/benchmarks
cd benchmarks/sweet
sweet get # to get assets
# Create a configuration file
cat <<CONFFILE > config.toml
[[config]]
name = "arm-benchmarks"
goroot = "/usr/local/go"
CONFFILE
EOF
# Make the script executable
chmod 755 install_go_and_sweet.sh
# Run the script
./install_go_and_sweet.sh
When sweet get completes successfully, you’ll see output similar to:
Sweet v0.3.0: Go Benchmarking Suite
Retrieves assets for benchmarks from GCS.
Usage: sweet get [flags]
-cache string
cache location for assets (default "/home/pareena_verma_arm_com/.cache/go-sweet")
-clean
delete all cached assets before installing new ones
-copy string
location to extract assets into, useful for development
-version string
the version to download assets for (default "v0.3.0")
To test that everything is installed correctly, set the environment variables shown below on each VM:
Now run the markdown benchmark with sweet on both VMs as shown:
cd benchmarks/sweet
sweet get
sweet run -count 10 -run="markdown" config.toml # run one, 1X
You should see output similar to the following:
# Example output:
[sweet] Work directory: /tmp/gosweet3444550660
[sweet] Benchmarks: markdown (10 runs)
[sweet] Setting up benchmark: markdown
[sweet] Running benchmark markdown for arm-benchmarks: run 1
[sweet] Running benchmark markdown for arm-benchmarks: run 10
