Inspect the CSV analysis task
The sandbox isolates each attempt. A failure therefore doesn’t affect your local machine or require cleanup of the deployment environment.
Within the same sandbox, run_demo.py performs the following tasks:
  • Runs a broken program analyze_sales_initial.py to analyze a CSV file
  • Observes the failure
  • Replaces the broken program with the corrected version analyze_sales.py
  • Runs the tests
Use the running cluster and warm pool for this CSV file analysis.
Start by downloading the necessary files:
cd "$LP_WORKDIR"
mkdir -p csv-app
BASE_URL=https://raw.githubusercontent.com/ArmDeveloperEcosystem/arm-learning-paths/main/content/learning-paths/servers-and-cloud-computing/gke-agent-sandbox/files/csv-app
for FILE in \
  sales.csv \
  analyze_sales_initial.py \
  analyze_sales.py \
  run_demo.py \
  remote_worker.py \
  test_sales.py; do
  curl -fL "$BASE_URL/$FILE" -o "csv-app/$FILE" || exit 1
done
The CSV file has 12 data rows, including sales, refunds, and invalid fields. Inspect the data:
cat csv-app/sales.csv
Review the initial program before running it:
cat csv-app/analyze_sales_initial.py
The initial revision of the analysis program analyze_sales_initial.py assumes that every quantity can be converted to an integer. Its core calculation is:
total += int(row["quantity"]) * Decimal(row["unit_price"])
A row with an empty quantity makes this fail.
The revised program csv-app/analyze_sales.py corrects this issue by performing the following tasks:
  • Validates input
  • Accounts for refunds
  • Uses decimal arithmetic
  • Renders an HTML report with escaped product names
You’ll use saved revisions for a reproducible comparison.
Run the failure and correction sequence
The runner uses kubectl to create a claim, verify its Pod, and upload the CSV, tests, and initial program from your local machine. It runs that program remotely, checks the expected failure, and replaces only the program. The runner then runs the corrected application and six tests in the same workspace.
Run the sequence with cluster context:
python3 csv-app/run_demo.py \
  --context "$GKE_CONTEXT" --namespace "$NAMESPACE" \
  --pool axion-python-pool --output-dir "$LP_WORKDIR/runs/csv"
The output includes the initial failure:
        Initial revision failed as expected:
Traceback (most recent call last):
ValueError: invalid literal for int() with base 10: ''
The workspace identifier and traceback line numbers might vary.
That error is part of the demonstration. The runner treats an unexpected initial success, a timeout, or a different failure as an unsuccessful run.
After replacing the program, the output includes the checks and report result. The following condensed example omits the test duration:
        test_duplicate_orders_are_not_double_counted (test_sales.SalesChecks...) ... ok
test_invalid_rows_are_accounted_for (test_sales.SalesChecks...) ... ok
test_known_sample (test_sales.SalesChecks...) ... ok
test_malformed_column_counts_can_be_reported (test_sales.SalesChecks...) ... ok
test_product_names_are_escaped_in_html (test_sales.SalesChecks...) ... ok
test_refund_and_decimal_precision (test_sales.SalesChecks...) ... ok
Ran 6 tests in 0.001s
OK
Report: net revenue $328.41; 9 accepted, 3 rejected
Cleanup: claim removed; bound Sandbox and Pod deleted.
The checks cover the following areas:
  • Duplicate orders
  • Invalid rows
  • Decimal precision
  • Refunds
  • HTML escaping
The runner also verifies that the CSV hash stays unchanged between executions. It replaces the program in the same sandbox workspace without creating a new claim.
Inspect the retrieved reports
The runner downloads summary.json, report.html, and run.json into the specified output directory before releasing the claim. Inspect the results:
python3 -m json.tool "$LP_WORKDIR/runs/csv/summary.json"
python3 -m json.tool "$LP_WORKDIR/runs/csv/run.json"
Confirm the following values in summary.json:
FieldExpected value
gross_sales397.90
refund_amount69.49
net_revenue328.41
accepted_rows9
rejected_rows3
Open $LP_WORKDIR/runs/csv/report.html in your browser. On macOS, use open "$LP_WORKDIR/runs/csv/report.html". On Ubuntu with a desktop, use xdg-open "$LP_WORKDIR/runs/csv/report.html". From a local machine without a desktop, copy the report to a machine with a browser.
The HTML displays the same revenue and row counts, plus monthly totals, product totals, and rejected rows.
Understand the workspace lifecycle
The runner exiting successfully confirms that the task claim and its bound Sandbox and Pod were deleted. The reports remain on your local machine. The warm pool and cluster keep running for the next task.
For a failed run, inspect $LP_WORKDIR/runs/csv/run.json. A cleanup_error needs attention even if application checks passed.
You can repeat the task with a new output directory, such as runs/csv-second.
You’ve run a failure-and-correction workflow on Arm and verified the business result. You’ve also retained reports after removing the task environment.
Next, you’ll open an interactive shell in another claimed sandbox to inspect its user, filesystem, and exposed Linux information.
