You can run the mongodb benchmark using Glibc with LSE and NoLSE and compare the results. This will give you an idea of the performance gained by using Glibc with LSE.
Result with No-LSE
Launch MongoDB with Glibc but without LSE and obtain a benchmark result.
The output will look similar to:
        [OVERALL], RunTime(ms), 750511
[OVERALL], Throughput(ops/sec), 6662.1275371047195
[TOTAL_GCS_G1_Young_Generation], Count, 3527
[TOTAL_GC_TIME_G1_Young_Generation], Time(ms), 27871
[TOTAL_GC_TIME_%_G1_Young_Generation], Time(%), 3.713603131732913
[TOTAL_GCS_G1_Old_Generation], Count, 0
[TOTAL_GC_TIME_G1_Old_Generation], Time(ms), 0
[TOTAL_GC_TIME_%_G1_Old_Generation], Time(%), 0.0
[TOTAL_GCs], Count, 3527
[TOTAL_GC_TIME], Time(ms), 27871
[TOTAL_GC_TIME_%], Time(%), 3.713603131732913
[READ], Operations, 1998800
[READ], AverageLatency(us), 3047.5279422653593
[READ], MinLatency(us), 225
[READ], MaxLatency(us), 219775
[READ], 95thPercentileLatency(us), 10495
[READ], 99thPercentileLatency(us), 23791
[READ], Return=OK, 1998800
[READ-MODIFY-WRITE], Operations, 999359
[READ-MODIFY-WRITE], AverageLatency(us), 5748.511211686691
[READ-MODIFY-WRITE], MinLatency(us), 482
[READ-MODIFY-WRITE], MaxLatency(us), 379135
[READ-MODIFY-WRITE], 95thPercentileLatency(us), 17455
[READ-MODIFY-WRITE], 99thPercentileLatency(us), 32271
[CLEANUP], Operations, 64
[CLEANUP], AverageLatency(us), 57.46875
[CLEANUP], MinLatency(us), 0
[CLEANUP], MaxLatency(us), 3519
[CLEANUP], 95thPercentileLatency(us), 3
[CLEANUP], 99thPercentileLatency(us), 38
[UPDATE], Operations, 2500755
[UPDATE], AverageLatency(us), 2888.259603599713
[UPDATE], MinLatency(us), 211
[UPDATE], MaxLatency(us), 378367
[UPDATE], 95thPercentileLatency(us), 9743
[UPDATE], 99thPercentileLatency(us), 22895
[UPDATE], Return=OK, 2500755
[SCAN], Operations, 1499804
[SCAN], AverageLatency(us), 22936.992162975963
[SCAN], MinLatency(us), 317
[SCAN], MaxLatency(us), 335615
[SCAN], 95thPercentileLatency(us), 51551
[SCAN], 99thPercentileLatency(us), 70143
[SCAN], Return=OK, 1499804
The overall throughput (operations/sec) is 6662.1275371047195 with No-LSE Glibc.
Result with LSE
Launch MongoDB again, this time with Glibc with LSE and obtain a benchmark result.
[OVERALL], RunTime(ms), 727632
[OVERALL], Throughput(ops/sec), 6871.605426919102
[TOTAL_GCS_G1_Young_Generation], Count, 3397
[TOTAL_GC_TIME_G1_Young_Generation], Time(ms), 27090
[TOTAL_GC_TIME_%_G1_Young_Generation], Time(%), 3.7230358203047693
[TOTAL_GCs], Count, 3397
[TOTAL_GC_TIME], Time(ms), 27090
[TOTAL_GC_TIME_%], Time(%), 3.7230358203047693
[READ], Operations, 1998456
[READ], AverageLatency(us), 3045.181359009155
[READ], MinLatency(us), 230
[READ], MaxLatency(us), 346111
[READ], 95thPercentileLatency(us), 10535
[READ], 99thPercentileLatency(us), 23631
[READ], Return=OK, 1998456
[READ-MODIFY-WRITE], Operations, 999026
[READ-MODIFY-WRITE], AverageLatency(us), 5786.018821331977
[READ-MODIFY-WRITE], MinLatency(us), 467
[READ-MODIFY-WRITE], MaxLatency(us), 359167
[READ-MODIFY-WRITE], 95thPercentileLatency(us), 17599
[READ-MODIFY-WRITE], 99thPercentileLatency(us), 32463
[CLEANUP], AverageLatency(us), 52.25
[CLEANUP], MinLatency(us), 1
[CLEANUP], MaxLatency(us), 3217
[CLEANUP], 95thPercentileLatency(us), 2
[CLEANUP], 99thPercentileLatency(us), 8
[UPDATE], Operations, 2500888
[UPDATE], AverageLatency(us), 2905.821863674023
[UPDATE], MinLatency(us), 207
[UPDATE], MaxLatency(us), 320767
[UPDATE], 95thPercentileLatency(us), 9903
[UPDATE], 99thPercentileLatency(us), 23007
[UPDATE], Return=OK, 2500888
[SCAN], Operations, 1499682
[SCAN], AverageLatency(us), 21999.80309425598
[SCAN], MinLatency(us), 298
[SCAN], MaxLatency(us), 525311
[SCAN], 95thPercentileLatency(us), 49727
[SCAN], 99thPercentileLatency(us), 67455
[SCAN], Return=OK, 1499682
The overall throughput (operations/sec) is 6871.605426919102 when using Glibc with LSE. In this case, you get around 3.14% performance uplift by using Glibc with LSE.
