Install Python programs and authenticate the Antigravity CLI
You’ll now install the Antigravity CLI and connect it to your Google Kubernetes Engine (GKE) sandbox. After connecting to the sandbox, you’ll prompt the CLI to write and run a Python program. The code runs inside the sandbox on the remote Arm node, not on your local machine. You’ll verify this by checking that the output shows the remote Linux environment.
Start by downloading necessary files, including the program that you’ll run:
cd "$LP_WORKDIR"
BASE_URL=https://raw.githubusercontent.com/ArmDeveloperEcosystem/arm-learning-paths/main/content/learning-paths/servers-and-cloud-computing/gke-agent-sandbox/files/mcp-bridge
for FILE in \
  bridge.py \
  server.py \
  remote_tools.py \
  prepare_session.py \
  verify_connection.py \
  capture_hello.py \
  finish_session.py \
  requirements.txt; do
  mkdir -p mcp-bridge
  curl -fL "$BASE_URL/$FILE" -o "mcp-bridge/$FILE" || exit 1
done
If agy isn’t installed, follow the instructions in the Antigravity CLI install guide to install the Antigravity CLI and add it to your PATH in ~/.zshrc or ~/.bashrc.
For an existing installation, run agy update to get the latest version.
Sign in to authenticate agy with your Google account:
agy
On your local machine, this opens a browser for Google Sign-In.
On a remote or SSH session, it prints a URL. Copy the URL and open it in your local browser to complete the login.
After authenticating, type /exit to close agy and return to your terminal.
Set up the MCP bridge
The Model Context Protocol (MCP) bridge is a Python script that runs on your local machine and forwards the agy tool calls to the sandbox Pod using kubectl.
Create a virtual environment for the bridge and install its dependencies:
python3 -m venv mcp-bridge/.venv
source mcp-bridge/.venv/bin/activate
pip install -r mcp-bridge/requirements.txt
Create a sandbox claim and prepare the agy workspace:
export AGY_SESSION="$LP_WORKDIR/runs/agy"
export AGY_RECORD="$AGY_SESSION/run.json"
export AGY_CLIENT="$AGY_SESSION/client"
rm -rf "$AGY_SESSION"
python3 mcp-bridge/prepare_session.py \
  --context "$GKE_CONTEXT" --namespace "$NAMESPACE" --pool axion-python-pool \
  --output-dir "$AGY_SESSION"
prepare_session.py creates a sandbox claim, waits for the Pod to be ready, and writes the MCP configuration that tells agy which Pod to use.
Verify the connection:
python3 mcp-bridge/verify_connection.py --record "$AGY_RECORD"
The expected output is:
        MCP connected: environment, execute_command, list_files, read_file, write_file
GKE: aarch64 UID 1000; Pod <claim-bound-pod>
The output identifies the remote Pod and confirms that the MCP tools are available.
If the connection fails, check that GKE_CONTEXT, NAMESPACE, and the cluster credentials are still set correctly, then re-run prepare_session.py to create a new claim.
Configure agy permissions and run code remotely
Start a new agy project in the prepared workspace:
cd "$AGY_CLIENT"
agy --new-project
Use /mcp to confirm that gke-sandbox is connected with the five tools listed earlier.
Open /permissions, select Project, and set the following rules to allow the GKE tools and block built-in local execution:
ListRule
Allowmcp(gke-sandbox/*)
Denycommand(*)
Denyread_file(*)
Denywrite_file(*)
Enter the following prompt:
Write hello.py using only Python's standard library. Print "Hello, World!",
the operating system, machine architecture, user ID, working directory,
Python version, and kernel release. Print available Linux distribution
information from /etc/os-release, or the macOS version when running on macOS.
Handle missing platform-specific files gracefully. Run the program and show
its actual output and exit code.
Watch that agy uses gke-sandbox write_file and execute_command tools rather than its built-in local tools.
        Hello, World!
Operating System: Linux
Machine Architecture: aarch64
User ID: 1000
Working Directory: /workspace/csv-<task-id>
Python Version: 3.12.15
Kernel Release: 4.19.0-gvisor
Linux Distribution Information (/etc/os-release):
NAME: Debian GNU/Linux
PRETTY_NAME: Debian GNU/Linux 12 (bookworm)
VERSION_ID: 12
The output including Linux, aarch64, UID 1000, and a gVisor kernel confirms that the code ran in the remote sandbox.
Save the conversation using agy conversation controls, then enter /exit.
Capture the result
Back in your terminal, capture the results of the remote run:
cd "$LP_WORKDIR"
python3 mcp-bridge/capture_hello.py --record "$AGY_RECORD" --label remote-first
The command runs hello.py in the recorded Pod one more time. It saves the source, output, and a SHA-256 hash to $AGY_SESSION/remote-first/ for your records.
You’ve connected the Antigravity CLI to a GKE sandbox through an MCP bridge. You’ve verified that agent-generated Python ran remotely on Arm with gVisor isolation.
Next, you’ll preserve your results and remove the cloud resources.
