Explore the benefits of migrating microservices to Arm on GKE
Set up your environment
Create build-ready Dockerfiles for both architectures
Build and deploy multi-architecture images on GKE
Prepare manifests and deploy on GKE
Automate builds and rollout with Cloud Build and Skaffold
You can use Cloud Shell to set variables, enable APIs, create Artifact Registry, authenticate Docker, and clone the sample microservices demo.
Make sure you have the following tools installed: kubectl, gcloud, docker, and git.
You can use your local macOS or Linux computer instead of Cloud Shell. Make sure the required software is installed.
Run the following commands in your terminal to set the project, region/zone, cluster, and Artifact Registry variables:
export PROJECT_ID="$(gcloud config get-value project)"
export REGION="us-central1"
export ZONE="us-central1-a"
export CLUSTER_NAME="gke-multi-arch-cluster"
# Artifact Registry settings
export REPO="multi-arch-services"
# GAR is the Artifact Registry host/repo prefix used in image tags (e.g., ${GAR}/service:tag)
export GAR="${REGION}-docker.pkg.dev/${PROJECT_ID}/${REPO}"
# Ensure gcloud uses these defaults
gcloud config set project "${PROJECT_ID}"
gcloud config set compute/region "${REGION}"
gcloud config set compute/zone "${ZONE}"
You’ll need the environment variables in any shell you use to work on the project.
Enable the required APIs so the project can create GKE clusters, push and pull container images in Artifact Registry, and use Cloud Build for CI/CD:
gcloud services enable container.googleapis.com artifactregistry.googleapis.com cloudbuild.googleapis.com
Create a Docker repository in Artifact Registry in this region for pushing and pulling your multi-architecture images:
gcloud artifacts repositories create "${REPO}" --repository-format=docker --location="${REGION}" --description="Multi-arch images for microservices demo"
Authenticate Docker to Artifact Registry so you can push and pull images:
gcloud auth configure-docker "${REGION}-docker.pkg.dev"
Clone the sample application repository:
git clone https://github.com/GoogleCloudPlatform/microservices-demo.git
cd microservices-demo
You’re now ready to start making modifications for arm64 support.
