Run agent-generated Python in GKE Agent Sandbox on Google Axion
Prepare your local machine for Agent Sandbox on GKE
Create the GKE cluster and Axion node pool
Claim a sandbox and test its restrictions
Analyze a CSV file in the sandbox
Open a shell and inspect the sandbox
Connect Antigravity CLI and run code in the sandbox
Preserve results and delete cloud resources
Use the Arm gVisor pool backed by
c4a-standard-2 machines. The provided sandbox.yaml selects that node pool for your Python sandbox workloads.Keep
LP_WORKDIR set and run cd "$LP_WORKDIR" before continuing. If you open a new terminal, source env.sh if you saved it. Otherwise, re-export variables such as LOCATION, REGION, CLUSTER_NAME, NODE_POOL_NAME, and MACHINE_TYPE.Run the Python test and check that it reports UID
1000. You should also see a denied write under /etc and a successful write to /workspace. Later, use kubectl exec to inspect the running sandbox interactively.Your first run with
analyze_sales_initial.py fails as expected. The runner replaces it with analyze_sales.py in the same sandbox workspace, runs six tests, and retrieves summary.json and report.html.In
agy, open /permissions and select Project. Allow mcp(gke-sandbox/*) and deny command(*), read_file(*), and write_file(*). Check that your session uses the gke-sandbox tools.
