Explore the benefits of migrating microservices to Arm on GKE
Set up your environment
Create build-ready Dockerfiles for both architectures
Build and deploy multi-architecture images on GKE
Prepare manifests and deploy on GKE
Automate builds and rollout with Cloud Build and Skaffold
You are ready to create a GKE cluster with two node pools (amd64 and arm64), then build and push multi-arch images natively on those node pools.
Each architecture uses its own BuildKit pod, and no QEMU emulation is required.
GKE uses VPC-native (IP aliasing) and requires two secondary ranges on the chosen subnet: one for Pods and one for Services.
For the default VPC, GKE creates the secondary ranges automatically.
Run the commands below in your terminal, adjusting the environment variables as needed for your account:
# Set/confirm network variables (adjust to your environment)
export REGION="${REGION:-us-central1}"
export NETWORK="dev-eco-nw-pb" # your VPC
export SUBNET="dev-eco-nw-subnet" # your subnet
export POD_RANGE_NAME="gke-boutique-pods"
export SVC_RANGE_NAME="gke-boutique-svcs"
# Inspect the subnet and existing ranges
gcloud compute networks subnets list --network "${NETWORK}" --regions "${REGION}" \
--format="table(name,region,ipCidrRange,secondaryIpRanges.list())"
# If missing, add two secondary ranges (example CIDRs; ensure no overlap)
gcloud compute networks subnets update "${SUBNET}" --region "${REGION}" --add-secondary-ranges ${POD_RANGE_NAME}=10.8.0.0/14,${SVC_RANGE_NAME}=10.4.0.0/20
This approach prevents users on the default VPC from accidentally setting NETWORK/SUBNET variables and passing incorrect flags later.
Create a GKE Standard cluster with VPC-native (IP aliasing) enabled and no default node pool. You’ll add amd64 and arm64 pools in the next step.
The command below works for both default and custom VPCs. If the NETWORK, SUBNET, and secondary range variables are unset, GKE uses the default VPC and manages ranges automatically:
# Cluster vars (reuses earlier PROJECT_ID/REGION/ZONE)
export CLUSTER_NAME="${CLUSTER_NAME:-gke-multi-arch-cluster}"
# If using the default VPC, you can omit --network/--subnetwork.
# If using a custom VPC, include them and pass the secondary range names you set above.
gcloud container clusters create "${CLUSTER_NAME}" --region "${REGION}" --enable-ip-alias --num-nodes "1" --machine-type "e2-standard-2" ${NETWORK:+--network "${NETWORK}"} ${SUBNET:+--subnetwork "${SUBNET}"} ${POD_RANGE_NAME:+--cluster-secondary-range-name "${POD_RANGE_NAME}"} ${SVC_RANGE_NAME:+--services-secondary-range-name "${SVC_RANGE_NAME}"}
Now create an x86 (amd64) pool and an Arm (arm64) pool. Use machine types available in your region. The commands below use c4-standard-* for x86 and c4a-standard-* for Axion:
# amd64 pool (x86)
gcloud container node-pools create amd64-pool --cluster="${CLUSTER_NAME}" --region="${REGION}" --machine-type="c4-standard-16" --num-nodes="1" --image-type="COS_CONTAINERD" --quiet
# arm64 pool (Axion)
gcloud container node-pools create arm64-pool --cluster="${CLUSTER_NAME}" --region="${REGION}" --machine-type="c4a-standard-16" --num-nodes="1" --image-type="COS_CONTAINERD" --quiet
# delete the tiny default pool
gcloud container node-pools delete default-pool --cluster="${CLUSTER_NAME}" --region="${REGION}" --quiet
Connect kubectl and confirm node architectures:
gcloud container clusters get-credentials "${CLUSTER_NAME}" --region "${REGION}"
kubectl config current-context
kubectl get nodes -o wide
kubectl get nodes -L kubernetes.io/arch
You should see nodes for both architectures. In zonal clusters (or when a pool has --num-nodes=1 in a single zone), expect one amd64 and one arm64 node. In regional clusters, --num-nodes is per zone, so with three zones you’ll see three amd64 and three arm64 nodes.
Now run a BuildKit pod on an amd64 node and another on an arm64 node. Buildx routes each platform’s build to the matching pod. These are native builds with no QEMU emulation.
# Namespace for BuildKit pods
kubectl create ns buildkit --dry-run=client -o yaml | kubectl apply -f -
# Create the builder (amd64 node)
docker buildx create --driver kubernetes --name gke-native --use --driver-opt namespace=buildkit,replicas=1,loadbalance=sticky,nodeselector=kubernetes.io/arch=amd64 --platform linux/amd64
# Append an arm64 node to the same builder
docker buildx create --driver kubernetes --append --name gke-native --driver-opt namespace=buildkit,replicas=1,loadbalance=sticky,nodeselector=kubernetes.io/arch=arm64 --platform linux/arm64
# Bootstrap and verify pods
docker buildx inspect gke-native --bootstrap
kubectl -n buildkit get pods -o wide
You now have a multi-node Buildx builder named gke-native. Each BuildKit pod is pinned to a specific CPU architecture using node selectors.
You can now build all services for linux/amd64 and linux/arm64 using the GKE-backed builder.
Run the commands:
cat << 'EOF' > build-all-multiarch.sh
#!/usr/bin/env bash
set -euo pipefail
: "${GAR:?Set GAR like REGION-docker.pkg.dev/PROJECT/REPO first}"
services=(
adservice
cartservice # special context below
checkoutservice
currencyservice
emailservice
frontend
paymentservice
productcatalogservice
recommendationservice
shippingservice
loadgenerator
for svc in "${services[@]}"; do
# cartservice Dockerfile path differs
if [ "$svc" = "cartservice" ] && [ -d "src/cartservice/src" ]; then
ctx="src/cartservice/src"
else
ctx="src/${svc}"
fi
echo ">>> Building ${svc} for amd64+arm64..."
docker buildx build --builder gke-native --platform linux/amd64,linux/arm64 --provenance=false -t "${GAR}/${svc}:v1" "${ctx}" --push
done
EOF
chmod +x build-all-multiarch.sh
./build-all-multiarch.sh
Each tag you push is a manifest list that points to two images, one per architecture.
List pushed images:
gcloud artifacts docker images list "${GAR}"
Inspect one tag to confirm it shows both platforms:
docker buildx imagetools inspect "${GAR}/adservice:v1"
The output is:
Platform: linux/amd64
Platform: linux/arm64
You are now ready to prepare the application manifests and deploy the application.
