Define the Python environment
Continue on your local machine in $LP_WORKDIR. Download the files that you need to define the sandbox environment:
cd "$LP_WORKDIR"
BASE_URL=https://raw.githubusercontent.com/ArmDeveloperEcosystem/arm-learning-paths/main/content/learning-paths/servers-and-cloud-computing/gke-agent-sandbox/files
for FILE in \
  sandbox_common.py \
  sandbox.yaml \
  claim.py \
  workload.py; do
  curl -fL "$BASE_URL/$FILE" -o "$FILE" || exit 1
done
Inspect the template before applying it:
cat sandbox.yaml
The template selects the Arm gVisor node pool and uses python:3.12.15-slim-bookworm. The image provides Python on Debian 12 without installing Python packages on your local machine. Its principal settings are as follows:
SettingEffect
runtimeClassName: gvisorSelects the sandbox runtime
UID and GID 1000Runs the workload without root identity
readOnlyRootFilesystem: trueMakes the image root filesystem read-only
Writable /workspace and /tmp volumesProvides task and temporary storage
Dropped capabilities and no privilege escalationRestricts process privileges
automountServiceAccountToken: falseOmits the default Kubernetes API token
500m CPU and 512Mi memory limitsBounds the configured compute resources of the Pod
The container sleep command keeps it available for interactive tasks for up to 24 hours per start. These examples aren’t persistent storage: the emptyDir workspace is tied to the lifetime of the Pod.
Apply the resources:
kubectl --context "$GKE_CONTEXT" create namespace "$NAMESPACE" --dry-run=client -o yaml \
  | kubectl --context "$GKE_CONTEXT" apply -f -
kubectl --context "$GKE_CONTEXT" apply -f sandbox.yaml
kubectl --context "$GKE_CONTEXT" -n "$NAMESPACE" get sandboxwarmpool,sandbox,pod -o wide
Wait for an available warm Pod to become ready before continuing.
Claim and identify your sandbox
claim.py is a Python script that automates the sandbox lifecycle. The script creates a SandboxClaim against the warm pool and waits until a sandbox Pod is ready. It then records the exact claim, Sandbox, and Pod names in a local run directory. You’ll use those recorded names in subsequent commands to target the right Pod.
Create the claim and wait for the Pod to be ready:
rm -rf "$LP_WORKDIR/runs/smoke"
python3 claim.py create \
  --context "$GKE_CONTEXT" --namespace "$NAMESPACE" \
  --pool axion-python-pool --purpose smoke --output-dir "$LP_WORKDIR/runs/smoke"
When create finishes, load the Pod name into your shell and verify the binding:
source "$LP_WORKDIR/runs/smoke/binding.env"
python3 claim.py check --record "$LP_WORKDIR/runs/smoke/run.json"
binding.env exports POD_NAME and related variables so that subsequent kubectl exec commands know which Pod to target. Each run needs a new output directory, so choose a different name if you repeat this step.
If readiness times out, inspect the claim and namespace events:
kubectl --context "$GKE_CONTEXT" -n "$NAMESPACE" get sandboxclaim,sandbox,pod -o wide
kubectl --context "$GKE_CONTEXT" -n "$NAMESPACE" get events --sort-by=.lastTimestamp
Run the Python test
Review workload.py before running it:
cat workload.py
The script runs inside the sandbox and does four things:
  • Reports the CPU architecture and user ID to confirm that it’s running on Arm as a non-root user (UID 1000).
  • Checks that the default Kubernetes service-account token is absent, as configured in the template.
  • Attempts to write a file under /etc. This write is expected to fail because the root filesystem is read-only and the process runs without root privileges. A write to /workspace succeeds because the template mounts a writable volume there.
  • Computes the sum of squares of integers 1 to 9 as a numeric result to confirm that the Python environment works.
Verify that the claim is still bound, then run the script and retrieve the result:
kubectl --context "$GKE_CONTEXT" -n "$NAMESPACE" exec -i "$POD_NAME" -c runtime -- \
  python3 - < workload.py
kubectl --context "$GKE_CONTEXT" -n "$NAMESPACE" exec "$POD_NAME" -c runtime -- \
  cat /workspace/result.json > "$LP_WORKDIR/output/result.json"
cat "$LP_WORKDIR/output/result.json"
The output is similar to:
  "architecture": "aarch64",
  "uid": 1000,
  "sum_of_squares": 285,
  "service_account_token_present": false,
  "denied_write": {
    "errno": 13,
    "reason": "Permission denied"
The errno value for the denied write can vary.
The script fails if the /etc write succeeds. EACCES, EPERM, or EROFS are all accepted denied-write results.
Record the runtime class and image ID:
kubectl --context "$GKE_CONTEXT" -n "$NAMESPACE" get pod "$POD_NAME" \
  -o jsonpath='{.spec.runtimeClassName}{"\n"}{.status.containerStatuses[0].imageID}{"\n"}' \
  > "$LP_WORKDIR/output/runtime-image.txt"
cat "$LP_WORKDIR/output/runtime-image.txt"
The runtime class should be gvisor.
Release the claim for the test
Delete only the verified claim and wait for its bound Sandbox and Pod to disappear:
python3 claim.py delete --record "$LP_WORKDIR/runs/smoke/run.json"
The helper confirms claim, Sandbox, and Pod deletion. The warm pool remains available and prepares a replacement Pod.
You’ve run Python on Arm with a non-root user, retrieved a workspace artifact, and verified a denied system-directory write.
Next, you’ll use the same pool for a CSV analysis task with a reproducible failure and correction.
